Question about RCA RS2044 Shelf System
Volume problem When I turn the power on, the volume is very high even though I turned it off at a much lower volume. Is there a setting somewhere that I need to adjust to lower volume (besides readjusting the volume dial each time I turn it on)? Shouldn't it turn back on at the same volume as when I powered off? Thanks, Diane
  • OoAllieoO Nov 29, 2007
    Ya I have that too. I have it set to come on at a certain time and I can set the volume that way. Other than that, I haven't found a way to keep it off 14 I think it is.
No it always does that to me to it cannot be fixed
Posted on Aug 19, 2008
My jvc RX-5020 VBK IS NOT WORKING AT MAX VOLUME,ON SCREEN APPEARS OVERLOAD SOUND STOPS AND I HAVE TO TURN IT OFF AND TURN IT ON AGAIN ! WHAT IS GOING ON???
You must be using speakers with lower impedance than what is recommended. This causes the amplifier to over load at high volumes.The protection circuit shuts down the Amplifier to prevent further damage.
And please remember no amplifier is designed to run at full volume, same as a car speed - Even though the speedometer might show max: speed 200Miles per hour would you do it???
Jun 19, 2011 | Car Audio & Video
I have a sony MP# player, same range as listed but the 8GB model. I can only turn volume up to 16 before it starts distorting and giving a really bad and weak signal though the headset, when the stereo...
Headphones are not designed to have the volume levels run at maximum. At this level the sounds from the headphones will distort.
Speakers have a much larger voice coil and therefore will not distort at higher volume levels.
Also when the speakers are connected to the MP3 player the sound level may appear lower because speakers require more energy to drive (produce sounds). In this case you need to connect powered (amplified) speakers to the MP3 player.
Mar 10, 2011 | Sony Network Walkman NWZ-S545 Digital...
Speakers way too loud
You don't say how the Samsung routes out to the receiver. I assume you're using its RCA audio L and R jacks. Inability to adequately lower volume usually means you're NOT using a Line Level input, but maybe a speaker feed.
Your TV may have a setting for variable audio out, but even if you use the fixed setting you should be able to lower the playback volume to something comfortable with the receiver's volume knob. It does go down to completely OFF, right?
Jan 23, 2010 | Denon AVR-3805 Receiver
The minimum volume setting is too loud for my ears. Is there anyway to gain a lower volume setting?
There are a couple of different ways to lower the volume. One is to check your settings to see if you have a volume limit setting and turn it on. Another way, check the settings and see if you have a equalizer setting, and see if it is turned on, then experiment with other settings. If you have a built in 4 band equalizer you can set the sliders all the way to the bottom and it should turn down the volume a good bit. Last, is to go and by cheep ear buds / head phones, the cheeper ones, take more volume / power to get loud.
Jan 06, 2010 | Coby MP815 Digital Media Player
Volume won't stay set
There have been many new things that have been introduced when Google bought Youtube, and I believe that one of them is that it resets the computers speaker volume all they way up, the best I can currently suggest is that you leave the computer volume up and turn the physical speaker volume down, and it should be fine.
Hope this has helped,
Ryan Frame
Creative Energy Associates Technical Center
Aug 16, 2009 | Dell 5650 Computer Speakers
Low volume bass
You need to look got the amp for the sub if there is not one there is notting you can do. If there is one then just turn up the gain on the amp.
If not there are some times the gain is on the radio in a setting and the only way to find that is to look in the user manuil.
Oct 15, 2007 | Kicker 05C104 Car Subwoofer
Sound setting
There are several complaints in FIXYA and they are all about this same fault conndition....the volume is too high when turned on...
Because of the high number of complaints about this same fault I would suggest that its a manufacturer fault.
So the manufacturer should be contacted about it to ask for your money back..
Cheers From YUBEUT..
Sep 06, 2007 | GPX HM3817DT Shelf System
Default volume too high
You can download the manual from the link below: http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds787_manual_e.pdf c. Power On Volume This sets a designated volume setting for the TX-DS787 to be set every time that the power is turned on. This prevents the TXDS787 from being turned on while it is set to an extremely high volume and suddenly output very loud sounds. For the absolute volume display method, this can be set between min and max. For the relative volume display method, this can be set between ?? and 18 decibels. If you do not mind having the TX-DS787 turned on with its current volume setting, set this to "Last." Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 03, 2007 | Onkyo TX-DS787 Receiver
RCA RS2044 Shelf System Logo
261 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
