Question about NetGear DG834G Router
Configuration for wi-fi
I'v an internet connection from one of ISP. I want to configure wi-fi using netgear DG834G for others. How it is possible pls let me know?
  • Abul Quashem
    Abul Quashem Nov 10, 2008
    hello,
    Actually I'v a broadband connection and The IP details are: ip address: 192.168.1.1
    subnet mask: 255.255.255.0
    defauklt gateway: 192.168.1.1
    DNS address also..
    So how it is configured?
    Plz let me know it as quick as posible.
    Best,
    Quashem
Yes its possible! first thing you need to do is call your ISP and ask what kind of connection type you have for your service then if your connection type is static connection yo need to ask for IP information regarding your service this is the connection type you need to set in your router, now if your service is Dynamic connection or DHCP you just need to hook up your router and set it to dhcp . i believe most router is set to dhcp as deafault settings so all you have to do is hook up you internet connection to your router. if your still having problem with your router you can call your router vendor support number, just give then your connection type and they will guide you regarding the router settings and how many computers you want get connected.
Posted on Nov 09, 2008
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
My Netgear adsl router is not getting connected to Internet in pppOe mode ..
POPE configuration is logs into your ADSL system and connects to your ISP provider server to link , so one of the reason why it dosent is due to either password and username not correct. Log unto IP address of your Router and go to WAN configuration , Check your username and password and reset to the initial password and username your ISP provider gave you , when you signed up with them. Then apply changes , off your router for 1 min and then power it , then wait for the ADSL light on the router to be stable , connect to the IP address of your router again and "Volla" , it should be fine , if not , contact your ISP provider....
Oct 07, 2010 | NetGear DG834G 802.11G Wireless ADSL...
I have a Netgear router model 834G purchased in the UK. Will it connect to the french telephone network on ADSL without any problems?
yes you can use it with it.Just you need to configure your router as your french telephone ADSL settings.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 23, 2010 | NetGear DG834G Router
Netgear dg834gt connected to isp but not no internet
Via Wi-fi or Ethernet? Eithewr way, you must run the network wizard for either the cable (Ethernet) connection or the wireless connection wizard. Check your local area connection status window (Right click the computer icon on the lower right hand corner of your screen -usually-). If you are connected but, can not log in and, you are absolutely sure your modem is connected properly to both ISP and your Computer, try calling a tech from your ISP. Be very nice and maybe they will guide you through the process. If , on the other hand, you want to be absolutely sure it is a router issue. Connect directly to your modem and see it you can surf.
Nov 24, 2009 | NetGear DG834G Router
I use aol & recently the netgear connection keeps getting lost. i have now reset the netgear box by the reset button at the back but it will not connect to the internet. what do i need to do. when i...
connect router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration of your router.
Set WAN settings as your internet service provider settings.
Enable DHCP in advanced.
click on wireless or wi fi menu and enable wi fi .
Enable WEP or WAP security if you want to secure then add key it is your password to connect internet.
Then save and restart router then check.
Let me know if you need more assistance.
Nov 09, 2009 | NetGear DG834G Router
I cannot connect my IPOd Touch to the internet to download music . I need wi-fi connection. I already have internet service. What is wi-fi and how do I get it?
Wi-fi is wireless internet. Wireless internet is aquired via a router that supports wireless internet. The router is connected to your modem which supplies your internet.
Sep 29, 2009 | NetGear DG834G Router
Need network security key or passphrase for my netgear DG834Gv4/DG834GBv4 !!! PLEASE( IP 192.168.0.1)
LOGIN
There is a login key for the router that can be accessed by opening the
address http://192.168.0.1 as described: after the login all settings inside the router can be changed.
Note: use a wired connection when going into the routers' ip address.
When you can not login with the default password, reset the device:
Restoring the Default Configuration and Password
This section explains how to restore the factory default configuration settings, changing the
router’s administration password to password and the IP address to 192.168.0.1. You can erase the
current configuration and restore factory defaults in two ways:
• Use the Erase function of the Web Configuration Manager.
• Press the WPS button and Wireless button on the side of the router simultaneously. You can
use this method for cases when the administration password or IP address is not known.
Resetting to Factory Default Settings
You can use this method for cases when the administration password or IP address is not known.
To restore the factory default configuration settings:
1. Press and hold the WPS button and the Wireless button on the side of the router until the Test
LED turns on (about 10 seconds).
2. Release the buttons and wait for the router to reboot.
WIRELESS SECURITY + PASSPHRASE
The wireless security is a network name for wireless connection called
SSID: the identification name of your router.
The passphrase is used for a secure password getting permission to have wireless data transfer from the router to the computer and vice versa. ( No internet connection so far: only Local Area Network [LAN] )
MODEM
Because the device is a router / ADSL modem you'r able to setup the
modem part for connection on a telephone line to the internet / Wide Area Network [WAN] .
You should use passwords from the Internet Service Provider [ ISP ] enter and save them in the modem section of the device.
Support for DG834G on the internet:
http://www.netgear.com/Products/RoutersandGateways/WirelessGRouters/DG834G.aspx
Sep 22, 2009 | NetGear DG834G Router
How do i blok my so no one use it
You can secure your router with WEP key so everyone need password to connect your wi fi .
For that first connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then configure your router as WEP.
Then go to wi fi security and set WEP key it is your password to connect your internet .
Let me know if you need more assistanse.
Thanks.
Sep 01, 2009 | NetGear DG834G Router
Connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Jun 25, 2009 | NetGear DG834G Router
Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Nov 15, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
78 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
