Question about Oregon Scientific VR368 Handheld Digital Voice Recorder
Oregon Scientific VR368 or equivalent
When I replaced the microphone batteries, one of the coils broke that holds the batteries in place. The microphone will not function even after I reinserted the coil to hold battery in place. I have important information already recorded that I must retieve. Please advise.
SOURCE: Oregon Scientific VR399 Handheld Digital
I have misplaced my driver also and my device is full of recordings I dont want to delete.
Posted on Apr 13, 2009
0 characters
1 Points
Olympus ws500m wont charge to computer
It's not supposed to. The WS-500m uses standard AA batteries, either disposables or rechargeables. If you want to use rechargeables, you must charge them outside the recorder using a separate battery charger.
Sep 15, 2012 | Olympus WS500M (2048 MB 5445 Hours)...
Screen shows ERR. I changed batteries and tried
You're right..This happens often when one changes the battery.Here's what to do :
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again.
Solution found at
Feb 01, 2010 | Olympus VN-4100PC Digital Voice Recorder
I need to record something with Dictaphone 3750 - I have no manual and there is just a Tel. Rec button. Help
If you press and hold the 'Conf' button, the machine will record using it's built-in mic (located on the right-hand side of the machine, closer to the front). It is probably recommended to get a microphone that plugs into the machine for better recording quality. Depending on what you're recording, you could get a handheld microphone or a telephone record adapter that plugs into your phone and the back of the 3750 (press and hold 'Tel Rec' to use that).
Aug 08, 2009 | Dictaphone 3740 Desktop Cassette...
Dowload in my computer
If your computer has an input on the sound card (Three holes coloured Yellow Blue & Green on lots of machines) then by purchasing a lead from Tandy or Radio Shack you can plug your cassette recorder in and record the contents to the hard drive as .wav files You will need a mini jack lug suitable for the output on your recorder and the same for the PC Windows has its own built in Sound Recorder software but there are better products on the market.
Jun 07, 2009 | Oregon Scientific VR636 Handheld Voice...
Hi i am trying to find and install the driver for my Oregon Scientific VR399 Handheld Digital on my windows Vista pc, can you help me, please thank you.
Oct 03, 2008 | Oregon Scientific VR399 Handheld Digital...
Oregon digial voice recorder VR636
I was looking online for the drivers too, but i couldn't find any...I did end up finding the original CD though, so I uploaded it in case anyone else needs it.
Oregon Scientific Voice Recorder Link for VR636
Note: I tested it on my XP and it worked perfectly, but I couldn't get it to work on my Vista. I probably won't hear from any of you again, but I hope you will return the favor by helping others. Thanks!
Jun 20, 2008 | Oregon Scientific VR636 Handheld Voice...
Sony IC Recorder ICD B600
To transfer recordings from the Sony ICD-B600 to Windows first buy a Radio Shack #42-2497 cable. Connect the cable from the recorder headphone jack to the computer microphone jack. In Windows XP follow the path: start, All Programs, Accessories, Entertainment, Sound Recorder. This small window will allow you to record 60 seconds of sound to a file. Get Article #82215 from the Microsoft web site. It will tell you how to make extended recordings. I was able to record 45 minutes continuously. The recorder is turned on by moving the 'HOLD' switch down. The recorder is turned off by moving the 'HOLD' switch up and waiting 2.5 seconds. Have fun.
May 08, 2008 | Sony ICD-B200 Digital Voice Recorder
Oregon Scientific VR368 Handheld Digital Voice Recorder Logo
19 people viewed this question
Top Oregon Scientific Voice Recorders Experts
David Burkhart
David Burkhart
Are you an Oregon Scientific Voice Recorder Expert? Answer questions, earn points and help others
