Question about Sanyo ECJ-B35S Micom 3.5-Cup Rice Cooker
I cannot change the time?
I press on the min or hr but the light never flashes and where do you take it apart to change the battery?
When I push the white rice button to cook no time is displayed. The cooking light is lit but there are only flashing lights going around the perimeter of the display.
It will judge when the rice is cooked successfully, don't worry. Leave the lid closed for at least 15 minutes after the light goes out to finish steaming the rice to make it fluffy.
Jan 05, 2015 | Aroma Kitchen Appliances - Others
I have s Sanyo ECJ-S35S rice cooker does not heat up. When I press Start/Cook button it keep flashing and light does not stay on. Any idea what I can do?
A rice cooker that doesn't cook anymore usually requires a thermal cutoff replaced. They act like a fuse and look like a resister. Look underneath it is crimped to one of the leads but perhaps underneath some braided insulation. Purchase another cutoff at an electronics components store (not radioshack). If there is not a rating on it try 185 degrees celcius.
Sep 22, 2013 | Sanyo ECJ-S35 3.5-Cup Rice Cooker
KS-ZT18 english manual please
English instructions here:
http://www.thaicity.co.th/elctfl/prdct/pdf72.pdf
Apr 04, 2012 | Kitchen Appliances - Others
When i plugged my cooker in the numbers started flashing all zeros and now none of the buttons will change the screen except the cancel button. When that's pressed the screen goes blank for a second it...
I am having the same problem. Here is what the Tiger people say. I haven't tried it yet though.
* If an external power failure has occurred, but only for a short time, then there's a possibility that when the electricity has returned, all functions may work normally and the clock is working correctly.
* When a power failure lasts for a long time, and the indicator is flashing 0:00...
--> Please set the time correctly by following the instruction manual.
If the electricity has returned as in these situations below:
(If it's already past the set time, after a lengthy power failure, cooking starts immediately.)
* While cooking rice (or reheating rice).
--> Continue to do the cooking (or reheating).
* Keeping warm (or Low temp Keeping warm).
--> Continue to keep warm (or low temp Keeping warm).
Aug 25, 2010 | Tiger JAE-A10U 5..5-Cup Rice Cooker
I purchased today, when i tried to cook rice, followed directions, cook light only stayed on 10 minutes and warm light automatically turned on. Rice and water were cold. I tried several times and reread...
This a bad unit. You sould return for an exchange. There is thermo strip inside to control cooking time and to change the stage of ON/WARM light when it reaches the calibration point depending on the weight of rice to cook. Now it is not working.
Aug 12, 2009 | Rival RC61 6-Cup Rice Cooker
Rice Cooker promaturely pops up before rice is cooked
try adding a little less water, And letting it sit about 4 min to make sure the steaming has stopped
Oct 21, 2008 | Zojirushi NRC-15 8-Cup Rice Cooker
Replacing clock battery on the ecj-b35s
This web site has a photos on how to open the Sanyo rice cooker:
http://www.efsowell.us/ed/SanyoECJ-B35SRiceCooker
The solution shown is to install an external battery pack,
but in the battery looks like a 3 volt Panasonic CR-2354/HFN .
(picture is too blurred to read a part number,
so you should check your own cooker).
http://www.digikey.com carries this part
(listed as P274-ND) for $1.90 plus $7.50 UPS ground service
(only carrier authorized to ship lithium batteries)
I used this battery to repair my William Sonoma SR-MK10S
Fuzzy Logic Rice Cooker which is the same as a
NationalSR-MM10N. I found the Panasonic repair manual at
http://www.usersmanualguide.com/panasonic/rice_cooker/srmm10n
-david
Sep 14, 2008 | Sanyo ECJ-B35S Micom 3.5-Cup Rice Cooker
New rice cooker - will not heat up
HELLO MIEMIEGO,I HAD THE SAME PROBLEM WITH A HAMILTON BEACH THAT I JUST BOUGHT. I DIDN'T WAIT THAT LONG FOR IT TO WARM TOUGH,I JUST WAITED 10 MIN,NOTHING HAPPENED. I JUST PACKED IT AND TOOK IT BACK TO K MART,AND EXCHANGED IT FOR A 24 CUP BLACK AND DECKER,THAT'S A BEAUTY. IT'S NICE LOOKING AND NO PROBLEMS SO FAR. I HAVE FOR A MONTH NOW AND I'M VERY GLAD FOR THIS PURCHASE ! BYE LETI50
Jun 01, 2008 | Kitchen Appliances - Others
Panasonic SR-LA10N two lamps flash
here is the link for the user manual if you need it http://www2.panasonic.com/webapp/wcs/stores/servlet/vProdSupportModel?displayTab=R&surfModel=SR-LA10N&modelNo=SR-LA10N&storeId=15001&catalogId=11017&itemId=65851&displayServiceCenter=true# I think you may possibly cure this by pressing and holding start as you plug the unit in. also try pressing start and timer together when plugging in. If this doesn't help then unfortunately; Panasonic recommend that the unit needs to be serviced - you can contact them on 1-800-211-7262 for more details or online at http://www2.panasonic.com/webapp/wcs/stores/servlet/vProdSupportContact?storeId=15001#email I hope this helps :)
Mar 01, 2007 | Panasonic SR-LA10N 5.5-Cup Rice Cooker
Sanyo ECJ-B35S Micom 3.5-Cup Rice Cooker Logo
Top Sanyo Kitchen Appliances - Others Experts
David Payne
David Payne
Gerry Harvey
Gerry Harvey
Irene Tulloch
Are you a Sanyo Kitchen Appliances - Other Expert? Answer questions, earn points and help others
