Question about Samsung LTN226W 22 in. HD-Ready LCD Television
Speaker Noise when volume turned down LTN226W Samsung
The speakers on my Samsung LTN226W are emitting sound as if I was not on a channel (ghost noise). This is occuring when I have the volume turned all the way down.The "ghost noise" is also quite loud. I am using an external stereo for sound and have this set up for a long time without issue. Any help would be appreciated.
  • performax Nov 09, 2008
    Can I open up the unit and disconnect the speakers? I've never actually used them. Also when I look at the back of the TV I only see one screw at the bottom of the unit.
  • 152 Answers
This is due to leakages in your internal circuit... this generally happens due to aging... the part which has suffered damage has to be found and replaced... but this part can be identified only physically testing the voltages and currents on the internal circuit...
Posted on Nov 09, 2008
  • Anand Srinivasan
    Anand Srinivasan Nov 09, 2008
    hey opening it up and disconnecting them is fine... do it only if u have done it in the past else it might prove a bad idea... generally there would be some glueing and stuff when it comes to speaker so i fear there would be more than the screw you are seeing...
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
The speaker make a buzzing sound
that's called breaking up or overloading it means that the speaker is being asked to play louder than it was designed to play!! this will ruin the speaker at all volume levels if allowed to make that sound for very long..advice? lower the volume till that noise disappears it's not a product fault it's user error advice turn it down or buy a more powerful unit to achieve the volume you want/need
Dec 12, 2013 | JBL On Stage Micro Speaker Dock for Apple...
Left channels not working
Check out the left channel amp stages - your issue is there.
Apr 30, 2017 | Yamaha RX-V395 Receiver
Left speaker terminal on the sub doesn't work properly
This is common with the type of powered speakers where the IC package that drives the speakers (the amp) is getting to hot and shuts down. Usually it is damaged and not reversable. There is a lot of reports of this same model loosing one channel or playing quietly. The air most likely cooled the chip down until it heats back up.
Jan 15, 2009 | Logitech Z-2300 Computer Speakers
Volume on tv stopped working
HIT MENU, GO TO AUDIO (SPEAKER PIC) SCROLL DOWN TO "2ND PAGE" AND SELECT SPEAKERS ON. AND YOU MAY NEED TO ALSO SELECT SBS ON
Jul 16, 2008 | Toshiba 36AF42 36" TV
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
Apr 07, 2008 | NAD C350 2-Channel Amplifier
No Sound - LCD Volume says 99
Found a solution that works. Power down the receiver. Unplug it from the wall. Wait 10 minutes. Plug it back in and power it back up. Worked like a champ to fix this exact problem with my TX-SR601.
Nov 10, 2007 | Audio Players & Recorders
Samsung LTN226W 22 in. HD-Ready LCD Television Logo
374 people viewed this question
Henry  Thomas
Henry Thomas
