Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
First time installing printer
When i turn it ON for the first time, It's making sqeeking noise( the top thread brown and black). I'm following the manual intruction to install ink cartridge. The error light is flushing. I'm still waiting what to do next. Please help.
    Genius:
  • 1,447 Answers
Hi-
Had one that has the same problem. Its having a hardware issue. call epson for replacement printer. 562 276 4382.
Hope this helps
Posted on Nov 09, 2008
?I HAVE A ZUKI TL-2010Q. IT WORKED UNTIL I HAD TO CHANGE THE BOBBIN.NOW THE TOP THREAD KEEPS BREAKING.I HAVE RETHREADED THE TOP THREAD SEVERAL TIMES,WITHOUT ANY CHANGE IN THE SEWING.
Remove both, the top thread and the bobbin from the machine.
Re-check your owner's manual then re- thread the bobbin and install it in the machine. (Make sure the bobbin is turning the correct direction.)
Re-check the instructions for threading the top thread.
ALWAYS RAISE the presser foot and re-thread the top thread following the thread path shown in the manual.
Start with the top tension set at the midway point between low and high number--then tweak it for your current project.
AVOID old or bargain bin thread!!!!
Sometimes, installing a brand new needle will help. A new needle should be installed every 8 hours of sewing time! A damaged needle will cause a great deal of sewing havoc but is really inexpensive when resolving sewing issues.
Dec 06, 2017 | Sewing Machines
Thread on bobbin does not attach to needle when needle is turned down.
Depends what was causing the noise. It could merely have been the build-up of lint and thread. However, something else could be the cause.
First: Install a brand new needle. A bent, damaged, old needle will frequently cause noise because it is striking something it should not. A dull needle will also make a thunking sound as it tries to penetrate the fabric. The needle should be changed about every 8 hours of sewing...a very inexpensive fix!
Also, be sure to following the oiling instructions (if any) in your manual. Use only fresh good quality sewing machine oil and apply only 1-2 drops in each spot as instructed.
If the top thread still fails to pick up the bobbin thread, it is likely the machine has been knocked out of time. Take it for service.
May 02, 2017 | Janome Sewist 525S Mechanical Sewing...
Clicking noise
Check the printer thoroughly for any small pieces of paper caught on a roller in the printer. If your printer is making a grinding noise, you may have a loose gear or roller in the printer.
If the noises started shortly after you installed a toner cartridge, turn off the printer and pull out this toner cartridge. Look up into the printer where this toner went. Make sure that both the charge roller and the transfer roller are still seated in the printer properly.
  • The charge roller is a tan-colored or gray roller attached to the inside of your top lid. Remove the toner cartridge from your printer. Close the top lid halfway with the cartridge still out. You will see the charge roller come down as you lower the top lid. Make sure that the charge roller is installed correctly within the two black arms on each end and that the roller does spin freely.
  • The transfer roller is the black, spongy roller in the bottom of the printer, under the toner cartridge. Push lightly down on it at both ends to make sure it is seated properly in its housing. NOTE: Try not to touch the charge roller with your bare hands. It is susceptible to the oil and may cause a permanent fingerprint to remain on the roller surface.
  • When you have checked the charge roller and the transfer roller, look around inside the printer. See if you can find any rollers that look loose or broken inside. Also look for any loose shreds of paper. If you do find a loose or broken part, you printer will probably require service to fix the problem.
If the rollers look fine, go ahead and reinstall the toner cartridge. If the squeaking/grinding noise continues and none of the rollers looks out of place, try swapping out the toner cartridge. There is a small chance that the toner cartridge is causing the squeaking/grinding noise. If you have any extra toner cartridges in stock, try another toner cartridge and see if that clears up the noise. If you have another working printer of the same model, try swapping the toner cartridges. See if the problem follows the toner cartridge or stays with the printer.
If replacing the cartridge does not cause the noises to go away, there are a few other things you can do to help pinpoint the source of the noise.
If the noise continues on the main printer, try opening the rear exit door while printing. See if you can tell if the grinding noise might be coming from one of those rear exit rollers/gears. If it does sound like it is coming from the rear of the printer, again look for any loose or broken part or any small pieces of paper.
If you have added any additional feed options (like a tray 2 or 3 option, duplex option, or envelope feeder), please remove these options. Try printing a few prints without these feed options attached. This will eliminate one of the feed options as the cause. If the noise goes away when you remove the options, reattach them one at a time. If the noise returns on one specific option, a roller or gear on that option may be the cause of the noise.
Is your printer making a rhythmic THUMP - THUMP - THUMP - THUMP noise when printing? This noise is a side-effect of a feature called Envelope Enhance. The Envelope Enhance feature is built into the fuser unit of the printer to help keep envelopes from wrinkling. This sound is perfectly safe and normal if the printer is printing on envelopes.
If none of the above fixes eliminates the noise, the printer will probably need service to return it to working condition.
***If you need any technical help on printer then you can reach at here
Feb 15, 2013 | Canon imagePROGRAF iPF8000S 44"...
Audi a4 making a skweek noise in front when braking + making a kadoef noise in the back weal
get the front breakes checked incase they need replacing if they are ok you can try cleaning the rust of around the disks also taking the pads out and putting a bit copper grease on the backs of the pads might stop them from sqeeking some time a harder pad will make the sqeek any way but try the above it should stop hope this helps ivan
Oct 22, 2012 | 2001 Audi A4
I have a frigidaire stackable washer and dryer one solid unit the dryer will sqeek really loud when the drum turns but it sqeeks in the same position every time. but it does sometimes and sometimes it does...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 01, 2011 | Frigidaire Dryers
My hp 2100 laserjet makes a sqeeking noise when it begains to print as if it is a roller, it works fine from the upper single feed with no noise please advise. Thanks
This could be caused by a worn and shiny paper seperator pad in the cassette tray 2.It sits at the front in the middle of the tray
Oct 12, 2009 | HP LaserJet 2100 Printer
Makes a sqeeking noise while turning or on bumps
Suspension problem like a rubber bushing. Try recreating it, have some one push up and down on the front fenders one at a time, asuming the noise comes from the front. Try and spot where is coming from, if the part looks good spray it with lubricant not penetrating oil. Is best to replace what ever is making the noise.
May 11, 2009 | 2006 Chevrolet Equinox
RUUD 14 seer heat pump makes loud squeeking noise after cycling.
Your problem is the TXV. I just had person with the same problem. Replace TXV no problem Rusty
May 01, 2009 | Ruud UAMB Air Conditioner
Maytag washer cleans poorly & has been making loud sqeeking noise
The drive Belt is loose adjust it's tension or change with new one.
Jan 09, 2018 | Maytag SAV3655A Top Load Washer
Black ink cartridge
I understand that you are unable to print in black.
Please perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
Once the steps are done, please do not insert the cartridges into the printer.
Perform the following steps:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Please re-insert the cartridges and check for the functionality of the printe by printing any document or making a color copy fromt the front panel of the All-in-One.
Regards,
Sagar.
Jul 23, 2008 | HP Photosmart C5180 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
