Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Panasonic pt47wx42 green shadow
I am having a problem with my panasonic rear projection tv. I have had the convergence ic's replaced, all connections are good. The red and the blue seem to be fine, but the green seems to bleed and shadow the images. I used caps for each and also noticed that when it is just the green, its barely there and looks wiped. please, any help?
SOURCE: Where can I get parts?
STK392-110=CONVERGENCE IC USE TWO FOR REPLACECEMENT PART= WWW.bdent.com Product Details: The STK392-110 is a convergence correction circuit IC for video projectors. It incorporates three output amplifiers in a single package, making possible the construction of CRT horizontal and vertical convergence correction output circuits for each of the RGB colors using ust two hybrid ICs. The output circuit use a class-B configuration, in comparison with the STK392-010, realizing a more compact package and lower cost. www.partstore.com
Posted on Jun 04, 2007
SOURCE: CONVERGENCE ic CHIP
I replaced the Convergence IC Chip STK392-110 for my PT-53WX42 Panasonic HD Rear Projection TV but I found burnt resistor(resistor #)R7053,R7002 & R7005.Can someone tell me the part# ,description,resistor value and power rating.I don't have the schematic to look .Thanks
Posted on Sep 08, 2007
Slinteriors
  • 8617 Answers
SOURCE: convergence for Panasonic 47"
Yes it is that set uses the same IC STK392-110 You can get the new ICs at this link and they will provide free installation instructions with pictures as well as free on line tech support instant messaging while you do the repair. heres the link.
http://servicemanuals.vstore.ca/
Posted on Apr 14, 2008
itvrepair
  • 28 Answers
SOURCE: I have problem with my convergence rear projection panasonic
most of the time you need to change the stk392-110 chips an ome resistors let me know if you need more help
Posted on Jul 31, 2009
Slinteriors
  • 8617 Answers
SOURCE: Panasonic rear projection-red convergence-moves horizontal only!?
The convergence ICs have failed. You will need to install a convergence repair kit. You can get the convergence repair kit for your model Panasonic from www.tvrepairworld.com which contains both of the Convergence ICs , the associated resistors and the cD with detailed repair instructions.
Posted on Dec 26, 2009
My color is not perfect. It looks like it is missing the green aspect
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows picture or 3D picture look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,require replacing to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 03, 2010 | Panasonic PT-53WX54 53" Rear Projection...
Green tint only on left hand side towards the middle of the screen
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 29, 2010 | Panasonic PT-47WX53 47" Rear Projection...
We own the PT51HX41 51 inch rear proj. We are getting a green and red glow around all pictures and wording. Are the bulbs gone or do they need to be adjusted...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors.These parts on the tv convergence board are dead,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 05, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Yellow band on bottom of PT. Double image on news scroller at bottom of PT. Have tried convergence - no luck. Green will not align and will not come down.
Ur tv have any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.Ur tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.The parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem on panasonic rear projection TV model PT-53WX52F
the PT47WX42 Convergence repair kit from www.tvrepairworld.com also works for your model. The kit contains the ICs, resistors and the CD with instructions.
Sep 21, 2010 | Panasonic Televison & Video
Stuck in 3d image
Replace the convergence Ics. You can get the Panasonic PT47WX42 convergence repair kit from www.tvrepairworld.com which is correct fro your model. The kit contains the parts and the CD with detailed repair instructions.
Aug 01, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Tv wont turn on
You need 2 STK392-110 Convergence ICs and possibly 6 2.2 ohm 2watt resistors. You can get the convergence repair kit for your model from www.tvrepairworld.com the kit contains the ICs, resistors and the CD with instructions. The PT47WX42 convergence kit is the correct one for your model.
May 10, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Projection tv convergence problem
install the convergence repair kit for your model. You need the PT47WX42 repair kit which covers your model also. Its available from www.tvrepairworld.com and comes with the CD that has instructions for the repair.
Apr 09, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Blue Shadows
You need to install a convergence repair kit. The PT47WX42 Convergence repair kit at the following link is the correct one for your model. The kit contains both Convergence ICs and the six feed resistors, Plus the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 20, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Convergence
covergence amp ic"S need to be replaced.
Aug 16, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
