Question about D-Link Wireless
How can I see who is connected to my WiFi network - D-link DSL-G604T?
I am sure somebody is helping me with my cap....
  • dnieuwoudt Nov 09, 2008
    How exactly?
Go to your router and check for the status tab
Posted on Nov 09, 2008
  • Anonymous Nov 10, 2008
    im so sorry but your router vendor can help with that try to call their support hotline.
D'link dsl router 2760u wifi password
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Mar 11, 2013 | D-Link DSL-G604T Wireless Router
Front signal lights on DSL-G604T router
If this is a wireless router you are having people accessing your network.I suggest you wep or secure your network.
Feb 23, 2008 | D-Link AirPlus G DSL-G604T (790069265662)...
HOW TO Connect tl-740n wireless WIFI router to PTCL DSL WIFI ROUTER
The easiest way to chain two wireless routers. *Please note this is just to have wireless access*
Make sure DHCP is enabled for both, make sure their SSID (the name that shows up when you connect to it) is different.
Make sure they are both different networks. So for example configure the first for 192.168.0.0 network and the other for 192.168.1.0. Now plug an Ethernet cable from the 740n router (WAN) port into a (LAN)
Second method *This only works if the tl-740 router supports AP mode (Access point).
In the configuration of the 740 router, enable AP mode and make sure DHCP and nat are turned off if they are on. Configure the wireless to operate on channel 1 6 or 11. Name the SSID the same as the other router. Plug in Ethernet from WAN 740 to LAN on the other router. Now on the DSL router make sure the SSID is the same and select a different channel from (1,6,11). Now you're all set.
Jan 26, 2013 | D-Link DSL-G604T Wireless Router
How to connect a iphone 4s to your home network modem /router dsl G604t
lift your modem and look at the bottom side of it there would be an serial key ir password there simply copy it down and it would connect to it.
Oct 11, 2012 | D-Link DSL-G604T Wireless Router
D-Link DSL-G604T router crashes/freezes when a laptop using windows7 accesses the internet
Hi ! If it is your only computer Make sure the you use ADSL filters not only on your router to phone line connections but also on every phone you use. If you have any other computers on your network please explain how they are connected and what OS do they use?
Feb 02, 2011 | D-Link DSL-G604T Wireless Router
Laptop can't connect to DSL-G604T
You need to configure your router and use WPA encryption so that all accessing device can connect to it.
The obvious reason why the dell laptop can't connect is because of the WPA encryption set. It is different compared with what your router is actually broadcasting: WPA2.
So you can choose one of the 2 things to alter. Change your router's WPA2 encryption to WPA or change your Dell's setup to WPA2.
Mar 05, 2010 | D-Link DSL-G604T Wireless Router
I'm trying to connect vista laptop to d link dsl-604t router wireless which has a mac os 10.5 with password using it
On Vista, when you "view available networks", is the SSID (that you configured into the router) listed as an available network?
If so, click to select that SSID, and click CONNECT.
Nov 06, 2009 | D-Link DSL-G604T Wireless Router
No internet connectivity after upgrade firmware
1,there is a reset button
2,press this using any pin with power
3,automatically restart
4,connect your router with pc
5,type 192.168.1.1 on the browser
username:admin
password:admin12 or admin
configure router
enable dhcp
Oct 29, 2009 | D-Link DSL-G604T Wireless Router
How to create a security enable router?
Firstly, confirm that your ISP connection for email and internet is working correctly. Then connect the router to the ISP using the ADSL plug, and to your computer using the ethernet connection. It is best to set up your router using a wired connection to your computer. Once set up, you can connect your computer using WiFi. Have your ISP username and password handy.
There are two steps to secure your router:
1. Change your ADMIN password. Using a web browser like Intenet Explorer, type in the address, http://10.1.1.1. This should take you to a sign-on screen. Username is "admin", and password is set at the factory as "admin". You should now be logged in to your router. Go to the TOOLS tab, and change your admin password. NOTE THIS DOWN FOR FUTURE REFERENCE.
2. Secure the wireless part of the network: Go to the HOME tab, and select either WEP security (good) or WPA security (better, but some devices like printers don't like this).
For WEP you will need to enter a 10-digit WEP key. Numerals will do, or you can use hexadecimal (base 16) notation if you know this. Numerals will do and are no less secure. NOTE THIS DOWN in a secure place. Click the "APPLY" button.
For the WPA alternative, you should select the "Pre-shared Key" radio button, and code in your WPA password in the "PSK String" field. This can be a word and or numerals. I don't think spaces or other characters are allowed. NOTE THIS DOWN in a secure place. Click the "APPLY" button.
That's IT!! You've changed the admin password and secured the wireless part of the network.
You will then need to code the WEP or WPA password into the devices like printers and computers that you want to connect to the WiFi. For Vista computers, right click on the network icon in the tray (two little computers overlapping) and select "Connect to a network". Enter the WEP or WPA password when you see SSID "default" or your SSID if you've changed it. Most printers have a connection wizard.
There is a further enhancement if you are really paranoid: change the SSID and turn off the SSID broadcast. Go to the manual at:
ftp://files.dlink.com.au/products/DSL-G604T-GenII/Manuals/DSL-G604T_GenII_Manual_v1.11.pdf
if you want further details. Good luck with your secure network.
Jan 19, 2009 | D-Link AirPlus G DSL-G604T (790069265662)...
Computers & Internet Logo
298 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
