My laptop has become very sloow. It also takes a long time to start up and shut down.
  • AboYazan May 11, 2010
    operating system ?
Try to scan your laptop for any virus first then try to disable all unwanted programs to run during startup,
Posted on Nov 09, 2008
My tool improper shut down detected checking file system please help me
that message appears if the shut down process is not followed.
power failure , emergency shut down or other problems that just shut the pc down will result in files and folders becoming corrupted and not saved
when booting up if the message appears that states start in safe mode , start normally etc , click on start normally
Oct 25, 2016 | Computers & Internet
Toshiba l750
to answer your questions, yes it can/will damage hardware and yes, and your in luck there are easy fixes, one is just take some canned air, and blow it out via the vent,
two.... you can open up the panels in the back and take canned air and blow it out that way(do not turn can upside down)
three, replace the fan, it very simple too do, just open the back panel and unscrew the fan out,pull the little plug out and replace, take about 5mins
Jun 17, 2013 | Computers & Internet
Dell Vostro 1014 Laptop Computer is unable to start. how can I fix it?
i have laptop votro 1014 and its giving me problem that while playing oline game my laptop i becoming so slow
Aug 27, 2012 | Dell Vostro 1014 Laptop Computer
Laptop keeps shutting down
There are a few reasons, bad power supply adapter, cooling fan is not working or there is dirt blocking the ports causing it to shut down, battery issues, "remove to verify" the DC jack in the laptop has become intermittent and must be dismantled down to the motherboard level and flipped over for solder touch up.
Apr 14, 2012 | Dell Inspiron 1525 Laptop
I have a HP Pavilion dv9810us laptop. It is about 3.5 yrs old. Since last 1 yr I am noticing that the laptop is becoming extremely heated when I open any heavy resource hungry application. Once it gets too...
Hi.
If the laptop is getting very hot and shutting down then you no doubt need to clean the CPU fan and the air vents of any build up of dust that may have collected over the 3 years you've had it.
Get a can of compressed air and give short blasts through the air vents and the CPU fan grill. You should see dust shoot out of the vents when you depress the button of the can.
The CPU fan is located underneath that laptop and the air vents can be located at the sides or the back of the laptop.
If it still gets hot and shuts down after doing this then I suggest that you take the laptop to a reutable PC repair store and have them clean the inside of the laptop for you and have it serviced at the same time.
Hope this helps!!!
Regards.
May 23, 2011 | HP Pavilion dv9810US Notebook
Laptop keeps shutting down for no reason leaving blank screen
If your laptop cuts the power off (shuts down) from time to time that may be overheating problem. Dust is blocking the air outlets on the fan and processor cannot be cooled down properly. Thermal protection shuts your laptop down when it reaches some certain temperature. Most likely you will hear your fan spinning full speed before the shut down and the bottom of the laptop is hot.
Best solution is to take it apart, remove the fan and the heatsink, clean them thoroughly, apply new thermal compound and assemble the laptop. Easy solution (though not the best one)is to buy compressed air can and blow it through the vents of the laptop. It will help for some time but occasionally it will start again.
Sep 06, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Toshiba A65-S1062 - This laptop overheats and shuts down.
I bet that you had your laptop on all the time.
Your heat sink is saturated with dust and grit.
you may have to open up the unit and use a can of dust remover to clean the fins on the heat sink out. it is causing your CPU to shut down bucause it is becoming overheated.
Happy Fixing =)
Jul 11, 2009 | Toshiba Satellite A65-S1062 Notebook
My laptop becomes too hot & it shut downs suddenly when I use any big applications like turbo c or playing any game or when I try to write any cd through it. After few minutes its fan starts spinning very...
Sounds like you have a hardware fan & vent, the CPU shuts down when it gets too hot.
Check the fan, it should spin freely, clean the dust off the fan and heatsink assembly. Replace the fan if necessary.
When you use the laptop, make sure none of the vents are covered.
May 01, 2009 | Compaq Computers & Internet
Automatic shutdown, crashing applications & no startup repair
Yes, sounds like some of you applications may have become corrupted. It happens over time. Find the backup program if XP >start>accessories>system tools>backup on Vista just type "backup" in the start box. You will see and option to back up all of your docs., email, web favorites, etc. Back them up then use the Windows disc reload the operating system You will also, have to reload your applications. That will take care of it. Good luck and let me know if you have any questions. Don't forget to rate this solution with 4 stars before you log out.
Feb 10, 2009 | Acer Aspire 4315 Notebook
Computer reboots after I shut down
Hi there...
              MMMMMmmmmmmmm can you be more specific ? has it recently started to do this or has it done this since you purchased the computer ? Are you trying to shut it down from the windows shutdown menu or are you pressing the power button to let windows shut it down ?? I Need more information before I can help you work out whats going on with your computer ...If its only just started to happen you may have a virus or a trojan infecting your system or your bios has become corrupted.The windows registry may have become corrupted or your power supply is faulty...the problems that could cause this are numerous , please be more specific about how you are shutting the computer down..
Aug 12, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
David Payne
David Payne
