Question about Maytag MER6872BAS Gemini Electric Kitchen Range
ELECTRIC STOVE MATAG MODEL#MER6872BAS
Im getting F1-8 message the to burners work fine the ovens dont work can anyone tell me what the problem is? thank you.
  • frankr1500 Nov 09, 2008
    thank you will check
    President:
  • Maytag Master
  • 2,651 Answers
F1:-8 Keypad Shorted Check to see if steam or other moisture is getting into clock assembly. Replace keypad if necessary
Posted on Nov 09, 2008
Gas stove with electric ignition (oven stopped working)
the electric ignition is bad and needs replaced in oven. I had the same problem a few months ago and it was the ignitor for the oven. if replacing it yourself, be very careful with ignitor, it is very fragil. do not touch ignitor itself, hold on to it by the base of it. they are not that hard to change.
Jan 31, 2010 | Kitchen Ranges
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Oven not lighting
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
May 06, 2009 | Amana ACF3325AS Dual Fuel (Electric and...
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Oven
Neal, the only thing I can bring up with that model number is a built in wall oven. You said the top burners work fine, so we are missing something here. Sounds to me like a stuck or shorted keypad. Catriver..post back
Sep 14, 2006 | GE JKP15 Electric Single Oven
Maytag MER6872BAS Gemini Electric Kitchen Range Logo
222 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
