Question about E-Machines eMachines Desktop PC
Emachine 5220 keeps tuning its self off
Every time i turn on my 5220 it powers up then shuts down the power suply fan runs but cpu fan cuts out and machine goes into kinda sleep mode
when i power it up and push delete and bring up the bios screen it runs fine till i xit it help please
  • 4 more comments
  • xtina ts Nov 09, 2008
    thanx il try that and get back to you
    christina x
    i wont thank you for helping a damsell in distress xxxx
    i love my 5220 with xp useing a friends pc with vista hate it with a pasion vista is a total nightmare cant do any thing with it
    i know that sweety but its my friends pc so dont want to mess around with it im lucky enough to have internet access via this one but she wants it back asap
    im doing as you said as we speak so hopfully it will work or its a new pc for me and as im kinda finatialy imbaresd at the mo ie skint im praying it works hugs tina xxx
    i hope so i have lots of discs
  • rsiday May 23, 2009
    i have exactly the same problem. i have swapped out the memory and reinstalled a fresh version of xp on a formatted h/d but it continues
    Not sure what else to try .... please help
I had the same problem; I put linux Kubuntu (a free operating system) and the problem stopped
Posted on Jan 15, 2009
    Sergeant:
    Champion:
  • 331 Answers
I think the problem  may be that your operating system  may have gone corrupt
try  to enter the Safe mode  (if you can )
and see if you can  revert back to old settings and whether it helps or not
else   you would have to
  reinstall the whole operating system
Posted on Nov 09, 2008
  • 3 more comments
  • Varun Kumar
    Varun Kumar Nov 09, 2008
    If it help  please dont forget to rate the solution
    thanks.
  • Varun Kumar
    And may I know the reason
    Miss
  • Varun Kumar
    Well you can certainly Install Windows Xp on  your system  .
    I am also using Xp it in not Mandatory to Upgrade to Vista
    and You can easily get windows Xp cd's to install the OS.
  • Varun Kumar
    You are reinstalling the Operating system
    now as  I say the reinstallation of the operating system  soles all the problems in one  go
    But just curious  and I hope you have
    All  the drivers required  for your computer.
  • Varun Kumar
    Ok
      Please do post if your EMachine start working.
My Desktop E-machine EL1331G-01w turned itsself off during an update and now it will not come back on, it powers on then goes back off after a matter 2-5 seconds. What causes this?
Have someone check the cooling fan for CPU and power supply. If the unit have a blown cooling fan on the CPU it will do as you described. Will also do the same if power supply is no good. Boot into safe mode and see if it still shuts down.
Jun 27, 2014 | eMachines EL1331G-01w -22344
Keeps powering off by it self
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Nov 27, 2012 | eMachines Computers & Internet
Emachines t5234
Nov 27, 2012 | E-Machines eMachines Desktop PC
My E machine 5220 keeps shutting down leaving just the amber light on the front of the tower lit.
eMachines are known to have cheap/bad power supplies.
If you have access to an extra good working supply you can disconnect the power supply from the computer with out removing it (unpluged of course), and connect your good one as a test.
Power supplies are very inexpensive off of sites like Newegg, Pricewatch, etc.
Do this right away.
You don't want a bad power supply to burn out your motherboard, and, or, CPU and end up costing you more to replace.
Also It could be possible something is overheating too and causing the machine to shut down.
Open the side panel and make sure the CPU fan is spinning freely when the power is on.
Some times what happens too is a machine can get so full of dust, dirt, and, or pet hair that the whole CPU fan and heat-sink get blocked so air can flow through and around them.
Jul 29, 2010 | E-Machines T1862 PC Desktop
Monitor cuts off
This could be the result of a few different things. If you haven't checked, click start, control panel, performance and maintenance, and power options. In this box, there should be numerous setting possibly pertaining to your specific problem. Also, ensure your cpu fan is running. A failed cpu fan will make your monitor turn off. Additionally you will have to make sure your power supply isn't bad. The easy fix is the first of the issues though.
May 26, 2010 | E-Machines eMachines Monitor E15T4
Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply: my cpu fan is running but at a low speed. When i t...
In my opinion you have a faulty power supply, replacing only the fan may not solve your problem. Try replacing the power supply.
May 16, 2010 | E-Machines Emachine T5026 power supply **...
No signal to monitor, fans run full speed
maybe your cpu is faulty or ... maybe power suply ??
Mar 31, 2009 | E-Machines W3107 (RBW3107) PC Desktop
Emachine heating issues
Hi rebecca_fran,
Well the system is shutting down for a reason but before you run off & buy a new CPU fan I want you to try something.
Unplug the power cord from the PC. Open your case & ground your self by simply touching any bare metal. (The bottom of the case will do).
Please remove the memory currently in your system. If you have never done this before please check within the manual for your eMachine. (There should be a section on how to install memory).
You can also click on this uTube link, it’s a bit long but you can skip through the video.
http://www.youtube.com/watch?v=SsXNT6fnHmM&feature=related
If you have some canned air blow out the memory slots.
(Do not place your fingers on the memory contacts at any time).
Re-seat the memory, firmly but gently. Leave the case opened & plug in the power cord. Turn on the PC. See if the fan runs & the system doe’s not shut down. If it still does replace the CPU fan.
Your PC uses an AMD Athlon 64 X2 4400+ / 2.3 GHz CPU.
Here is a replacement AMD CPU fan & assembly.
http://www.endpcnoise.com/cgi-bin/e/std/sku=dual_core_cpu_fan.html
The CPU will come with thermal tap on its underside. (No need to buy thermal grease).
(Make sure you remove the old thermal grease from the top of the CPU). Use a clean rag with a little alcohol on it. (Not dripping). Allow time for drying. Do not scratch the CPU surface.
Good luck rebecca_fran!
Mike
Nov 27, 2008 | E-Machines (BFB0505HA) Cooling Fan, Laptop...
About 2 weeks ago my sister's computer(emachines t3589) shut down I first thought that was the power supply,so I replaced it ,but the problem didn't go away,then I put the old power suply back on the...
The CPU fan is working?
The power button is working?
Did you connect the cables right?
If none of above fix your problem, seem to be a motherboard problem
Oct 04, 2008 | E-Machines Computers & Internet
Emachines 1900+ gets power to the monitor and computer but wont boot
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Desktop PC Logo
348 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
