Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Why wont my washer dryer empty the water...???
My 3 yr old Washer Dryer has worked perfectly until it decided to keep hold of all the dirty water....yuk! It fills, it spins, but it doesnt drain... help please. Where is the filter on this ?? cough cough... Yeah ok its 3 yrs old and now I'm asking! Thanks Fizzy
  • Anonymous Mar 28, 2014
    You can have it spin for 3 hours and still humid. I think it's actually not warming up anymore. Easy solution or ask for replacement? No idea how old it is. Thanks.
    President:
  • 1,294 Answers
If the machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is okay (though some units have a separate belt for the pump and direct-drive washing machines don't have belts). 1) Be sure the drain hose isn't kinked. 2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The water pump may be broken or clogged with a small article of clothing or the controls may be broken; call an appliance repairperson. courtesy "nagev"
Posted on Apr 14, 2007
  • prem mathew Apr 15, 2007
    Take a good look at your drain filter and clean thoroughly first; clean out the pipe also from the base of the tub to the drain filter, probably this is blocked with some cloth,etc
What could it be
Hello Reese,
I see that you're having a Problem with your Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer. I see that the washer will not work until dryer is turned on and the dryer will not heat. I would recommend giving the appliance a hard reset. You will do this by either unplugging it or switching the circuit breaker off that the appliance is attached to. When you do this you will want to leave it off for 3-5 minutes. Once the 3-5 minutes has elapsed, bring power back on and try to restart it. If you are still having trouble with the washer not working until dryer is turned on and the dryer will not heat. I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 20, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
Our washer dryer model GLEH1642FSO will not
sounds like the motor needs new bushes, same thing happened to me last yr, regards paul
Feb 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Asko WCAM1812 Front Load All-in-One Washer / Dryer It does not start the lights are blinking on spin. the door remains unlocked
hold down the "cycle signal" button for 3-5 sec. unplug and plug back in. should clear and reset computer
Aug 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Washer wont drain....
try the lid switch with a screwdriver in the slot to see if it activates. Mine did the same thing, would agitate but not empty nor spin and it was the lid switch assembly--a 35.00 part that cost 150.00 to repair with a repairman!
Jul 11, 2009 | GE WSM2420T Top Load Stacked Washer /...
Puddle under 1 yr old washing machine hours after it is finished
Sounds like either the gasket on the inlet is leaking or not tight or the solenoid housing is cracked causing the leak. When its in use the pressure from the line is realased when the solenoid is opened letting water in. When not in use the solenoid stays closed allowing pressure from the line to build causing the gasket to leak. Check your gaskets, and solenoid housing for leaks and then check to make sure your water pressure is not set too high.
Joe
May 19, 2009 | Kenmore 22422 Top Load Washer
LG WM2688H Front Load Washer
I do not have a solution, but have the same exact problem and would like to know if you ever found out where the thermistor is and if you were able to fix it.
Thank you,
Treegirl
Sep 12, 2007 | LG WM2688H Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
239 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
