Question about Toshiba TZ55V61 55" Rear Projection Television
Power problem My Toshiba powers off by itself. The red light beside the power switch begins flashing. I must unplug the set, then plug back in. The set comes on momentarily, shuts down again and the red light begins to flash again. I have tried letting the set remain unplugged overnight with same results. I actually let it set for about a month, took it to a repairman, he found nothing wrong. Took it home, plugged it in, watched a video, went to use it the next morning...same old problem.
  • Anonymous Nov 22, 2007
    My Toshiba (purchased Jan 01) powers off by itself. The red light beside the power switch begins flashing. I must unplug the set, then plug back in. The set comes on momentarily, shuts down again and the red light begins to flash again. I am letting the set remain unplugged for 30 mins then comes back on. What could be the possible causes. Is it an easy repair
    Genius:
  • 1,694 Answers
1)all TV's I service get the chassis pulled for good visual inspection and soldering any/all suspect connections,esp. any
active device mounted to a heatsink.
2)Check horiz drive circuit for weak capacitor.
3)Let me know if you are still on it.....T.
Posted on Oct 23, 2007
I have a toshiba tp55h60, power light is flashing
I have the parts you need if interested. Email me at hill6399 at yahoo.
Oct 30, 2009 | Toshiba TP55H60 55" Rear Projection...
Toshiba 50hp95 will not respond and has flashing red power light. It seems many people have this problem, what's the solution? We have tried all the Toshiba suggestions.
My 50hp95 had the same problem; the red power light is flashing and the tv will not turn on. I unplug the power and plug it back in and the TV clicks, but the power light continues to flash red. My problem was a bad Seine module which you can bypass if you do not need to watch HD off air programming. Since I get my HD from the cable, I can bypass it. All you need to do is remove the back panel from the TV (unplug the TV first) and on the main circuit board unplug the white connector labeled PJ63A. The main circuit board is the one in the center of the TV and the PJ63A connector is the bottom white connector on the left side of the main circuit board (the label is printed in white on the circuit board under the connector). Once I plugged the TV back in it worked immediately.
Sep 09, 2009 | Toshiba 50HP95 50 in. Plasma Television
The tv suddenly shuts off
flyback on the verge of giveing out on you.. needs a new flyback..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 21, 2009 | Toshiba CF36G40 36" TV
Toshiba tv will not turn on
I have a toshiba tv and it will not turn on. There is a flashing green light that comes on, but there is no picture or sound.
Oct 31, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
No video, shuts off then back on
I checked Toshiba's website and found the manual for the set. The self restarting was indicitive of a lamp failure. The red light was solid while the green light blinked. It would then restart 8 times before both lights would then begin blinking.
Sep 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Flashing Power Light
Toshiba rear projection with blinking LED =
1) Open micro fuse F850,851,etc....caused by
2) Bad solder connects....jumper wires 008,010,017,048,600
re-solder all and solder STK392-110 convergence amp pins.
3) Or consider replacing original IC's with improved version...
STK394-160 = Hitachi part # CZ 01341
.........................T.
Aug 30, 2006 | Toshiba 53H71 53 in. Rear Projection...
Open Questions:
Toshiba TZ55V61 55" Rear Projection Television Logo
257 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
