Question about Philips 30PW6341 30" TV
Philips 24PW600 My 24" Phillips wide screen is starting to go out of focus in the corners when I'm on Cable the program information when I change page is barely readable. Is there an adjustment or is my Tube on its way out. Cheers
I didn't understand that your assistance was NOT free. So, if I had to spend some money for it and get some good advices, I think it would be better for me to take my TV set "phisically" to a customer service in the area where I live...Anyway thank you, but at this point I prefer to do by myself...
Posted on Mar 28, 2008
0 characters
1 Points
Philips Magnavox 27MS343S 27" TV picture stretched or zoomed !
Take of the back and there is buttons inside, try turning them.
Nov 25, 2013 | Philips Magnavox 27MS343S 27" TV
After Power outage - picture is larger than screen
This TV also should have similar facility like 19" Tv. Try the menu, it may be in different name or classification. I do not suspect circuit fault. If you can access service menu code you can try. Better take assistance from service center. If you access service menu, do not for get to note down the values in each and every step.
Apr 30, 2010 | Philips 19PR19 19" TV
I hooked up the cable but do not know how to set the channels up. All i get is static or a black screen that says FRONT in the top left corner. Can you help me.
If the screen says "Front" on it, then you need to change the input. The "Front" input is for connections made to the front (video game, camcorder, etc).
See for the manual.
-=/ Daft Tech /=-
Oct 23, 2009 | Philips 25PS40S 25" TV
Blurry picture
If this isn't due to a decaying capacitor, you may be able to correct the focus. PLEASE NOTE! Once the rear housing is removed, there are many points where dangerous voltages exist!  Please use caution and behave like there is a live rattlesnake hiding in the unit.
The rear housing on most is secured by only a few screws; four at the corners and perhaps two located around the cutout for the connectors. Don't remove any connectors by accident, they are normally mounted on a panel.
Once the housing is removed, you will need at least a very well insulated flat blade or #1 Phillips screwdriver - specially insulated tools for this kind of work can be had but if caution is used, normal ones will work.
You may have to remove the AC cord from the rear housing to use it to power up the set if it is attached.
Locate a largeish object that has a thick cable coming from its top and connected to the picture tube that will have a rubber cover over the connecting point on the tube. This device is the 'flyback' or horizontal output transformer. It will have two, sometimes three protruding adjustments. I recommend having a mirror positioned in front of the set so you can see instantly what is happening when you adjust it. Keep kids well away from the set, better yet, out of the room completely; they can distract and even get hurt if they move quickly.
One of the adjustments will affect the brightness - adjust any of these very slowly, you can damage the picture tube (CRT) if the brightness is turned too high and if misset, will create slanted white stripes across the screen if set too high. Another of these adjustments will affect the focus; this is the one you want to adjust. If there is a third one, it may affect focus on a part of the screen but not all of it.
If you get the brightness first (this adjusts the actual *very high* voltage that is connected via the thick cable), put it back where it was and try another.
You should be able to improve the sharpness of your video to its optimum again if the problem is not related (as previously stated) to a failing part. If you cannot improve the focus, then it is time to turn it over to a tech to troubleshoot.
Jan 28, 2009 | Philips 36PT842H 36" TV
Problem with televisor phillips 27f8007583 chassis
Philips 27f8007583 how to reset auto programming
Dec 29, 2008 | Philips 24PT6341 24" TV
Television - blurry
if you know to adjust the focus at the back of the plyback,the upper knob adjust it .if there's no effect, change the CRT socket,the white socket with many pins at the back of the picture tube
Oct 11, 2008 | Philips Standard (CRT) Televisions
Fix the color on my tv
sir/maam kindly adjust its screen focus of your tv,,,,thankss and hopetohelp you,,,gud luck!!
Feb 27, 2008 | Philips 20PT6441 20" TV
Phillips 27PT9007D/17 Manufacture Date May 2007
Have you changed any settings or added
any new components to the set like a
dvd player etc
Nov 20, 2007 | Philips Magnavox 27MS343S 27" TV
Model MW C20T6 Serial # V08613170
the Magnavox TV codes for a phillips universal remote are:
MAGNAVOX 0807, 0002, 0502, 0247, 0919, 0224, 0430, 0402, 0408, 0109, 0715
Nov 18, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 30PW6341 30" TV Logo
27 people viewed this question
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
