Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WT740 Aquarius washing machine
I have an "TEST" led light on my display when I turn machine on, this results in the machine doing a dry run !!!!! anyone any ideas ???
  • FixYaUpp May 11, 2009
    I have the same problem as this poster
5 Suggested Answers
zeusfaber
  • 247 Answers
SOURCE: Hotpoint Aquarius 1200 doesn't dry properly
Assuming that the dryer blower is running, but the air is just not coming out hot...... Turn off the power. Remember it's got to be either "hands on" or "power on" - any attempt to combine the two is going to end in tears. Take off the top cover of the machine, and find the dryer box (this is usually a metal duct which runs over the top of the machine, with a blower at one end). Set into this are several electrical parts. Expect to see the end of the dryer element (on the WD63, this is double, so two pairs of terminals), probably a pair of thermostats and probably a pair of thermal fuses. See pages 3, 5 and 6 at http://www.hotpoint-spares.co.uk/results.cfm?PageNum_Results=3&category=1505&secondary=0 for illustrations. Firstly, look at the thermal fuses, and see if they have reset buttons on them. If so, give them a good push, see if they click, and see if that fixes the problem. If this works, you need to find out what caused it to overheat in the first place. Check all the air ducts for lint blockage. Also, there's a cold water flow to cool the condenser while the dryer is running - make sure this works too. If this doesn't solve the problem, use a multimeter set on Ohms range (£10-£15 from B&Q if you haven't got one - a sound investment for the future) to check for continuity across the key components: The thermostats and thermal fuses each ought to read comfortably less than an ohm. If faulty, they will be much more. The elements should come in at a few tens of ohms for each half - it looks like the left hand pair of terminals serve one half of the element and the right hand pair the other. If faulty the resistance will be very much higher. Hopefully this will identify what needs replacing. Suggest you shop around - spares prices on the net vary enormously, and there's no really compelling reason not to use pattern parts instead of genuine if there's a big saving to be made. Good luck. A.
Posted on Mar 10, 2007
SOURCE: HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Posted on Feb 07, 2008
  • 53 Answers
SOURCE: F05 displayed on the LEd panel On our Hotpoint
check pump/filter/outlet hose is not blocked.
Posted on Oct 16, 2009
  • 82 Answers
SOURCE: I cannot open the door on my Hotpoint Aquarius
it sounds like you have a broken door handle Disconnect power before doing anthing remove lid , what you will need to do is usining a screw driver or somthing simular look down to where the catch is (you may need a tourch) and look carefully you should be able to to the door catch mechanisim from inside you will need to mimic the action of the door handel but using a screw driver it a bit fiddley but can be done there is no grate force needed and it the catch will only need to move a bout 3-8 mm to open
Posted on Jan 17, 2010
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
I have a code on the display f-08
hotpoint washing machine WT740 1400 code erroe F-08 flashing machine stops working after 20 minutes please help
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi i have a hotpoint washin machine and it kepp showing H20 on the csreen can you please help th model number is WT740
H20 indicates a problem with water supply.
Check the inlet hose/s for restrriction or kinks, ensure water supply pressure is o/k, also check the filter screens in the inlet valves, you will have to turn the water off to do this.
Dec 06, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Fault code stopping washer from working
My washing machine will not spin and in fact turn around at all, i did a wash earlier and it was making a funny noise...like some thing was caught in the drum. It is about 3 years old....It does still fill with water thou!
May 24, 2009 | Ariston Technologies Washing Machines
Testing Shows On Display
press and hold start/cancel button for 5 secs. Thenpress on /offbutton and start/cancel together until Doff is displayed the machine should now be ok
Nov 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
This works
Feb 04, 2008 | Hotpoint Washing Machines
Hotpoint Aquarius WF530 LEDs flashing
I cannot tell from your description what the error may be but here is a list of reasons;
https://www.whitegoodshelp.co.uk/hotpoint-aquarius-lights-flashing
Jun 13, 2017 | Hotpoint Washing Machines
Led flashes on then off
did you find out what this problem was?
Dec 07, 2006 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
172 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
