Question about Compaq Presario 700 470024-192 Notebook
Microphone not working
Plz help i have checked all settings
Please use geniune windows vista only thanks minu ji /& other solution pls cont 09416797415
Posted on Nov 16, 2008
Hear myself through my headset
so to begin
1. right click the lil speaker on the bottum right hand side
2. select Playback
3. Right click you default speaker set, (for me its 2-logitech G330 headset)
4. select properties
5. go to Levels in the tab menu.
6. use the microphone slider and slide the microphone volume to 0
hats it your done, your mic will continue to work as normal with out the feed back loop in ur head set.
Aug 30, 2012 | Logitech USB Desktop Consumer Microphone
In my laptop hp compaq cq45 with os windows xp microphone is not working plz solve my problem...
If the person cannot hear you then, either your microphonedriver not installed or not working OR the microphone is not configured inSkype.
To test your microphone then click on Start - All Programs - Accessories -Entertainment - Sound recorder. Then record your voice and then play it back.If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options -Audio Settings for the Microphone THEN click on Save.
Mar 04, 2012 | Computers & Internet
When doing recording, my laptop does not detect sounds from the microphone.
  1. Might be in ur laptop sound setting the mic on mute
  2. ur microphone pin not put into the right place
  3. ur microphone cable or ur microphone may be faulty, plz check the mic in other system .
Jun 04, 2011 | Computers & Internet
Realteck mic problem
Well, if it's working when you record sound, then there might be settings related problem with the skype or yahoo messenger etc... Let's get started with the "skype" open your skype - sign in - click on "tools" select "options", on the left pane of the options windows, click "audio settings" and now on the right pane, check the "microphone" settings and verify it's set to "Realtek High Definition Audio", if it's not, do so now. click "Save". You can set the volume manually by uncheking the "automatically adjust microphone settings" and turn up the volume slider. Do the same with the yahoo messenger, but you can't set this before you log in. In yahoo messenger you need to go to the "preferences" - "Video and Voice" from the "Messenger" menu. Also make sure, that "digital input or output" isn't selected.
Good luck. Thanks for using FixYa.
Jun 06, 2010 | MSI K9N6SGM-V Motherboard
Acer aspire 5920 running vista has built in mic not working
Hey,
It is all because the Microphone is not set as a default device to start recording.
Its like your computer has no device for recording even if the computer has connected with Mic.
Just change the settings and enjoy..!!!
Check the below link:
How To Install and Setup a Microphone:
http://www.vista4beginners.com/How-To-Install-and-Setup-a-Microphone
Set up microphone:
http://www.microsoft.com/enable/training/windowsvista/srmic.aspx
Hope it helps.
Regards,
Nags
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Plz help with the mic
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Jan 24, 2009 | MSI Starcam 370i Webcam
Sir , I hv a compaq presario c700 product with KU764PA Product no . m using window vista OS. Sir I m not able to use My Inbuilt or extension Microphone..Watz the Problem..Plz sugges me wat to do ? I m not...
Go here to get the updated audio driver:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-64867-1&lc=en&dlc=en&cc=uk&product=3694963&os=2093&lang=en
Once you are on that website, Click and download the file named: SP40762.EXE
When you have dowloaded to the file to your pc, double click on it and it will install the new drivers.
If this doesnt work it might be because your microphone is either turned off or turned down in the sound control section.
To get there:
Click start > Control Panel > Hardware and Sound > Sound
Then select the Recording Tab
Double click the microphone icon
On the page titled "General"
Device usage should be set to "use this device (enable)"
The next page to check is "levels"
Make sure "Microphone" has about 90 to 100 next to it
Click apply and ok to exit.
Reboot your pc and check for sound..
I hope that helps.
If it does, please rate me.
Cheers
Mike
Jan 18, 2009 | Compaq Presario 700 470024-192 Notebook
My Microphone is not working
Simply enable the microphone and check the audio control tab to see if the microphone is not mute....sodeep
Dec 12, 2008 | Asrock 775i65G Motherboard
Microphone on Apple Macbbok 13" 2.4 GHZ,2GB
Check to see if the microphone works on the macintosh side of the computer, chances are it won't, microphone usage on Macintosh computers has been hit and miss, sometimes the microphone needs a pre-amp or USB interface like a Griffin iMic adapter.
Oct 23, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Pavilion dv4000 microphone
sorry no build in microphone use ext....
Apr 28, 2008 | HP Pavilion dv4000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
