Question about Philips Magnavox DVD/VCR Dual Player
Player unable to load discs when inserted
I have got a LG DVD/VCD/CD player which upon inserting the discs takes too long to load and at times click noises are heard and eventually does not load some discs at all especially the DVDs. The CD VCD discs are loaded quite fast.
Please assist me on how i can solve this problem for me to enjoy the full services of the disc player.
My e - mail is mwangi_macharia@yahoo.ca
    Problem Solver:
  • 6 Answers
Http://forum.videohelp.com/topic350059.html
I think I found these adjustments! There are two tiny surface-mount potentiometers (could be capacitors also) sitting in the small circuit on laser assembly.
this is exactly response I would like to hear - an expert opinion!
What I did with help of 1mm-wide screwdriver:
1) There were two surface-mount potentiometers marked with C1 and D. I tried first D. Turned it clock- and counterclockwise by about 45 degrees.
2) After each turn I opened and closed tray to force the player read DVD disc.
3) It did not help, "NO DISC", then I tried the same with C1, and again, no luck.
4) Finally, I came back to D and turned it by about 180 degrees in one direction. IT WORKED!!!
Moreover, seem that now player reads content of the DVD discs faster then before. Probably manufacturer did not really adjust it properly and upon the time something has degraded, so it failed eventually.
Posted on Nov 27, 2008
How to repair dvd player v zon says wrong disc
Hi Vzon DVD Player,
Before you fix anything, you need to troubleshoot the problem first to know what needs fixing. Since DVD players can play different kind of media formats like Audio CD, VCD, mp3, etc, please try the following
1. Turn on the DVD player and set the program to DVD. some player needs to be setup due to multiple functionality (can play mp3 on flash drive, etc..)
2. insert different Media CD as mentioned above if your player will play them. (if they play, try to insert the DVD you want to play)
3. Try different DVD disc
4. If all the above don't work, try to clean the laser head using the standard disc cleaner.
5. retry the DVD disc
6. If the player still don't play your DVD, probable issue would be the laser head or the disc motor.
7. Please bring them to you nearest Electronic repair shop for further assessment.
Good luck and thanks!
Aug 20, 2011 | Coby TF-DVD7107 Portable DVD Player
My lg bd50 is able to play any normal dvds however it is unable to play any bluyray dvds!!! when a blueray is loaded into the machine you cannot even eject the disc for sometime. i downloaded updates to...
hi,
blue ray players takes one to two minute to read the content. it will not read as fater as dvd. give some time and then find out what the player says. error or no disc. also check ur BD's region and the region of the disc u inserted. BD's comes with only one region.
ok
Dec 17, 2010 | LG BD350 Blu-Ray Player
ONIDA DFX-7100 DVD player unable to play VCD/CD
dvd player s-video pin use to tv tuner card
May 18, 2010 | Televison & Video
Jvc dvd XV-N322S REGION CODE-2 is showing 'NO FILE'
It's a software problem pls upgrade ur dvd player.ur problem will be solved
May 11, 2009 | JVC XV-N322 DVD Player
How to unlock LG dvd/vcr model no/ v782w
try that:
  1. Power on (with no disc inserted)
  2. Press PAUSE
  3. Press 3, 1, 4, 1, 5, 9
  4. Enter the desired RC
  5. Press PAUSE
  6. Turn the player off and wait a few seconds
  1. VCD playback
  2. Press PAUSE, 1, 4, 7, 2
  3. Press UP 6 times, '07 00' should appear on the display
  4. Press Program 6, Program 5 ('07 FE' should be displayed)
  5. Press ENTER
  6. Press RETURN
  7. Power off and on again
Dec 28, 2008 | LG V181 DVD Player/VCR
LG RC797T Region Unlocking Codes
Purchased two of these VCR/DVD recorders (for the ATSC-digital tuner) in March 2007 at Best Buy. They play PAL/region 0 out of the box. To enable region-free playback I used the CD-ROM previously made for my LG LST-3510A. Visit this link for the files to burn your disc:
http://aiwaownersnetwork.tripod.com/pages/lg/5000_series_firmware.html
Next:
--Power on the player and load the CD-ROM
--In a few moments a text box appears displaying current DVD region and a second line to change DVD region
--Press the number you wish (most likely "0") on the remote control
--Press "Enter" on the remote control
--In a few seconds the player will eject the disc. Remove the CD-ROM from the tray and power off
Upon powering on the player my region 2 and 4 DVD's play fine but Macrovision still remains.
OR
Click the HOME button on the remote with the unit in 480i resolution
Click the setup page
Click Start
Click TV Aspect
highlight the 16x9 wide aspect ratio
enter on remote control this coded sequence:
1397139
Edit specific "Options"
Option 2: 35 (enables Divx/Xvid playback)
Option 4: ff (enables Vcd and SVCD playback)
Option 5: ff (enables region free playback (region 0) DVD playback)
Option 6: ce (enables Insignia brand startup logo on boot)
Option 6: c0 (enables LG brand startup logo on boot)
Sep 19, 2008 | Denon DVD-3910 DVD Player
DVD PLAYER 3166 SHOWING NO DISC
I AM HAVING A DVD PLAYER 3166 . MY DVD PLAYS CD /VCD/MP3/JPEG AND USB. BUT WHEN I INSERT A DVD VIDEO IT SHOWS NO DISC ERROR. BUT CD IT ACCPTING.KINDLY HELP ME OTHER WISE TELL ME WHERE SHALL I GET IT REPAIRED . PLEASE GIVE ME THE PHONE NOS OF PHILIPS CUSTOMER CARE THANKS, G.SEKARAN, CHENNAI
Aug 26, 2008 | Televison & Video
Problem in philips dvd
IT WILL SHOW NO DISC IF THE DVD IS HIGH DEFINITION AS THIS PLAYER IS NOT HD CAPABLE.
Dec 26, 2007 | Philips DVP642 DVD Player
Menu reads "Disc is dirty" and refuses to play disc when inserted
One note my friend don't buy SONY they have propriety tech on they're lenses that has poor Pickup on some CD\DVD's.
Sep 21, 2007 | Sony DVP-NS55PS DVD Player
LG DVP7772 Portable DVD Player with Screen showing disc error
its aged and old, all pordable dvd players stuff up eventually, get a new one.
Jun 14, 2007 | LG DVP7772 Portable DVD Player with Screen
Philips Magnavox DVD/VCR Dual Player Logo
188 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
