Cannot install Nero 9
SetupX.exe: Critical errorin installation of Nero
Please contact Support...
Message : SetupX.exe: CantOpen Msi Database (Path: C:\.........\unit_app_30\unit.msi) for precondition checks.
Exiting deployment process ...
  • 1 more comment
  • Anonymous Dec 21, 2008
    Great solution. I killed the registry entries and deleted the installation directory but was still having issues after a restart. I completely forgot about the common files directory. Once I deleted Nero from there the software installed correctly. Thank you.
  • Anonymous Feb 02, 2009
    Kan nero 9 niet instaleren geeft Setup X exe
    There was an error while extracting the UI Image .Exiting deployment process Error
  • Anonymous May 01, 2009
    exactly the same as described above.
I had the same problem after a previous bad installation of Nero.
I solved it by completely removing that installation.
Check that these folders are deleted:
\program files\Ahead\Nero
and more important:
\program files\common files\Nero
Then clean your registry and re-install
Posted on Dec 03, 2008
Thanks!!!. I had the same problem and was trying everything I know to make it reinstall. I didnt know that there was a directory created under common files. When deleted, everything worked like a charm.
boo hoo.....hemimeros
Posted on Jan 18, 2009
Program the following error message when I get up.SetupX.exe: Critical error in installation of Nero
Message : SetupX.exe: CantOpen Msi Database (Path: F:\Nero 9\unit_app_30\unit.msi) for precondition checks. I tried all the solutions to this problem was not.What's on my computer with nero and Marrow if I removed allI tried everything.I have to install this program.I can not use other programs.I got used to it.I've looked at all the related topics in the forum site.I also follow written instructions.no one did not work.Please help.If you do not have to format the computer will
Posted on Mar 19, 2010
Impossible de reinstaller nero 9 apres restauration
Posted on Jul 03, 2009
Give me unit setup in nero 9
Here is something I was workining hard to solve: how to install any nero 9 app for example "Nero Burning rom" or "Nero Stsrtsmart" from one of the seperate .msi installers without setupx.exe. These installers are found when you extract the full downloaded packege of nero 9. In the folder you find folders named "unit_app_4", "unit_app_5" and so on.
Inside the unit_app folders you find cab files and an .msi installer. If you try to execute the .msi you recieve an error stating this program can only be started from "setupx.exe".
This is most distubing since what would seem to be the only option is to go through nero's set up process which is time consuming and annoying.
However I have discovered a way to choose the applications I like for example Nero burning rom which is the files in "unit_app_4" and install any one of these apps directly from the .msi installer.
To do this you will need an .msi windows installer editor. The one I use is "ORCA" which is available from microsoft and comes with the windows installer sdk.
The first thing to do is edit the .msi. The .msi in the folder to burning rom is labled "unit.msi" as are all the .msi installers for each app. Open orca. Drag and drop "unit.msi" onto orca.
On the left hand tables select "custom action'. On the right hand window under "action" select "CA_BeforeDeferredFinalizexxInstall". Right click on this and then delete it.
gif.gif Capture.JPG (54.59K)
Now find in the left hand "table" "launch condition". Right click on it and select "drop table".
gif.gif Cape.JPG (47.21K)
Save the changes and exit orca.
You should now be able to install the application with the modified installer be clicking on it.
After running the install you should find folders and files in "program files" and "program files\common files" but there will be no shortcuts.
We are not finished.
If you go to the folder that contains "nero.exe" don't even try it becouse it won't work.
Nero applications will only work with a serial key and a crucial file which must be registerd.
You need this file: "AdvrCntr4.dll". In ordern to get this file you will have to run the full packege installer or setupx.exe. When you get to the first welcome to nero page go to your temp folder and you will find a folder named "nro.tmp". Open this folder select "AdvrCntr4.dll" and move it to "program files\common files".
Open a commaned prompt. Change the directory to "program files\common files"(CD %systemdrive%\program files\common files)
Type "regsvr32 AdvrCntr4.dll"
It will confirm that the file is registered.
Now you need your serial.
Open a command. Type REG ADD HKLM\SOFTWARE\Nero\Shared\NL9 /v Serial9_1223131541 /d 1111-2222-3333-4444-5555-6666-7777-8888
Substitute these intergers with your key.
You may need the product id which is under the same key. The easiest way to enter it along with the serial is to install nero with the normal installer or setupx.exe go through the process and then export the key containing the product id and serial from registry editor.
(Be carful not to use the nero product id from vista on xp becouse they are different.)
--This edit is for people who modified their .msi but still can not launch it directly. This behavior only occurs if the .msi you edited has bean used previously.--
The reason for this is the .msi was executed before it was modified and the data base located in c:\windows\installer
is still refering to the previosly executed unmodified .msi.
To create a new data base find the .msi in the c:\windows\installer folder and delete it but thats hard to find so just move the installer folder somewhere outside of c:\windows, create a new folder in c:\windows named installer and execute the modified .msi which will create a new data base then move the installer folder you moved out of c:\windows back to c:\windows. The .msi should now execute directly.
Jul 19, 2010 | Ahead Software Nero 6.6 (600901) for PC
Power dvd 9 ultra installation error...
Running Vista?
Right click on the installation.exe and select "Run as Administrator".
Jul 12, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Windows installer is looking for FAX.MSI Error 1706 I am running Windows XP Media Center
Try This:
  1. Click Start and then click Run.
  2. In the Open box, type a command line similar to the following, and then click OK new network path\Setup.exe /fvm package name.msiwhere new network path is the full path to the alternative network administrative installation, and package name is the name of the Windows Installer .msi package on the root of this administrative installation (for example, Proplus.msi).
  3. Click OK when the update is finished
Jun 30, 2009 | Computers & Internet
I don't know the serial number for nero9.
You will be prompted to enter a serial number while installing the Nero 9 Trial version. Copy your personal Trial Serial Number and paste it into the prompted dialog box during the installation of Nero 9.
Try this "Trial Serial Number": 8M01-20CX-4294-TL10-U4U0-UKE2-MMT7-AHWX
Guideline: How to enter the Trial Serial Number
1. Double-click the Nero 9_trial.exe file to start the installation.
2. During the installation you will be asked to enter a new serial number.
3. Copy the serial number above and paste it into the requested field in the Nero installation dialog box.
4. Click the "Add" button. The installation will continue.
Enjoy Your Nero 9 Trial
Hope it was helpful!
Jun 06, 2009 | Ahead Software 8 Ultra Windows
Nero 9 wont uninstall
Hi Ashley,
download NERO9 cleanup tool here:
http://www.nero.com/enu/tools-utilities.html#tab4
/Teis
Please vote before you leave
Dec 12, 2008 | Microsoft Windows Vista Ultimate Edition
UPDATION OF MSI ENGINE
Sounds like the installation file is corrupted on the CD. You could contact Nero and see if they can send you a new CD. If there are visible scratches on the CD, you could use a resurfacing machine to see if the scratches will go away. If this is being installed on a Vista Computer, it might not be compatible or it needs an update.
Aug 06, 2008 | Intel Motherboard
MSI ENGINE UPDATEING PROBLEM WHILE INSTALLING NERO 8
Error message installing Nero 7 Essentials that engine MSI must be manually updated (installed) without any instructions or links of how to do so. Can you help?
Jul 15, 2008 | Ahead Software Computers & Internet
Uninstall nero problem
Better way is to remove it through regcleaner.......
Dec 27, 2007 | FBM Software ZeroSpyware 2004 for PC
Installing Nero 8
Just down load windows installer 3.1
WindowsInstaller-KB893803-v2-x86.exe and install it on your PC. After installing the above you try installing nero 8.
This will solve the error "Cannot update MSI engine, please update manually".
Oct 15, 2007 | Computers & Internet
Computers & Internet Logo
10,142 people viewed this question
David Payne
David Payne
