Question about Sony Ericsson W200i Cellular Phone
About- infrared connect with my pc
Hello sir,
presently i am using k22oi hand set of sony i don't about infrared and i want to transffer camera photoes in my pc, so tell me how can connect and transffer from my set.....
thanks
    Brigadier General:
  • 7,752 Answers
You need to install........the pc suite software and following the instructions
Posted on Dec 28, 2008
I have synced my controllers, both wired and wireless, but they are not connecting. I have heard about a gel I can use to make the connection better. Is this true?
Hello carolinemacl,
I'd imagine a gel would not help a controller at all to connect to a console. I've heard of Silica Gel Packs to help soak up moisture from the controller, that is if it got wet, and circuits shortening. Infrared remotes (I don't know if Xbox is an IR remote,) use infrared rays to send and receive messages. Infrared rays will transmit a gel filter. It's a hard question to answer.
If you have any other questions or concerns, feel free to contact me.
Aug 27, 2011 | Microsoft Xbox 360 Controller
T.v. does not respond to remote control, but does work maually from side buttons
Turn tv on manually.Test the remote control all functions are dead or some functions work other don't?Tries take the remote control parts and clean the inner rubbers buttons between the rubbers insulater and the remote circuitries board and the battery connections + - connections with some rubbing alchahol.Then wait awhile like 20 mins and putting it back together again and putting in new battery in the remote,it might work again.If getting the same result than the remote CPU chip is probally dead,remote control devices are very depended on it CPU chip.Try website like Remotes.com to buy an original remote for the replacement.
Mar 24, 2011 | Vizio 42 in. LCD TV
I have a sony Bravia KLV-S40A10E 4 years old.Remote controle device is no ore working. Batteries have been changed without solving the problem .. Other Remote device ( DVD-Sony ) is also not working...
Hello
You just check your remote control handset for its infrared emission. There is an infrared light emitting diode [LED], in front of your remote control handset from which infrared light rays are send to your TVs infrared sensor, fitted inside it, behind the infrared window on its front panel. Infrared rays are invisible to human eye. We can check if it is there by using a cellphone with camera option.
Put the cellphone in camera mode, and place your remote control's LED side towards its lens, for about a feet away or so, and when you push its each button, you can see an image in the phones' screen. If it is there, and still your TV don't work with remote control, TVs infrared sensor inside is faulty, and needs replacement.
If there is no infrared image from your remote control, you have to buy one new remote control. OK.
Dec 18, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
How to connect moto z3 to internet to use in laptop..
Hello, motorola phone pc suite or phone tools software no longer works for using net from mobile. It may better to use bluetooth dongle to connect net. Just purchase a bluetooth dongle then install driver n on your phone's bluetooth and connect it with dongle select PAN connection if possible otherwise make dial up connection. This will surely work
Hope this will solve your problem...
Jul 24, 2010 | Motorola Mobility MOTORIZR Z3 Cellular...
How to use infrared port in sony ericssion k220i . what is main use of infrared port. what can i do using this facility?
The infrared port is by the left side of the phone, it is along the line that splits the front and the back of the phone. It is mostly covered by a thick red glass or plastic.
Infrared is a device on a phone that allows you to send and receive file using the infrared radiation wireless wave. It works like a bluetooth device, just that it must be placed close to the infrared port of the phone that is sending or receiving files from. You cannot send or receive files that does not have infrared using your own infrared.
Infrared can be used to send and receive files (data, song, pictures, videos etc).
To use the infrared of the sony ericsson K220i, you have to go to your phone 'menu', go to the 'settings', select the 'connectivity', then you select the 'infrared', turn it 'on', when you are to receive a file, you place your phone close to the sending devices infrared port. Also when receiving a file, you do the same.
When you want to send a file through infrared, you go to the file you want to send, you select the option, select send from the option, a pop up blog will come up asking you how you want to send the file, you select via infrared and your infrared will come on, the device you are sending it to would have its infrared turned on as well. The infrared ports must be placed close to themselves before the files can be sent.
Take care
Jun 25, 2010 | Sony Ericsson Cell Phones
I want to purchase a laptop printer Canon bjc 80 will it connect to my vaio via the usb or whatever the 15 pin plug is on the left hand side
According to the specs this printer uses IEEE 1284 connection which is infrared. So you would have to have an infrared receiver/transceiver on your laptop or purchase and install one. In other words this printer does not connect directly to your USB port or your Paralell Port.
Mar 27, 2010 | Sony VAIO PCG-K35 Notebook
Why does the camera trun off when i hook it up to
the thing that you experienced on your camera Is normal. It will turn off because when you connect the camera on your computer it will be ready for transffering your picture. Most of the kodak digital camera will shuts off when connecting to computer its either to charged the battery or transffer picture.
By the way your camera will not be charged using the USB cable it will just transffer the picture., Gudluck!
Nov 08, 2009 | Kodak EasyShare C713 Digital Camera
Sir, I have digital video camera recorder DCR-TRV265E PAL. How can i Download my saved video on my pc ?kevin<<<>
hello kevin. you will need the usb cord that came with your camera. if you don 't have one take your camera to walmart and get the connection cord. then hook the camera up to the computer and click on my computer where you will find the camera listed. click on that and you can download.
Oct 26, 2009 | E.Digital Sony DCR-TRV265E camcorder Pal
Softwere instllatin in sony ercsson w550i
Installation instructions
  • Download the file to a temporary folder on your PC.
  • It is recommended to uninstall any previously installed version of Sony Ericsson PC Suite
  • Execute the downloaded file.
  • If updating to a newer version of the Sony Ericsson PC Suite, a restart of the PC may be required after the new installation is completed.
How to use
  • Connect the mobile phone to your PC using an applicable connection: Cable, Infrared or Bluetooth connection.
  • Start the included programs from the Start/Programs/Sony Ericsson folder or the Application Launcher application
try it
Sep 07, 2008 | Sony Ericsson W550i Cellular Phone
Infrared port sony ericsson k220i
you will need a usb cable for the sony ericsson to connect to the computer and the pc suite software to transfer the picz to the pc.
Jul 04, 2008 | Sony Ericsson W200i Cellular Phone
Sony Ericsson W200i Cellular Phone Logo
48 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
