Question about Epson Stylus DX6050 All-In-One InkJet Printer
My epsom driver has crashed my computer.
My computer has crashed and when i turn it on the desktop screen is wavering and you can see many of each icon. I have tried to uninstall the driver but error 1719 comes up. If anyone has any ideas i would appreciate some advice.
  • espafford Nov 10, 2008
    Thank you for your help. I tried your solution but unfortunately it hasn't solved the problem.
    If you have any other ideas I would be deeply grateful to recieve them
    With Regards
    Elaine Spafford
    Thank you for your help. Unfortunately the problem has not yet been resolved. I really do appreciate your help.
    With Regards
    Elaine
    Guru:
  • 859 Answers
This can probably be fixed. First, check that your cable coming from your monitor is tightened firmly to the socket on the back of your PC. If need be, remove this, its ok if the PC is still on, and then reattach to the plug and 'firmly' tighten the plug into the socket.
Let me know if this has resolved your problem. If not, proceed with then following paragraphs below.
Shut the PC down cold. Remove the power cord and leave it off for a few minutes. Reattach the power cord. Turn the PC on. While booting press F8 by tapping on that key like a piano key. You will get a Safe Mode boot menu. Should you get a boot source option menu, hit ESC and be prepared to hit F8 immediately to get the Safe Mode boot menu. Choose Safe Mode from this screen, then acknowledge you're booting into Windows by pressing Enter. Once you are in Safe Mode just acknowledge that you are in Safe Mode by pressing OK.
Now, you need to change the display driver refresh rate. Open Control Panel, activate the Display Icon. Click on the Settings Tab and then Advanced button. You want to change the refresh rate at this point. Click on the Adapter Tab and then the button that says List All Modes. Now select this refresh rate 72HZ. Acknowledge (and if given a preview and you have a normal display choose OK or Accept to keep the change) Now, back out by pressing OK every time until you are back to your desktop.
Now, restart your PC normally and see if you get a normal view of your Desktop.
If you do not, or you get confused, let me know by commentting back on your situation by using the Comment Text Entry Area below so I can talk you through a second approach to troubleshooting your problem. OK?
Regards,
Worldvet
Posted on Nov 09, 2008
  • Glenn Rogers
    Glenn Rogers Nov 10, 2008
    I was hoping that your issue may be solely related to the refresh rate of your display adapter and not a corrupted installation.
    However, it is clear now that your intuition was spot on and this then
    will have to be dealt with. I am providing instructions that are
    copyrighted materials and can only be used for informational purposes.
    This is my intention by providing them below. Please do not distribute
    the information without agreeing to the terms of the copyright holder.
    You may not pay me in any form for assisting you while supplying the
    below information. I know you do not intend to and I am not going to
    ask, neither is FixYa as you posted your problem in our Free Forum.
    Now that we have the legalities out of the way. The information I
    include below have instructions that are pretty darn good and accurate.
    You should have some difficulty in following them, but you are capable
    of following them completely. If you have any trouble or do not
    understand what is being asked of you, just ask me using the Comment
    Text Area below to ask me for further help.
    It is my hope you will now re-rate this solution from Thanks for Trying
    to Fixed when this resolves your problem. At the very least I hope you
    will reconsider and rate this as Helpful instead of TFT if it doesn't
    resolve your problem.
    Just recognize, we are here to Help Fix your problems. We and I in
    particular do not Try to do any Fix I will stick with you on this until
    it is Fixed so long as you will work with me and get this problem
    Fixed. If need be, I may ask another Expert to consult and confer on
    your problem to see you are back and running again. Just realize that
    we are working off a web site using email notifications. This works
    rather well, but can be slower than if I was sitting beside you on a
    Service Call for a fee.
    Regards,
    Worldvet
    Follow these instructions to the letter:
    The following material is for information purposes in solving your problem. It is
    Copyright 2008© Sandhills Publishing Company. All rights reserved
    The entire copyright statement can be found here:
    http://www.smartcomputing.com/info/legal...
    [Begin Solution]
    Error 1719. The Windows Installer Service could not be accessed. You
    may be running in safe mode or Windows Installer may not be correctly
    installed.
    Translation:
    This message might appear when you’re trying to add or remove a program
    that installs via a Windows Installer MSI (Microsoft Software
    Installation) package file. The Windows Installer Service is the
    standard method for installing and uninstalling software on Windows XP.
    It keeps track of all of the components that need to be installed for a
    particular program to run and ensures that any files that are shared by
    programs are not removed when one of those programs is uninstalled. The
    Error 1719 is an indication that some Windows Installer Service files
    are missing or have become damaged.
    Solution:
    The first thing to try is re-registering Windows Installer in the
    Windows registry. Make sure that no other programs are running and then
    click Start, Run, type msiexec /unregister in the Open field, and click
    OK. Next, click Start, Run, type misexec /regserver in the Open field,
    and click OK. Restart your computer and try installing or uninstalling
    again.
    If you’re still getting the error message, the next step is to try
    reinstalling the Windows Installer files. In order to do this, you’ll
    first need to rename the existing files.
    First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
    In My Computer, click Search and locate the following three files:
    msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll
    need to select Search Hidden Files And Folders under More Advanced
    Options. When you’ve found the files, rename them, by removing the .dll
    and .exe extensions and replacing them with an .old extension(for
    example msi.dll becomes msi.old).
    Once you’ve renamed the files, WinXP will automatically replace them
    with a new copy from the dllcache (a hidden folder where copies of
    important system files are kept in case you mistakenly delete or rename
    critical system files). Restart your computer and try to install or
    uninstall the program again.
    Finally, if neither of the above processes corrects the problem, boot
    into Safe Mode, and go through the above steps again, first
    re-registering and then reinstalling.
    [End of Solution]
  • Glenn Rogers
    I'm sorry to see your problem still exists. Still, this exercise you just ran through does help to narrow down the problem at hand.
    Sometimes, coincidences happen and perhaps this is the case with your new printer.
    1.) Have you uninstalled or been able to uninstall your printer?
    a. On your CD/DVD with the Printer installer on it, there are sometimes a installer cleanup utility. It would be noted by the name of the sub Folder its located in in most cases.
    2.) Do you feel there is any chance this problem is related solely to your monitor? Could this have just been a coincidence?
    a Can you replace your monitor with another to rule out your monitor as the problem?
    b Do you have an LCD panel or a TV like CRT Monitor?
    Regards,
    Worldvet
If i leave computer on without anyone using it . computer goes to black/dark screen , can't perform any functions. also computer crashes at times during use.
You need to check your power settings. It is being set to go to turn of the drivers after a certain amount of time.
Control Panel\Hardware and Sound\Power Options Then change the power options so it does not shut off the hard drive.
Mar 06, 2011 | Gateway DX4300-03 Desktop PC
My desktop keeps crashing/freezing, the screen goes a solid colour (colour depends on what you are doing at the time of the crash) and i have to turn it off via the plug because it wont turn off by the...
It sounds something else is wrong, try plugging out every pci, pci-e, and usb. If the problem still persist, try updating your motherboard driver and cmos driver.
If all the above fails, then you have a bad motherboard. Then there's nothing else you can do but buy a new pc or replace the motherboard.
Jan 03, 2011 | Acer Aspire X1300 (PV.SCC0X.002) PC...
Hp pavilion desktop keeps crashing with Windows 7 just installed? cant someone help?
hello,
if the case is that whenever you turn on the computer it presents to you options on how to turn on your computer, safe mode, safe mode with command prompt, start up windows normally and other options of such.
if you select any and it goes blank, and comes up with a screen showing windows driver error occurred.
try to format the system and reinstall the operating system again.
get back to me to assist you better if that doesnt work
Jan 02, 2010 | HP Pavilion (PN153AAR) PC Desktop
Blue screen appears and windows has crashed
Boot into safe mode by pressing F8 repeatedly as the computer boots until you get to the advanced start up menu. Choose safe mode and either roll back your video driver or use a system restore point.
Jun 02, 2009 | E-Machines eMachines Desktop PC
Game crashes
It might be your graphics card or one of the files is corrupted try installing it again and if it still crashes its your computer
Feb 06, 2009 | HP Hewlett Packard Pavilion S3530F Phenom...
We are having problems trying to crash our cumputer. The reason is children had downloaded some viruses and we have already did a back up of all good files needed. Now we need to crash it and reinstall...
Why in the world are you trying to crash your computer??? Just download a virus utility, such as Trend Micro or McAffee, and let it deal with the virus. If you are having problems logging in, restart your computer, and after it goes through the BIOS screens, before it brings up the screen that says "Windows XP" with the little progress bar, press F8. Select safe mode with Networking, wait for it to go though all of the MULTIDISK screens, and then download the virus utility. If this doesn't help, please report back and elaborate on everything. What computer you have, what you mean by "crash it" (reformat???), what drivers you need to reinstall... etc...
Jul 05, 2008 | Computers & Internet
Dell Dimension 2350 - Computer Crashing
try boot in safe mode and restore to an earlier date when your pc was working nicely
May 08, 2008 | Dell Dimension 2350 PC Desktop
System failure blue screen,error message. used recovery disks successfully. updated computer and service pack 2. i shut down computer and restarted it and it crashed again. redid recovery/formatting...
Usually a device driver wrong. Check hardware divices. If yellow with exclamation driver needs to be loaded ith correct driver before next crash. Then reboot and test.
Feb 28, 2008 | Computers & Internet
Dell Inspiron 700m screen acting up
try to uninstall and install the the display drivers / graphics card drivers.. it should help you.
Feb 20, 2008 | Dell Inspiron 700M Notebook
Epson Stylus DX6050 All-In-One InkJet Printer Logo
172 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
