Question about Panasonic KX TC1503 Cordless Phone
On/off button of handset not working of panasonic cordless phone
On/off button of handset not working of cordless panasonic telephone.and cannot hear anything through the handset
Hand set can not find a base
Posted on Feb 16, 2009
User Manuel for panasonice cordless phone kztgea20
Do you mean the KX-TGEA20 cordless handset? I don't know of any KZ models in the Panasonic product line. If you do have the KX-TGEA20 handset, then Panasonic has the manual here: ftp://ftp.panasonic.com/telephone/om/kx-tgea20_en_om.pdf . You can also find the manual on the product page, http://shop.panasonic.com/search?q=KX-TGEA20# . Select the S or B suffix depending on the country in which you use the phone.
If you need additional information on using the handset, check the manual for the base system. The KX-TGEA20 works with the KX-TGE210 and other models. The KX-TGE210B manual is available here: http://shop.panasonic.com/support-only/KX-TGE210B.html . The direct link is ftp://ftp.panasonic.com/telephone/om/kx-tge210_mul_om.pdf .
I hope this helps.
Aug 02, 2016 | Panasonic Lands Phones
Handset on panasonic cordless only works with headset
It appears there is something internally wrong with your handset. We recommend you use the below link to setup service.
www.panasonic.com/repair
Apr 28, 2014 | Panasonic KX-TG5422M Cordless Phone
How do i turn off eco mode in panasonic cordless
You cannot turn off the ECO mode manually.
Intelligent ECO mode (select models)
Power consumption is automatically reduced when the handset is close to the base unit for extended talk time. Battery life on Talk is up to 13 hours when in ECO mode.
https://panasonic.ca/english/telecom/telephones/features.asp#eco
Jun 25, 2012 | Panasonic KX TG4021 Cordless Phone
My panasonic cordless phone model # KX-TG2258S the handset works but when you dial or talk or even just pick up the phone you don't hear any noise at all. not dial tone but it does call out. you just...
Do you even hear white noise? If not, it sounds like your phone's speakers may be broken, or it has water damage. If your landline is connected to more phones, ask yourself these questions:
Do all of the phones have this problem? If so, it's a problem with your connection, not the speaker.
Is there a volume button anywhere on the phone or the base? Try turning it up.
Do my phones make a "beep" noise when i push the buttons? If not, did they used to? If they don't, then it's likely that the speaker is no longer working properly.
You may need to contact panasonic and see if they will replace it for you.
Hope this helped! Please rate my solution!
- Frankie
May 06, 2011 | Panasonic 2.4GHz Digital Cordless...
Panasonic kx-tga101s -- problem regarding making conference call - this is very much helpfull. But i have weird problem, i did call 1 person, and then i asked the person to hold and i made the other call....
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Panasonic KX-TG2740 Cordless Phone
Which button is the menu button on the panasonic kx-tg6524? None of the buttons on the answering machine or phone say "menu" and all the settings require you to hit menu first. Thans
Jan 25, 2011 | Panasonic KX-TG6524 Cordless Phone
CRACKLES ALL THE TIME ON ALL THREE PHONES , NO NOISE ON THE CORDED PHONE I HAVE
Jan 17, 2011 | Panasonic KX-TG6311S 1.9 GHz 1-Line...
My new Panasonic cordless phone handset is not working. I can hear sound but the other terminal can not hear anything
The mic for the handset was not soldered correctly.
After re-soldering it, the handset worked perfect.
Jan 30, 2010 | Panasonic KX-TGA101S Cordless Handset
An error message is apearing on my handset,maybe a code is needed
Try this method:
Press locator button on base unit for 3 seconds. Now push flash button on handset for 3 seconds.
This MAY reregister phone to base unit. It did not work for me, more tests at http://www.panasonic.com/consumer_electronics/telephones/ts_guide1.asp
Mar 20, 2009 | Panasonic KX TG2258S Cordless Phone
No dial tone on my handset
when the phone rings just pick up the hand set and answer
if that doesn't work press the talk/answer button and answer
Oct 05, 2017 | GE 21008GE2 Dual-Handset Cordless...
Panasonic KX TC1503 Cordless Phone Logo
268 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
