Question about Intel D865GBF Motherboard
My system gets hanged
When I boot my system it runs for a while and after some time It gets hanged. then nothing can be done even when restarted there wont be any display.
  • Intel Master
  • 1,250 Answers
Change the RAM then check
Posted on Nov 09, 2008
Hi!My laptop hangs/freezes on desktop after starting 10-20 secs. But i can run safe mode and has done System Restore but when I restart happens same problem occurs. I first encountered this problem when...
Welcome to FixYa!
Since you already done doing system restore and same thing happens, there's a possibility that the problem is with the Operating System itself. All you need to do is to reinstall the whole operating system.
1. If you have the Recovery Disc that came with the computer, insert the disc and restart the computer.
2. It will ask you to press something, maybe Del or F2 to boot from the disc.
3. Once you press that, your computer will automatically boot from the cd and it will asked you on to which partition you will save it.
4. Choose the partition which have the largest space, usually Disc 0 Partition 1.
5. Follow the next instruction on the screen and it will reinstall the whole Operating System.
Hope this information will help. Thank you for using FixYa!
May 14, 2011 | Computers & Internet
Freezing upon boot
restart and tap F8 key, if loads to repair your computer/Advanced boot option, select safe mode using the down arrow key and log in to your account, create a backup of all the data on a removable storage device.
Insert System disk and run a system recovery to the original fcty setting, if backup done, restore from the removable storage device.
Jun 08, 2010 | HP Hewlett Packard Pavilion Slimline...
Running Windows 7. A windows Critical Update auto installed on Thursday and system ran fine for several hours. Then it hung and I had to re-boot. It would not reboot, not even into Safe Mode. It would...
it more than likely has little to do with the operating system. It sounds like a hard drive problem. Are you able to format the harddrive and reinstall?
Jan 30, 2010 | Computers & Internet
I have a sony vaio pcv-L400 that is running extremely slow i started the cleanup utility and 3 hours later its still running and its only about 20 percent done, when i try to remove programs from the...
There are some Tips and Techniques for smooth and fast working of Windows.
Re-boot your system, press F8 for boot menu, select Safe Mode, Try to Uninstall any Useless software from Control Panel.
Go to;
C:\Documents and Settings\Administrator\Local Settings\Temp (Administrator Login Should be your user name)
Delete all files of the Temp folder.
Go to;
C:\Documents and Settings\Administrator\Local Settings\Temporary Internet Files
Delete all files.
Empty Recycle bin.
Go to;
Start>Run>Regedit>HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run Delete every value except Default
Go to;
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run Delete every value except Default
Go to Start>Programs>Startup> Delete all shortcuts.
Reboot system and now check.
Jul 27, 2009 | Sony VAIO PCV-L400 PC Desktop
My pc gets struck up suddenly forcing me to restart (windows xp
sounds like either a RAM or HDD issue. First thing is if you have 2 sticks of ram pull one out and see if it boots ok if not pull the other stick out and put first stick back in. If neither stick lets you boot then I would run a HDD test (some have them in bios) if you do not have it in bios boot windows into safe mode with command prompt and in command prompt type chkdsk /f
May 28, 2009 | Computers & Internet
Getting hanged
try to boot into safe mode by pressing F8 while restarting..then in safe mode goto>start>Run>type msconfig>and in start up tab disable the un necessary programs...then restart
Apr 11, 2009 | Acer Aspire 4720 Notebook
Qosmio G35-AV600 boot problems
You will have to reinstall both its BIOS and operating system, only that can properly solve the problem. I my solution was helpful, Kindly accept it.
Thank You, Arjun
Apr 01, 2009 | Toshiba Qosmio G35-AV600 Notebook
Safe mode boots okay but not in normal boot - no error either
Do you have the original recovery disk? I recommend inserting the recover disk, restart the computer while continually pressing F12. Select boot from CD, press any key when asked, and you would want to do a "repair". That should fix your problem.
Jan 12, 2009 | IBM ThinkPad 600X Notebook
No operating system is booting
Do a repair with the XP disk. boot up and choose repair then do chkdsk /p and fixmbr or fixboot
Aug 15, 2008 | Intel D102GGC2 Motherboard
Xp hangs .we rebooted the xp machine but it agin got hanged .when we login and click any icon like IE .it hangs
Reboot computer in safe mode by pressing f8 key at boot. Select safe mode. Run your spyware removal program to clean of spyware. Then run your antivirus to check for and clean viruses. After complete restart computer normally. If it boots to desktop and can access the internet, update your virus scan and run another scan & clean. If this does not work boot computer with your xp cd, select r for repair console. At the dos prompt type fixboot then hit enter, and y. Then type exit to reboot. If that does not work reboot with cd same steps as before except type chkdsk c: /r  and ht enter. After done exit to restart.
Hope this helps... please comment if further assistance is needed
Oct 26, 2007 | Computers & Internet
Intel D865GBF Motherboard Logo
49 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
