How to open a terminal. (On my acer aspire one)
    Scholar:
  • 53 Answers
What do you mean by terminal?
Hyperterminal connection to a switch? - It's in Start - All programs - Accessories - Communications - Hyperteminal. You will need to know the com port number and associated other settings. Try 9600, 8, none, 1 with flow control None
A physical port on your laptop? - there are screws on the underside of the laptop that can be undone to reveal compartments, or flaps on the side of your laptop that can be simply undone by hand.
A remote desktop connection? - using microsoft terminal services connection. Click Start - Run then type mstsc and hit enter. Enter the IP address or host name of the system you want to connect to.
Posted on Nov 09, 2008
Forgot password for acer tablet/aspire one
The default root password for an Acer Aspire One running Linpus Lite is 111111
So open a terminal, and enter
Code: [Select]
and the password 111111 when asked.
your prompt should change from an $ to a #
If it's the user password you want to change, now enter:
Code: [Select]
you will be prompted for the new password twice
[END EDIT]
You'll need to get the into advanced mode - you'll see why once you've done it. To do this go to "Files" > "My Documents" to open the File Manager. Then go to "File" > "Terminal" (use the word menu at the top of the File Manager window.
Linpus Linux uses Xfce, so use "xfce-setting-show" to get the Xfce Settings Manager.
Click on "Desktop" to get to the "Desktop Preferences" and select the "Behavior" tab.
Now under "Menus" click the "Show desktop menu on right click" option and close the window.
This setting will allow you to bring up the normal desktop menu when you right click somewhere on the desktop. The Desktop Menu contains many more options than the limited user interface on the Aspire One.
OK. Now you're in advanced mode, right click somewhere on the desktop to bring up the menu. Go to "system" and then go to "terminal"
Once the terminal has opened type this:
Code: [Select]
sudo -su it will prompt you to enter a password. type this:
Code: [Select]
passwd It will now prompt you to enter your new root password (Just type it - you won't see anything appear but it's registering it).
You'll be happy to hear it asks you to repeat the password to make sure you were paying attention...
Note: That the password can be anything you want but needs to be longer than 6 characters.
Done!
Aug 07, 2014 | Acer Tablets & eReaders
I purchased an Acer Aspire AM3470G-UW10P.Hooked it up and it worked fine .Next morning the power light is on but the computer will not wake up.
remove it from power source,open up the casing and you will see a jumper with CLR CMOS.remove the jumper and replace it on the next terminal.wait a few seconds and return it to the normal position you found the jumper on.
power up your machine,you will have 2 reset the date and time after though.
good luck
Mar 28, 2013 | Acer Refurbished Black Aspire...
Reset bios on acer aspire e380
You can reset BIOS setting by CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battery, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will clear the BIOS setting. Now, fix the CMOS battery & restart the computer. This will take care of the issue.
If the computer still does not boot, then it needs repair.
Thanks and regards,
Jitha
Dec 16, 2011 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
My acer aspire one will not turn on
Please start by checking from the adapter, check the DC power output at the pin , if absent check the adapter. Also check the power at the battery terminals of the PC. if present and the battery seems to charge or hold charge then there are errors or failures on the main board as the PC needs to be opened and checked. Possible problems in the main board, CPU or sub power.
Mar 29, 2011 | Acer Aspire One PC Notebook
How can i unlock my acer aspire hdd (it demand a 8-digit password on startup)??
If you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battrey, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will clear the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Thanks and regards,
Jitha
Nov 28, 2010 | Acer Aspire 5315 Notebook
ACER default password for Bios
By default Acer wont enter any BIOS password however, if you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battrey, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Thanks and regards,
Jitha
Nov 24, 2010 | Acer Aspire 5920-6423 Notebook
I lost bios password of acer aspire 4520
Thanks and regards,
Jitha
Sep 20, 2010 | Acer Aspire 4520-5582 Notebook
Battery not charging on my acer aspire one
I had the same problem with my Aspire One in the past. When I would plug in my Aspire One it would not charge, but would emit a foul smell. I had to send mine to Acer. The problem was caused by a short in the charging terminal on the mother board. They replaced the mother board and since then my Aspire One has been running as good as ever.
Sep 25, 2009 | Acer Computer AOA150 Notebook
Acer Aspire one - network connection problems.
Open terminal, and type, server networking restart let me know if this solves it.
Feb 23, 2009 | Acer Aspire One PC Notebook
Acer aspire 5920 N
just turn it on it will boot through linux u will get the user login put root or username if created and password for that then it will go to graphical mode if u wan to shut down u will be having a option there only if there is no option just open terminal type init 0 command
init with Zero command or else say halt
Jul 22, 2008 | Acer Aspire 5920-6574 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
