Please advice me as soon as uyou can ..thx
I have a problem with fasteathernet port in my cisco router ,which that i have high INPUT ERRORS wh i used " sh int " command i want to know what is that refer to ?
the following what is apper :
FastEthernet0/0 is up, line protocol is up
Hardware is Gt96k FE, address is 0016.9da3.08f2 (bia 0016.9da3.08f2)
Description: $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
Internet address is 10.18.1.2/16
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 4d18h
Input queue: 0/75/240/0 (size/max/drops/flushes); Total output drops: 168358
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 50000 bits/sec, 36 packets/sec
5 minute output rate 54000 bits/sec, 32 packets/sec
40309846 packets input, 3202249187 bytes
Received 650225 broadcasts, 0 runts, 0 giants, 1 throttles
202461 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
0 input packets with dribble condition detected
4661712 packets output, 2311390016 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier
0 output buffer failures, 0 output buffers swapped out
    Scholar:
  • 58 Answers
Start troubleshooting the problem by checking the physical layer (Plugs, Jacks, Cables). Replace them with known working equipment.
Once you have traced the line from your Cisco to each other end (through to ISP, and to network switch), then reset your error counters, by restarting the cisco.
Check the ethernet interfaces on the network switch and the Cisco. Make sure they are both set to Autonegotiate or both set to the same settings like 100mbs Full-duplex. If they are not communicating the same way lots of errors will be generated.
Posted on Nov 11, 2008
Greetings i am using a cisco adsl 2 wireless modem router,what do i need to get to upgrade from a 4 port TRENDnet TE100-S55E switch to a 12 port TRENDnet patch panel,I need advice on what type of chal
Keep your 4-port and just purchase a netgear or linksys 8-port switch. This will increase your port count to 12, but you burn two ports on uplinking. If you need more ports, just get a 16-port switch then. I believe this will be the most cost effective solution.
May 15, 2014 | Cisco Catalyst 4006 Chassis ( 4006)
Tip
877 router factory reset woes
Question:<br> We've recently changed <a href="http://www.3anetwork.com/cisco-c2951-vsec-sre/k9-price_p267.html"><b>C2951-VSEC </b></a>data line providers and now have some Cisco 877 routers we'd like to reconfigure and use at other sites. Although we own these, they were configured by our old data line providers, I'm having a hard time of resetting them to factory defaults and am after some advice.<br> The simple, hold down the reset button until it restarts does not work.<br> If I press the reset button within 5 seconds of power up to load the default rom image, I get the below:<br> System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE<br> Technical Support: http://www.cisco.com/techsupport<br> Copyright (c) 2006 by cisco Systems, Inc.<br> C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory<br> Booting flash:c870-advipservicesk9-mz.124-24.T.bin<br> Error opening: flash:c870-advipservicesk9-mz.124-24.T.bin<br> System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE<br> Technical Support: http://www.cisco.com/techsupport<br> Copyright (c) 2006 by cisco Systems, Inc.<br> C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory<br> Booting flash:/c870-advsecurityk9-mz.124-24.T6.bin<br> Self decompressing the image : ############################################################################## [OK]<br> I assume from this the required bin has either been removed, renamed or overwritten.<br> As soon as the router boots it requires a password and I dont have the password to be able ftp files in and out of it.<br> Hope you guys can help.<br> Answer: <br> this should work indeed.<br> take a look here:http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml <a href="http://www.3anetwork.com/cisco-cisco3925/k9-price_p284.html"><b>Cisco 3925</b></a>
on Aug 28, 2013 | Computers & Internet
Tip
Popular Cisco 1900 Series Routers Including Cisco 1941/K9, Sepcial for Mother's...
Cisco 1900 router series including CISCO1941/K9, C1941-SEC-SRE/K9, CISCO1941-SEC/K9, CISCO1941W-A/K9, CISCO1941W-E/K9, etc. are designed for small office and small enterprise branch offices, delivering high-performance, highly secure connectivity with multiservice integration that can transform the workplace with a broad set of services, rich-media support, and operational excellence.
Key features of Cisco 1900 series in detials:High Perfomance: Cisco 1900 series routers offer significant performance improvements over previous-generation ISRs such as 1800 series.
Investment Protection: Cisco router 1900 Series reduces deployment costs and increases flexibility. The platform also offers investment protection with support for a majority of existing WICs and HWICs.
Services On-Demand: The Cisco 1900 Series Integrated Services Routers reduce total cost of ownership by decoupling the delivery of software from hardware on optional service modules. In addition, you receive a Universal IOS image capable of enabling all of Cisco's rich IOS features and allowing you to quickly deploy new services.
Energy Efficiency: The Cisco 1900 Series architecture incorporates higher-efficiency power supplies with intelligent power management.
Specifiction of Cisco Router 1900 series:* Embedded hardware-accelerated VPN encryption.* Secure collaborative communications with Group Encrypted Transport VPN, Dynamic Multipoint VPN, or Enhanced Easy VPN.* Integrated threat control using Cisco IOS Firewall, Cisco IOS Zone-Based Firewall, Cisco IOS IPS, and Cisco IOS Content Filtering.* Identity management that uses authentication, authorization, and accounting (AAA), and public key infrastructure.* 2 Integrated 10/100/1000 Ethernet ports.* 2 enhanced High-Speed WAN Interface Card slots that can host 2 single wide or 1 double wide and 1 single wide (e)HWIC.* Fully integrated power distribution to modules supporting 802.3af Power over Ethernet (PoE) and Cisco Enhanced PoE.
Overall, Cisco 1900 Series Routers offer unparalleled total cost of ownership savings and network agility through the intelligent integration of security, wireless, and application services.
After knowing more information about Cisco router 1900 series, it's nice choice for you to select one of Cisco 1900 series that meet yor need in net to net.Why not choose? More tips about Cisco products and other Cisco network equipments you can visit here: http://www.router-switch.com/Price-cisco-routers-cisco-router-1900-series_c16
on May 05, 2011 | Computers & Internet
Setup ea4500 router
You must use your Cisco Connect CD Install, this runs a wizard, otherwise you need to know default IP address, administrator password and some other data.
Please check your prouct home page at: http://homesupport.cisco.com/en-us/support/routers/EA4500
Sep 17, 2012 | Linksys EA4500 Dual-Band N900 Router with...
I have tried connecting Cisco linksys router but it gives ERROR 322 NEW ROUTER OR GATEWAY NOT DETECTED...How can I solve this problem please advice
Use an Ethernet cable to connect from the network-port on your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see output like:
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
if the router has self-configured, and is ready for "wired" usage.
Then, start Internet Explorer.
Type http://192.168.1.1
Press Enter
Login to the web-server "inside" the router
Click to run the "Wireless Networking Setup Wizard" to configure it for "wireless" usage.
Feb 21, 2011 | Cisco Linksys Wireless N Home Router...
Can not login on con 0 port (not text), lost
default username and password for all router are
admin and admin
or
admin and password
try these two combinations
else try link
http://www.cisco.com/en/US/products/ps6187/index.html
Oct 03, 2009 | Cisco 1811 Router
Cisco 2900xl switch - can't type anything in console?
Please try using Hyperterminal, it's in accessories> communications>
Use com port and click on "restore default" on next window and then ok. Then try typing it will probably work.
The console port is fine as you can see all the outputs coming from there.
Try changing the settings in putty under keyboard, make sure the bit rate selected is 9600bps.
Regards,
Harshit
Jan 19, 2009 | Cisco Catalyst 2908 (WS-C2908-XL)...
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
