Question about IBM ThinkPad T20 2647 Notebook
Ethernet network adapter not working on T20
No matter what I do, when I install a "network adapter" to get my ethernet connection in dorm room to work (none are installed in network connections already, but there IS an ethernet port on back so I'm assuming there's some sort of card already in here - what brand or kind it is I cannot seem to figure out) the device fails to start (ERROR CODE 10) and I am sooo frustrated. This is a several years old IBM, has been upgraded to Windows XP professional but I don't think any other alterations beyond a wireless Netgear card installed on the side have been made. Thanks.
Also , not all IBM T20/T21 laptops shipped with a ethernet card fitted.
some had a modem only card. some a combined modem/ethernet card.
if the tiny LEDs light when plugged into a known active network connection then the card is present.
if they dont light up then it probably isnt present.
to check for the card..remove the panel secured by a single screw (just above center of the base)
the panel is in the top right quadrant of the bottom of the PC if you look at the bottom with the power connector at the top and the battery at the bottom.
remove the screw. open the panel.
there may or may not be a card present.
if there is if there is only a single white connector (with 2 small wires) then it is the Modem only card.
if there are 2 connectors one with 2 wires and another bigger with 8 wires..then you have the network card. check the connectors a fully pushed home.
its fiddly good luck
Posted on Nov 09, 2008
  • mt10 Oct 25, 2010
    THank you!!! This solved me hours of work figuring out why my "network adapter" was not detected. As a matter of fact... There's a RJ45 port, but no PCI card to handle it. Silly ol' computer...
  • 306 Answers
The ethernet connection will be list as Local Connection 3 or something while the wireless pcmcia card will be listed as Local Connection 4 or so. If that is not so then whatever is not listed is not recognized (needs a driver or is dead). If Add/Remove Hardware does not detect an ethernet card, onboard, then you will need to download the chipset drivers executable file which will include a LAN driver. Rarely but possible that ethernet circuit could be dead. You can get a pcmcia ethernet card with an RG45 connection for a broadband connection.
Thanks - nobody yet has been able to tell me the difference between having that port where an ethernet cable fits and actually having the card installed; I'm unsure about screwing off the top of the computer ... but I KNOW those lights have never lit up and that my network connection is good as everyone else on it seems to be able to connect no problem. Thanks again; if I find I DONT have one; can I add one in? I'd like to be able to use this LAN.
Posted on Nov 10, 2008
I just moved in to my college dorm yesterday and you have to use an ethernet cord for internet in my room. So I bought one, and when I plug it into the wall and into my computer, the ethernet port has a...
The lights means the port is active and working. Does the lan connection show as connected on the computer, what IP are you getting if any? Does the college use a proxy?
Aug 30, 2011 | Toshiba Ethernet Cable (cmcable)
Can't connect to internet the internet. My modem is working okay on another pc.Previously I could connect. I'm using GATEWAY NV54 laptop on Windows 7 Home premium
Have you received Windows 7 installed at the time of purchase? If not, check the compatibility with Windows 7. Check your Ethernet adapter with LAN for its proper functioning. Try using latest driver for Ethernet adapter from the laptop manufacturer. If the adapter is OK, restore the system to previous date on which it used to work or reinstall the operating system as a last resort.
Jun 14, 2011 | Microsoft Ethernet MN-120 Network Adapter
Im having problem connecting to the internet. Its telling me that i have to install a network adapter and a ethernet controller drive because its not working properly.
Try to uninstall your ethernet controller driver and install it again, if this not work again, you need to replaced a new network adapter.
Hope this work!
Thanks and Godbless!
Mar 29, 2011 | Computers & Internet
Ethernet connection has just stopped working. 80072ee7 error. However, device manager says adapter working properly, orange green lights working/flashing. cable checked to another comptuer without...
Try going into the control panel and then into the device manager. Find the ethernet device and remove it. Then re-boot the computer and the OS should re-detect the card and re-install the drivers. Hopefully this will get the card working again. Let me know if this helps.
Nov 18, 2009 | SMC Realtek 10/100TX PCI Fast Ethernet...
Cannot connect laptop with the eithernet cord
If you cannot connect your laptop using an Ethernet cable, make sure the laptop's wireless ethernet is disabled. To disable it in window xp, click the Start button and open the Control Panel. Double-click Network Connections. Right-click Wireless Network Connection and select Disable from the drop-down list.
04e3ee0.png If you are using a laptop with Windows Vista, click the Start Button and type Network and Sharing into the Start Search box. Select Network and Sharing Center from the Programs list. Select Manage Network Connections from the left pane of the window. The Network Connections window will open. Click on Wireless Network Connection. Select Disable this Network Device at the top of the window.
9a7c8c6.png Troubleshoot the Network
After disabling the laptop's wireless connection, be sure to restart the computer before trying to connect with the Ethernet cable again. If you still cannot connect the laptop to the network with an Ethernet cable after rebooting, check to make sure there is not a problem with the network itself. If there are others nearby connected to the same network, such as in your office, dorm or another public location, ask them whether they are currently able to connect to the network. If no one else is using the network, contact the system administrator or your Internet service provider to see if there may be an outage. This step can save you plenty of time troubleshooting if there is an outage in your area!
Troubleshoot the Ethernet Cable
If there is no problem with the network itself, the reason that you cannot connect the laptop may be the ethernet cable. Make sure that the Ethernet Cable is securely connected to both the laptop and the wall outlet. If possible, try connecting the Ethernet cable into another wall jack or port on the router, and then try using a different Ethernet cable. The Ethernet cable you are using may be damaged.
8686681.png Troubleshoot Network Settings
If the Ethernet cable does not seem to be the reason why you cannot connect to the network, check the laptop's network settings. In Windows XP, open the Control Panel and select Network Connections. Open Local Area Connection and check the status of the connection.
In Windows Vista, go to the Network and Sharing Center and select Diagnose and Repair from the left pane and wait for the results.
If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
If it says that the network adapter is unplugged and you have ruled out a problem with the Ethernet cable and port, the laptop's network adapter may have failed. Try using the same Ethernet cable on another computer. If you are able to connect to the network on another computer using the same Ethernet cord, contact the laptop's manufacturer, a computer repair technician or replace the network adapter yourself.
fc4831a.png If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
Oct 28, 2009 | HP Pavilion dv6000z Notebook
Ethernet drivers
My thinkpad R50 also has same problem, I update the driver and patch from the lenovo . You can update your network card diver and then open the admin tools to add the ethernet controller. Take a try.
Good luck.
Nov 14, 2008 | IBM ThinkPad T20 2647 Notebook
About ethernet
If you computer has already a ethernet card installed on it, just need to get a ethernet cable and connect it to your modem and the other to the computer and make sure the USB is disconnected already, then power off your modem and restart the computer then power the modem back on and check if internet is already working, if its not working you may need to contact your ISP and tell them to enable the ethernet connection of your modem....
Sep 14, 2008 | SMC Abocom ExpressCard to Ethernet Network...
Need Ethernet port on PC
If you have a wireless router then the ethernet cable will go between the modem and the router. Then you need a wireless LAN card to connect the PC to the router
What model router and modem do you have?
PC wireless card
Jul 03, 2008 | D-Link DFE-530TX+ Fast Ethernet PCI...
Connecting powerline ethernet adapters through orange livebox
Try to eliminate the problem into smaller parts. Try networking the two via the same power outlet via a multiple power board first in the same room. I don't have much experience with these powerline ethernet but i'm sure the configuration of these will be very similar as wireless router / access points and wireless adapter cards. However what I do know is that your power outlets need to be on the same "phase" of your electrical power system, so if you do this test I suggest (from one outlet board) you know the equipment works and your setup procedure works. then try seperating again and if it still doesnt work, check if your power outlets are wired on seperate phases (depends if your house has 3 phase wiring incoming to your home or not). Try another room or another outlet.
Oct 13, 2007 | Powerline Ethernet Network Adapter
IBM ThinkPad T20 2647 Notebook Logo
967 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
