Question about Acer X193W LCD Monitor
Drivers for the Acer LCD monitor X193W under Windows XP Pro.
I am looking for the Drivers for the Acer LCD monitor X193W under Windows XP Pro......
Acer does not support Windows XP anymore....
  • 5 more comments
  • kdavt Nov 15, 2008
    The same problem. There's no drivers for XP.
  • Anonymous Nov 18, 2008
    yes, i've got the same problem
  • Anonymous Dec 10, 2008
  • Anonymous Dec 13, 2008
    i wanna have my max resolution with my new LCD but i cant with windows xp pro
  • gab69676 Dec 25, 2008
    Need driver for acer X193W LCD Monitor.
  • philbrat Dec 30, 2008
    Yes, I've got the Acer X193W monitor on a NVIDIA GeForce 7600 GS card under Windows XP trying to play SPORE, and I get these annoying lines and bars. I need a driver as my system is treating the monitor as a generic Plug & Play device.
  • Anonymous Jan 03, 2009
    nao acho o driver de video para este monitor, estou procurando até o momento.. se alguém tiver por favor poste aqui e se eu conseguir também irei postá-lo
The acer LCD monitor is plug and play.You don't need a driver.But unless you have a graphics card that supports at least 1440x900 you have problems. Also if your card has a div connection, use that instead of the analog connector, The monitor comes with that connector. Use the old one to connect a second CRT monitor if you want. Don't connect both to the lcd monitor and to the computer unless you are using a second monitor. Like everything these days, every purchase seems to need an upgrade of sorts, On board graphics **** anyway. Buy at least a 128 MB graphic card with a digital connector and more RAM never goes astray.....
Ron
Posted on Dec 30, 2008
    New Friend:
  • 99 Answers
Try driver.com
Rifaa
Posted on Nov 09, 2008
My PC runs on an XP Pro x64 system and has installed Plug & Play Monitor instead of my Acer X193W ....!! How can i install my Monitor properly on XP x64.... Thank you...
Unfortunately Acer has chosen to not support Windows XP any longer. If you go to the Acer website as follows:
http://www.acer.ca/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3751&sp=page15e&ctx2.c2att1=27&miu10ekcond13.attN2B2F2EEF=3751&CountryISOCtxParam=CA&ctx1.att21k=1&CRC=719687231
Then look for the driver for your monitor. You will see that the driver only lists versions of the Vista O/S as those that will work with the driver. When XP is not able to load the correct driver the system will identify and load the driver as a Plug & Play Monitor. This means that you will be able to get some functionality out of your monitor. but you will not be able to get all of the resolutions that the monitor is capable of running. If you just purchased the monitor and were told that it will work correctly with XP, you may want to take it back to the dealer you bought it from. Failing that you will either have to upgrade your O/S, or give up some of the functionality of the monitor.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 16, 2011 | Acer X193W 19" Widescreen TFT Monitor
Hello, I have installed a new 18.5 acer monitor, X193W C but the screen turns blank when I scroll over the task bar. Any suggestions? I have windows xp. Donna
I would check Acer's website in the support section. I suspect you have the wrong driver for your operating system.
Jan 20, 2011 | Acer X193W LCD Monitor
I have an Asus X193W Moniter, and a fairly highend hyperthreading computer with Windows XP on it, (going to 7 soon) a GeForce 7600 3D graphics card, I plugged my Acer moniter into it and be damned if I do...
PROBLEM:
Weird colors
SOLUTION
that problem its a hardware failure, so you can't do much with drivers and softwares.
that happens usually when some filters (electronic component) fail so y best advice is take the monitor to a shop for proper fix
Aug 24, 2010 | Acer X193W LCD Monitor
I bought this acer z193w monitor and everytime I fire it up I get a message saying . My computer runs on windows xp pro.as I haven't got the user's manual, I would like to know why it doen't work, and if...
1) Monitors do not care what operating system you are running, otherwise I wll not br able to fix the monitors if I need to have all the operating system installed in my PC or MAC. You must have correct driver for the video card installed in the your PC.
2) What message are you getting on the screen?
3) User manual: http://retrevo.com/support/Acer-X193W-Monitors-manual/id/7197ag005/t/2/
Jan 21, 2010 | Acer X193W LCD Monitor
Just bought a acer x193w lcd monitor no sound
I assume the monitor has speakers built in . Have you plugged the sound card in to the monitor?
Jun 03, 2009 | Acer X193W LCD Monitor
Win XP with Acer LCD" X193w Monitor Display Resolution problem?
First, make sure that it has found you exact monitor, if not install the drivers for the monitor and see if that helps. Also check the specs on the monitor and make sure it can go to the size you are selecting
Apr 21, 2009 | Acer X193W LCD Monitor
Rapid shuddering of icons, pix on Acer X193W monitor (10 mo. old)
in very first you have to check the pc with another display monitor
if display problem still available check the graphic card and video driver. remove the driver and reboot. check display resolution and refresh rate
Apr 12, 2017 | Acer X193W LCD Monitor
Acer P193W monitor stretched image
What service pack of windows xp are you running? Also, do you have your old monitor, if so, then plug it in and see if the same problem occurs. If not , go under the settings for your graphics card (not windows display options) and see if there can be a correction made to the settings for your monitor. Also, try going to microsoft.com and updating your computer (it's free) and you'll probably get the required driver to fix the problem from them. Check under your control panel and see if you have automatic updates turned on, if so you may want to limit what updates are to be installed by allowing updates but you choose which one's to install. Hope I could help. My e-mail
tallcoolone@yahoo.com .
Jan 04, 2009 | Acer X193W LCD Monitor
Acer x193w on win xp woulnt go above 800x600 resolution
The resolution issue you are describing sounds like a video card driver issue. You must determine what video card or chipset you have and apply the appropriate driver. The Acer x193w monitor is plug and play, it will display whatever the OS sends to it provided it is within it display range and 1440x900 is definitely within that range.
Dec 16, 2008 | Acer X193W LCD Monitor
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Acer X193W LCD Monitor
Acer X193W LCD Monitor Logo
4,089 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
