I have a teac LCD221SD that is not turning on. Have bought off a family member. TV is getting power, and all plugs are in the correct places. Have tried pushing on/off button on unit and remote
  • Anonymous Nov 24, 2008
    i cant turn it on or use remote either whats wrong?
  • 3 Answers
The main power board is faulty and you need a new one.Mine was fixed under warranty twice and now it is out of warranty and has just died again.The repairer said it was common and to turn the tv off at the wall but it still died .He also said the tv was junk!
Posted on Apr 12, 2009
I want to turn my TV onto high definition for gaming. How do I do that. I have looked in the menu but cant see an option for the high definition. I just bought a Teac LEV32A1HD. Cheers.
Well, that depends on what you are using for your gaming. If you are using something like a Nintendo 3DS, a PS4, an Xbox One, an Xbox 360, or a PS3 there should be RCA connectors (3 - red, white, and yellow) or on the higher end consoles even an HDMI port, simply plug the cables into the corresponding female connectors on the console and on the back of your TEAC. If you have an HDMI output on your console, get an HDMI cable and plug that in (your TEAC has 3HDMI ports).
Once you have done this, take the TV remote and click "Setup." This will take you to the "Source" screen. In the 3rd section down, you should see HDMI1, HDMI2, HDMI3, and PC. The choice you make here depends on which HDMI port you used for gaming. Choose that one and click the "OK" button on your remote. If you hooked it up correctly, you should see something on the screen relating to your gaming console. If you do, then start playing your game!
If you don't want to or can't use the HDMI ports, your other option is to use the RCA ports. These are colored, usually, red, white, and a third color. Plug the red and white connectors into the corresponding connectors and place the last color (yellow, green, etc.) into the last connector. Follow the above Setup procedure except for choosing the Input. In this case, I believe you should choose the YPbPr input.
If you are using a computer for gaming, you must use an HDMI port. The Setup procedure is the same for setting up a gaming console.
Happy gaming!
Oct 17, 2014 | Audio Players & Recorders
TEAC AG-V1200 receiver won't auto turn on when
No. It won't automatically turn on when power is present.
Aug 08, 2011 | Teac Audio Players & Recorders
Remote won`t operate tv stuck on channel 99 w/ no signal showing
Some units have a little hole where you can insert a straightened paper clip and manually retract the DVD.
Make sure the power is turned off first.
"Your mileage may vary."
Jun 30, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
No manual cant get the digital side towork
email Teac at parts@teac.com and ask for the manual. There is a place where you can buy the pdf for $10 http://www.teac.owner-manuals.com/AGD9300-owners-manual-TEAC.html
Apr 24, 2009 | Televison & Video
I have a Teac LCD221SD, and the red light comes on, but when i try to turn it on, noting happens.A few ties it has come on, it turns offa second or two after..What should i do??
i had the same problem but seeing my machine was only 1 month old i took it in for warranty repair and the guy said hed seen it before with this model and said it was the capacitor fitted in when being made that was too small and they just replaced it with a bigger one
i dont see mto be able to get digital channels on it either??
NOW i have the problem with the aerial input not receiving a signal so again its back in the shop but i tell you what third time and its OUT it will be going BACK and next time i wont be such a tight wad
Nov 14, 2008 | Televison & Video
Hi, I bought a teac dvd and 5 speaker surround sound system yesterday. I am having trouble setting it up. I want to run the TV sound through it as well, but at the moment it is only going through the sub...
Whoa,ok.Sounds like things aren't connected properly.The first step is to disconnect the TV and concentrate on getting sound from a dvd or cd.Read the owners manual and double check that the speakers are hooked up correctly and that the unit is in the correct surround mode.Next, connect the TV.Use an RCA cable to go from an "Audio out" jack on the TV to an input jack on the Teac -e.g. "Aux, TV, etc.If your TV doesn't have the proper jack, I'm afraid you're out of luck.
Jul 21, 2008 | Teac Audio Players & Recorders
Powering up
It's most likely your hard drive. You can do it yourself and get the software and hard drive or buy a pre-configured kit.
It could be the power supply/motherboard.
It's extremely hard to say without seeing the unit in person. A great place to send it is CCS in Indiana. They'll test it and replace/upgrade the drive (if you choose that option).
Dec 26, 2007 | Tivo Series 2 80-Hours Video Recorder
NO POWER TO TV SET
I would change the fuse in the plug I see you are in australia and I do not know if your plugs are different over there, I can almost garuntee it is a fuse hope this helps
Apr 16, 2007 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
Televison & Video Logo
228 people viewed this question
Top Televison & Video Experts
