Question about Bose SoundDock Digital Music System for Apple iPod - White
Bose soundock i had no problem with my soundock until i turned it off at the wall. It was turned off for about 4 days. When i turned it back on the i-pod would not play through it, but was fine through the headphones.The dock is about 3 years old and has never had an issue. I know power is passing through it and through to the pod, and i have checked the circuit boards for any scoring but they LOOK fine.         Any help with this would be greatly appreciated. Thanks for your time  Beau
    Sergeant:
  • 306 Answers
U need to Check  the power supply is providing +18 VDC and -18VDC.
If  it is  then open the sounddock and examine the power supply connector....very very closely.
The power connector had intermittent connection to the sound dock circuit board. Looking closely (mangifing glass) you might see cracks in the solder around the connector pins. This is a cold solder agravated by rough handing of the power cord. Resolder the pins on the connector on the bottom side of the board. Make sure the solder flows around the pin and through the board. else i suppose  its a problems with the port that plugs into the ipod.
Posted on Nov 09, 2008
Bose soundock 10
You want to plug the SoundDock into a 220 receptacle, is that correct, and the Soundock works off of 120v., correct. I tried to find the specs for the Bose SoundDock, i.e. its wattage rating but it seems that Bose does not publish these specs. At any rate a 220v to 120 v converter should work
The 300 watt converter listed above should work fine. Wahtever converter you use, make sure it operates at 60/50 hz.
May 19, 2014 | BOSE(R) SoundDock 10 Bluetooth dock...
Http owners bose com
Remove preconfigured bluetooth and repair.
May 02, 2014 | Audio Players & Recorders
How Do I fix My I Pod Which Is Disabled
First make sure the battery has some charge by using a wall plugin. Then try resetting it by holding down the power button and home/middle button at the same time until it turns off. It should automatically start back up again.
Aug 06, 2012 | Audio Players & Recorders
Sticky volume control when turning up and down
The volume control needs a good flush out, take the unit apart to expose volume control pod, buy some electronic contact cleaner and flush the pod while turning the volume back and forth, repeat 2 or 3 times. Note some pods have small slot where you can spray.
Mar 08, 2012 | Audio Players & Recorders
I have a BOSE soundock portable and I have to replace my connector at the end of the power supply.What is the size of the connector.
Bose uses a proprietary connector for their power supply. Your best bet would be to purchase one, for example at this site: http://www.frontrowelectronics.com/bose-power-supply-sounddock-series-1-white.aspx?utm_source=googleBase&utm_medium=referal&utm_campaign=Bose
The four pin connector is not standard and cannot be found in stores such as Radio Shack, etc.
Mar 07, 2011 | Bose SoundDock Portable Digital Music...
Connector on the back of my Bose sounddock came out.....now what?
Take the sound processor board out and sens it to the guys at www.invebo.com they change the connector for 16 Euros. It takes a couple of days. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Jun 26, 2010 | Bose SoundDock Digital Music System for...
Bose sounddock not giving any sound. Ipod working fine through earplugs. Unhooked soundock for travel, now no sound. Tried all the resets, etc. Also, new battery in remote and it doesn't respond either????
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Jun 07, 2010 | Bose SoundDock digital music system...
Female plug for i pod came off on 282490-001 board need new board
Don't bother doing it yourself, Bose has excellent customer service.
support@bose.com
1-877-210-3782.
Mar 18, 2010 | Bose SoundDock Digital Music System for...
Bose SoundDock Digital Music System for Apple iPod - White Logo
110 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
