Question about Brother MFC-5440CN All-In-One InkJet Printer
Brother MFC-5440CN Printer Problem
My Brother MFC 5440CN prints 2 lines down every page when autofeeding to make copies. I tried cleaning everything, changing ink cartridges... The machine is less than a year old.
  • 2 more comments
  • Anonymous Feb 12, 2008
    Mergatroid had the solution to multiple streaks when using the document feeder. Cleaned the small strip of glass and Viola! no more streaks.
    Thanks for the solution.
  • Anonymous Mar 23, 2014
    I have a Brother MFC-J615W all-in-one printer and everything prints out in Blue, what's wrong?
    replaced drum, cleaned all rollers, cleaned glass including small one on the side. Still every time I scan I have three lines down page. I am very frustrated. Bad thing is my husband's machine which is the same as mine and both bought at the same time and his is doing same thing.
  • Anonymous Mar 24, 2014
    how do i make photocopies on the brother MFC-685cw machine?
  • 286 Answers
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Posted on Dec 30, 2007
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
My printer wont print even after changing ink and cleaning
When cleaning doesn't help, you need a new printhead. Around $89.00 now and then you add labor. They sell a new MFC 490 for around $120.00 with a year warranty.
Jul 01, 2009 | Brother MFC-3240C All-In-One InkJet...
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Brother mfc-5440cn
The cartridge has no chip to reset. I'm guessing that the problem might be the printer. Have you tried turning off the printer for about 30 seconds? If this didn't work try turning it off and unplugging the usb and power for 30 seconds. This is to reset the printer to recognize a full cartridge. If this doesn't work, did you put the cartridge in the correct position? Is it aligned correctly? Hope this helps.
Jul 24, 2008 | Brother MFC-5440CN All-In-One InkJet...
Remove mfc 5440cn print head
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 30, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother mfc MFC-5440CN magenta issues
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
Can't print documents from Word.
Did you do a test print by pressing ink testprint etc.? Do you have all colors incl. BK? If yes, check the printersetting WITHIN Word. Is the mfc the printer to be recognized by Word or is it another one? If you miss the bk upon the test sheet try to clean the ink cart by help of pressing ink arrow-down-button (cleaning) and (blue) start mono. If there is no or not enough ink check the cart. In case you use third party ones, use an original brother cart and do the cleaning twice. Third party carts do make a lot of trouble due to malconstruction!
Oct 10, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
220 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
