Question about Apple iPod MP3 Player
Nissan problems car cuts out sometimes when starting. also makes a screching noise in tune with the accelerator
  • 53 Answers
Id say you need to replace your serpentine belt and or put belt dressing on it to stop the screching
also tell me more about the car cutting out
Posted on Dec 10, 2008
How do i reduce or control fuel consumption in nissan pathfinder
Make sure it has a good tune-up. Also, the type of tires on the vehicle will sometimes alter fuel consumption. Drive smoothly and consistently. Avoid accelerating and stopping quickly. Certain fuel additives may also help.
Mar 08, 2016 | Nissan Cars & Trucks
When maintaining speed of about 50mph,2004 pacifica hesitates and will cut off while in park sometimes.check engine light is not on
ENGINE HESITATES WHILE ACCELERATION
LOSS OF ACCELERATION
It can be fuel pressure issue or it's the problem with accelerator pedal or its clogged filters causing there.
There are many other possibilities. I suggest you to go through the list of help links mentioned below, these will help you to confirm where the actual fault lies: -------
Jerks and Hesitates During Acceleration?
http://technoanswers.blogspot.in/2012/07/2004-dodge-town-country-jerks-and.html
Loss of acceleration?
http://technoanswers.blogspot.in/2012/02/loss-of-acceleration.html
Headlights flickering and car hesitates to start?
http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
How exactly the Vehicles Accelerator Cable works?
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-cable.html
How exactly Vehicles Accelerator Pump Diaphragm Works?
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-pump.html
2000 Toyota Avalon: Engine Lean Codes and Knock Sound on Acceleration?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-engine-lean-codes.html
2004 Toyota Avensis: Acceleration And Deceleration makes noise on Front End?
http://whatisbyme.blogspot.in/2012/05/2004-toyota-avensis-acceleration-and.html
Wheel hop under hard acceleration?
http://technoanswers.blogspot.in/2012/04/wheel-hop-under-hard-acceleration.html
2009 Chevy impala accelerator pedal sensor?
http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Acceleration lag problem?
http://repairhelpcenter.blogspot.com/2012/01/acceleration-lag-problem.html
These details will help.
Thanks.
Nov 28, 2012 | Chrysler Pacifica Cars & Trucks
Car has been idling very rough for about three months. When I push on the accelerator it will occasionally skip and stall. I can usually just put it in park and the car will start back up (sometimes i have...
Have diagnostic codes read at a local shop or auto parts store and go from there. noise in back is fuel pump, it's probably ok, most make a whining noise. Probably needs a complete tune up or some minor repairs. guessing will not help. have someone qualified help you.
Sep 05, 2011 | 1999 Nissan Sentra
I Have A 93 Ford Escort Lx Im Having A Problem Accelerating After Driving It For About Ten Minutes I Will Drive It For A Little Then When I Come To A Stop Light It Sputters And Jumps Around And Sometimes...
By the sounds of it, its like once your car gets hot its starts playing up. You should run a compression test on all ur cylinders..you can get a tester from your local automotive store quite cheap, you just screw it in or shove it in and hold it, start the car and use the throttle cable hinge to rev the car slowly up to redline.. do that while the engine is quite hot though to get a more accurate reading, especially because i think thats when your car starts playing up (when its hot) im just going to say it should be around 140 for all cylinders.. just double check that and cross check your readings with ford. It also could be a ECU problem, once your car is running hot (normal temp) the tuning is wrong.
Sep 09, 2009 | 1993 Ford Escort 4 Door
My 1992 Nissan Maxima is sputtering upon acceleration. It has 220,000 miles on it and it seems to mainly have this problem in first gear. And mostly happens shortly after starting the car. Ive done a basic...
92 max
I own a 92 max 370 kms runs good but one day just cuts out while doing about 30 km, I pull over i can start it no problem but when I touch the pedal to accelerate the car stalls out.
It got worse to the point of sputtering on the highway , sometimes i could keep it alive by working the pedal but others would slow down and stall out.
I have changed the fuel filter and plugs seemed to make it a bit better but still stalling. I ran it in my driveway for 10 mins on idle then it stalls out
Is this the fuel pump??
Jun 13, 2009 | 1992 Nissan Maxima
01 sentra when i accelerate my car doesnt speed up and it makes a wooofing noise
very first thing i would try is a full tune up. This means the fuel filter , air filter, plugs and wires and possibly the coils. If this still does not fix it then try doing an emissions clean on it. What this does is it cleans out the intire fuel system and is very simple to do. Depending on the transmission on whether its a standard or automatic could be a bad tranny.
Jun 02, 2009 | 2001 Nissan Sentra
Nissan Stanza 1986 car bucks and cuts out when accelerating
I would check the vacuum advance. or maybe an O2 sensor
Feb 19, 2009 | 1985 Nissan Stanza
Nissan power cuts out when I step on gas
either the crank sensor, tune up, or a transmission sensor are bad
Jun 20, 2008 | 1998 Nissan Maxima
Apple iPod MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
