Question about Canon PC-D320 Copier
Delayed printing When making copies, they scan at normal speed, but the printing is delayed. This just recently started occuring and it seems as though it is taking longer to print each time. What could be the cause of this?
  • 69 Answers
Not enough Memory
Posted on Sep 21, 2007
Delayed start 2005 3.6l
Just replaced fuel filter, all injectors, plugs and compute ?????? Why did you replace all these thing's ????? Did you have the computer programmed ?
Feb 16, 2018 | 2005 Cadillac SRX V6
Tip
Incorrect paper size while copy in progress for Canon iR2016 series.
Regarding pick-up error "change paper size"or "incorrect paper size" while copy/print:
These may do the trick:
Point of problem:
Paper Pick-Up Assembly
Problem:
Prevention of incorrect Paper Size Error or Pickup Assmbly Delay Jam (0104) upon Cassette Pick-up
Behaviour of copier:
When making a pick-up setting as from the Cassette and starting Copy, "incorrect paper size" error or pick-up delay
jam (0104) may occur.
Possible reason:
When considerable amount of Paper Lint is attached onto the Vertical Path Roller , the feeding power is
undermined and the paper feeding is delayed, resulting in "incorrect paper size" error or "pickup assembly delay"
jam.
Servicing work:
When the foregoing symptom occurs, be sure to replace the 27T/50T Gear [old type] with the 33T/50T Gear [new
type] and the 29T Gear with the new type simultaneously.
Affected machines are:
iR2016J 120V KQW00838 and later iR2020 230V KRS02060 and later
iR2016J EUR 230V KQX19105 and later iR2020i 120V SRB03779 and later
iR2016J 230V KQY08575 and later iR2020i EUR 230V SRC03634 and later
iR2016 EUR 230V KRB61503 and later iR2020i 230V SRE00245 and later
iR2016J EUR 230V TXK10815 and later iR2016i 120V SRH01205 and later
iR2016 120V KRE05112 and later iR2016i EUR 230V SRJ04494 and later
iR2016 230V KRJ07227 and later iR2016i 230V SRL00298 and later
iR2020J 230V KRM01592 and later
iR2020 EUR 230V KRP16433 and later
iR2020 120V KRR07615 and later
on Apr 12, 2011 | Office Equipment & Supplies
Intermittent electric problem
Have you had your alternator tested recently? some newer vehicles will have electronic issues if the alternator is going bad.
Dec 07, 2013 | 2002 Ford Taurus
Sony CCP1300 Cassette Duplicator delayed start on B side in A+B recording.
The delay allows for the leader to pass the record head until modulation (sound) is detected. This is a normal design feature
Jun 18, 2012 | Sony CCP1300 Monaural 1-to-3 16x Master...
Hiii... I am having a 500 G.B. external hard disk. whenever i want to perform any operation on it such as "Copy to PC" or "Copy From PC"... it displays an error message after some time...
This is Microsoft's answer to this problem.
This error typically occurs when the "Enable write caching on the disk" feature for your hard disk is turned on.
However, if the "Enable write caching on the disk" feature is turned off, this error can occur because the Ultra Direct Memory Access (UDMA) hard disk controller may be configured in either of the following ways:
  • You are using a 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
  • The BIOS settings are configured to force faster UDMA modes.
For more information about the delayed write failure, go to the "Delayed Write Failure information" section.
Jan 21, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I am retired from25 yrs as aoto tech. I used to enter diagnostics on Caddis by pushing off and warmer at same time. will a 97 deville work with same procedures through the AC controls? Family member has...
delayed ignition ?? (meaning no spark when first cranking over)
or delayed starting
if delayed spark -electrical problem -check Ignition module and wiring
if delayed starting (spark ok) i'd check is Fuel rest pressure And Fuel pump relay
Does fuel pump cycle when ignition is turned on
meaning engine starts when oil pressure activates pump
Mar 17, 2010 | 1995 Cadillac DeVille
Mouse is glitchy
I would recomend a RAM upgrade, That speeds up the reaction time of your computer
Jan 11, 2009 | Dell Inspiron E1705 Notebook
WORKCENTRE PE220 - How do I print reports from the fax? and I want to set it up to do automatically, but I also need to look at a certain day, to see if a fax went through. Thanks
Hope this helps.
  1. Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
Report / List Description Phonebook List This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers.
NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
Sent Fax Report This report shows information on recently sent faxes. System Data List This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified. Scheduled Job Information This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax. Message Confirmation This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job. Junk Fax Number List This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID. Multi-communication Report This report is automatically printed after sending documents from more than one location. Power Failure Report This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure. elem_1_spacer.gif
Jul 23, 2008 | Xerox Office Equipment & Supplies
Canon PC-D320 Copier Logo
65 people viewed this question
Clive
Clive
old marine
old marine
