Toshibas rear projection model 50WT29B rolling or no picture
Hi William, I've had this great TV for 6 years now and its been excellent. Its just started to have problems with the video input side of the TV and sometimes there will be no picture, sometimes the picture is scrolling from left to right whilst rolling as well. If I let it cool down for 10 mins and switch it on then it works fine for a period of time (Which is random) then something starts to break down again. I've ordered a 60" LG plasma to replace it but if possible I would like to repair it and donate it to my local primary school for their useage. I've contacted you as you look to be the right guy for sorting these out, but maybe a little to far away for a site visit.
Tony Powell, Wales in the UK
  • MrPow Nov 10, 2008
    Hi William
    The model number is in the title its a Toshiba 50WT29B. I used to build and sell PC's in the past so I'm aware of PCB's suffering from heat problems with spot soldering cracks. The only problem is where to start lol.
    Just to recap its fine when cold but after a couple of mins starts to fail.
    Thanks for your help and time mate.
I have a toshiba 50wt29b rear projection tv,one day it just lost the picture when i was watching it the sound is fine but no picture or any type of light coming out of the bulbs,any one got any ideas?
Posted on May 22, 2011
  • 934 Answers
From what you're describing it sounds like ring-cracked solder joints or maybe a couple of failed caps. What's the model number???
Ring cracks happen because a component on the board gets hot and cools many thousands of times over the life of the Tv and the extreme heat causes the solder to crystal and break leaving the smallest of rings around where the coponent would otherwise firmly be soldered, breaking contact with the board. The other possibility is one or more electrolytic capacitors measure high equivilent series resistance and take more time (thus heat) to reach an operating temp sufficient to dissipate voltage at a correct rate.
Drop me a post and let me know what the model number is and I can look it up for common problems in the schematics and service manual.
BTW: Uk is a bit beyond my normal servicing route... :)
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
Posted on Nov 10, 2008
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
Bright blue concave archs accross top of the screen with some yellowish ghosts on any lettering accross bottom of screen. This is a hitachi model 53fdx01b rear projection tv that normally has an excellant...
Sounds like a convergence failure, here is a tutorial I made:
Let me know if I can be of further assistance.
Sep 09, 2010 | Hitachi 53FDX01B 53" Rear Projection...
My toshiba TP50H15 color tv comes on then off and the light blink
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110.  Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
If you would like further help with this please post a comment back here.
Dec 05, 2009 | Toshiba TP50H50 50" Rear Projection...
I have a problem with a very shaky picture on my TOSHIBA rear projection TV model 42h83 I have tried the touch focus, all I really get is two horizontal lines of each color (RGB) they roll top to bottom...
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
Hope this helps :)
Sep 17, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Feb 05, 2009 | Toshiba 40H80 40" Rear Projection...
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Age of tv?
I purchased mine from Circuit city back in spring of 2002 as a display model that they were no longer selling. So I would assume 2001 which would be almost 8 years old. Excellent tv!
Nov 03, 2008 | Hitachi 53FDX20B 53" Rear Projection...
TV screen jumps and rolls, sometimes won't stay on
Try Re-soldering the vertical yoke connection and the vertical output IC. Thats a common problem in that model.
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Hitachi Projection on/off problem
Tell me what it does when you try turning it on...accordianman
Feb 17, 2008 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
