Question about Microwave Ovens
Sanyo microwave fuse blowing -drawing too much current
I dont have any lit. on the machine and cant locate any model number.!!! The machine quit working I was told. Found a blown fuse. Did not have any replacement so I fitted a thin wire. The machine seemed to work. It had nothing in. As I watched the wire became red hot. Before it blew the circuit breaker of the main board disconnected. Several tries gave the same result. I have another magnetron and transformer. They all give the same ohm readings. Seems unlikely all units would be faulty. The turntable motor functions normally as does the cooling fan-no shorts detected. Dont know how to check the capacitor
Can you help? Rob alias truffle. Jhb. R.S.A. 09/11/08
  • Thandanani Nov 24, 2008
    Hi, I found the links very helpful esp. the sample pages which makes me realise how much I need to learn!! I am still testing the cap. and transf. Seem to be OK but I am not sure. Some one with more know-how will help me confirm that today. I did not explain myself very well-it was the circuit breaker for the whole house mainboard that tripped.
    Much as I would like to I dont know that I can risk ordering the instruction material. So much disappears from our mail especially CD disks and that would be R1000 down the drain. Wish I had known before as I just came from the USA. First I will try to find something locally. In any case I plan to learn a bit more about it before I spend much more time fiddling on the machine.
    I will try to let you know if ever I have any success.
    So far at least I have had some fun and....no shocks!!
    Regards,
    Thandanani.
  • Microwave Ovens Master
  • 9,098 Answers
Wow, I've never heard of a microwave having a circuit breaker on the main board.
I would suggest that you test the capacitor and the high voltage transformer.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Nov 21, 2008
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
What causes microwave to blow new fuse?
The only thing inside a microwave oven that draws enough current to blow a fuse is the magnetron that generates the microwaves to provide the cooking power. Based on the age of the unit (approx 15 years) it is most likely best to just replace it as repairs at that level are not cost effective. Newer units cook better and faster using less power these days.
Jul 02, 2015 | Sharp Microwave Ovens
The microwave won't turn on. it is off completely. Just happened last night. Have checked the electric fuses, poked the buttons, but noty on. Stove is ok.
You have to open it up and see if you can find the power fuse, usually a BUSS 15amp Slo Blo that protects the Microwave Tube from drawing too much current and causing a fire. These fuses degrade over time or some get through that are not quite 15 amps and blow.
Dec 19, 2010 | Jenn-Air JMC9158AAS Convection/Microwave...
3 year old OTR microwave left on with nothing in it. now shows no power,board,lights or fan. what do I check first?
Dec 19, 2010 | Kenmore 69642 Microwave Oven
Microwave blows fuse when turn on
If it is blowing an internal fuse it could be a lot of things.
-short in the motor
-short in one of the other components
- gunk/dust could be causing a short
If it is your house circuit breaker/fuse then either the microwave draws too much current/amps for the circuit and you should try another circuit or you already have too many things/appliances plugged into the same circuit (not necessarily the same outlet) and need to unplug one or more of them so that the 'fuse' doesn't blow.
Kugellager
Nov 07, 2009 | Sharp R-1460 Microwave Oven
My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
Jul 23, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave Repair
there are several internal fuses protecting different circuits, as long as you get a direct replacement you will be ok
Feb 18, 2009 | Whirlpool GH4155XP Microwave Oven
Fuse blows. Drawing too much current ?cause.
Nov 09, 2008 | Microwave Ovens
Microwave Repair
You will need a model # to look up parts. Go to appliancepartspros.com and you can see a diagram. Use the model # on the sticker in the microwave. There will be a fuse and most of the time they are easy to get to.
Oct 08, 2007 | Microwave Ovens
Jenn-air model jmc7000
Can someone tell me where i can find fuse for microwave convection/grill oven 5kv 700ma There is a other no on the fuse TUV5m41GF
Aug 29, 2006 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
326 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
