Question about Aiwa AV-DV70 5.1 Channels Receiver
Aiwa AV-DV70 Will Not Power On
My unit will not power on. The clock will light up and I can set it, but it will not turn on with the power button. I've try using the Video 1, 2, & 3 button to turn it on too and still nothing. I have alread disconected everything and only have it plugged in. Is there something else that I can do to fix this?
2 Suggested Answers
  • 5 Answers
SOURCE: Speakers started buzzing.
It sound like your getting AC noise, chances are you have some dried out capacitors
Posted on May 17, 2006
How do I set the clock on my ccr1cd?
stevej9_98
SOURCE:need instructions for Wharfdale ccr1cd micro clock alarm
Press the STOP/CLOCK button for about 3 seconds till the hour number flashes
use the forward and reverse buttons to set the time on the hour
press the stop/clock button again to move on to minutes numbers
use the forward and reverse buttons to set minutes
Press the stop/clock button again to complete process
Posted on Mar 28, 2010
May 27, 2018 | The Audio Players & Recorders
Whay does my AIWA CA-DW63OU start playing by itself?
are you sure it's not going into demo mode after you turn it off? Is there just lights and display flashing? - that is demo mode. Probably a button on the remote to turn it off.
May 13, 2014 | Aiwa Audio Players & Recorders
Aiwa XR-EM50
This was easy.. download the manual here:
http://www.nodevice.com/download/user_manual/aiwa+xr-em50.html
From the manual:
Clock Adjustment: (Page 7)
Setting the clock
1 Hold down SHIFT and press CLOCK on the remote
control.
When the unit is turned off, you can also press SET.
2 Within 6 seconds, press "< <" (rewind icon) or > > (fast forward icon) to set thetime.
Each press changes the time in 1-minute steps.
Holding these buttons down will vary the time in 10-minute
units.
3 Press SET.
The time display stops flashing and the clock starts from
00 seconds.
When setting the clock on the unit in stop mode, hold down
"square" (stop icon) and press "> >" in step 1. After setting the time in step 2,
press TONE in step 3.
To display the time while the power is on
Hold down SHIFT and press CLOCK on the remote control.
The time will be displayed for 6 seconds.
To switch to the 24-hour standard
Display the time and press s within 6 seconds.
With each press, the clock alternates between 12- and 24-
hour standard time.
Tip:
In the 12-hour standard, "AM12:00" indicates midnight and
"PM12:00" noon.
If the clock display flashes when the unit is turned
off
There has been a power interruption. Reset the clock.
Bass / Treb Adjustment: (Page 11)
1) Press BAS or TRE
2) Within 6 seconds, turn VOLUME (press VOLUME +,- on the remote control).
Each level can be adjusted from "-2" to "+5".
Good Luck!
Apr 07, 2014 | Audio Players & Recorders
How do i set the clock on jvc rv b90?
Hello
To adjust time:
1 Set the power button to ON
2 Press the CLOCK button 3 square cloumms will blink
in the display
3 Set to 13:15 by pressing the DOWN/UP
buttons
(When the button is kept pressed, the minute/
hour indication changes continuously.)
4 Press the SET button; the time will light in
the display
To set to the nearest second...
Press the SET button when you hear the time
signal from a TV or radio
To confirm the time while listening to a CD
or radio broadcast
Press the DISPLAY button briefly on the
remote control unit. Press it again to return to
the previous display
If memory back-up batteries are exhausted
or not installed, and the power cord is plugged
in again after being disconnected, or power is
restored after a power failure, "CLOCK" will
blink in the display. Set the current time again.
Jul 04, 2011 | Audio Players & Recorders
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    How do i set time in pioneer in DEH-2250UBG
    1) Hold SRC until unit power down.
    2) Hold Master Contol nob until "clock set" appears.
    3) Press Master Contol to enter set clock
    4) Turn Master Contol to adjust time. Use left
    Feb 18, 2011 | Car Audio & Video
    Set the clock on a clarion cd player?
    Setting the Clock
    1) Press and hold in the BAND button [4] then press the DISP button [9] to toggle the display to the clock mode.
    2) Press and hold in the BAND button [4] then press and hold in the DISP button [9] for at least 2 seconds.
    3) Select left or right to adjust the time using the a-selector
    ~Adjusting minutes
    Each time you select right >> using the a-selector [3], the minutes increment up by one digit (0 to 59).
    ~Adjusting hours
    Each time you select left << using the a-selector [3], the hours increment up by one digit (1 to 12).
    *The clock only displays time in a 12-hour format.
    There is no way to toggle the clock to a 24-hour format.
    4) Press the BAND button [4] to set the clock into memory. This also resets the seconds counter to zero.
    Note:
    *The clock can only be set by turning power on to the unit and switching to the clock display mode. You cannot set the clock when it is displayed with only the igntion on. If you drain or remove the car's battery, the clock must be reset. While setting the clock, if another button or operation is selected, the clock set mode is canceled.
    Dec 08, 2009 | Alpine Car Audio & Video
    AV-S17 - Clock Display won't stay on?
    Check the internal memory battery if there is one, then reset the sleep setting? Check the manual regarding memory back up.
    Sonic Doctor
    Mar 27, 2009 | Aiwa AV-S17 Receiver
    Change Clock - Logitech Pure-Fi Elite
    hold the src button left of power along with button to the right power.a model number will appear once it does let it disappear and the unit will go into reset. set the language, 12/hr, 24hr etc and the time. :)
    Dec 13, 2008 | Logitech Pure-Fi Elite High Performance...
    Changing the time pioneer DEN2000MP
    The solution that worked for me is:
    1) turn off the radio.
    2) Push and hold the power button down (the dial). DON'T release the button.
    3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
    4) use the up/dwn, right/left buttons to set the clock.
    5) turn off the unit by pushing the power button (again, the dial).
    That is it. the clock should be set.
    Hope that helps,
    Nov 11, 2008 | Pioneer DEH-2000 CD Changer
    Aiwa AV-DV70 5.1 Channels Receiver Logo
    85 people viewed this question
    Top Aiwa Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Morne Olivier
    Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
