FixYa.com
Tags:
Fujitsu Siemens Siemens Business Line 19P4 19
Monitor deosnt turn on (by 7 users)
posted by Systema on Oct 24, 2006
I have had my monitor for quite some time now and recently i got a new graphics card and the monitor doesnt turn on it just stays black with an orange LED when i turn the pc on. but everything else runs fine.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by dreadhead, posted on Aug 17, 2008
I have nearly the same Problem.
My Monitor turns also black but, the LED is green so it gets a signal. When I use it with another Graphics card then the Monitor works just as he should do.
The Graphics card I use (when it doesn't work fine is: NVIDIA GeForce 5200FX.
Comment by chimtellgo, posted on Aug 04, 2008
Comment by LINDA81, posted on Aug 03, 2008
WHEN I TURN ON MY PC THE MONITORS TURNS ON BUT ALL IT SAYS IS NO SIGNAL IN RED, WHAT DO I DO?
Comment by Guest, posted on May 29, 2008
wHEN TURN ON DE IT DOESN`T WORK
Comment by Hilt, posted on Mar 01, 2008
I have a Hyundai S770 monitor. I shut down my computer the other day the same way I have always done in the past. When I came to turn on my computer ahain the computer booted up fine and the on LED on the monitor came on but the monitor stayed blank and wont turn on. If I press the monotor on / off button the monitor clicks a few times but still wont switch on. I don't beleive the monitor is faulty. Are there any solutions out there?
My e-mail address to reply is:
hilton_spark@hotmail.com
Thank you and regards.
Hilton Spark.
Best Solution
posted on Aug 21, 2007
Helpful (85)
BNUTZBCRAZY
Rank:Master Master
Rating: 89%, 33 votes
OK PEOPLE I GOT THE SOLUTION TO THE MAG INNOVISION LT916S GOING BLACK AFTER ANY LENGTH OF TIME BEING ON!!! I JUST REPAIRED MINE TODAY! THE PROBLEM IS THE CAPACITOR BANK IN THE POWER SUPPLY PART THERE ARE 6 CAPACITORS I HAD A FEW LEAKY ONES "NOT GOOD" THE CAPACITOR SPECS ARE AS FOLLOWS 470UF 25V 105 DEGREES C MEANING 470 MICRO FARAD/25 VOLTS I HAD A VERY HARD TIME FINDING THE 25 VOLT ONES SO I WENT WITH 470UF/35V 85 DEGREES C THEY MIGHT NOT LAST AS LONG AS THE OTHERS DUE TO THE TEMP RATING HOWEVER, IM THINKING SINCE THEY CAN HANDLE UP TO 35 VOLTS IT SHOULD EVEN OUT AND HEY, ITS WORKING SO FAR SO GOOD!! THE CAPACITORS ARE FROM UNDER A DOLLAR A PIECE TO A COUPLE BUCKS EACH. THE CAPACITORS HAVE A BOLD LINE RUNNING UP ON ONE SIDE INDICATING THE POLARITY. BOLD LINE SIDE IS "-" SIDE WITHOUT BOLD LINE ITS "+" THE POWER SUPPLY BOARD HAS THE POLARITYS STAMPED ON THE BOARD ITSELF UNDER EACH CAPACITOR. EASY 30 MINUTE FIX IF YOU ARE LEARY ABOUT SOILDERING, FIND A FRIEND THAT KNOWS HOW TO. ITS REALLY NOT THAT HARD THOUGH AND YOULL HAVE SOME DECENT ROOM TO WORK WITH. I PROMISE WHEN YOU OPEN IT UP YOU WILL ALMOST CERTAINLY SEE AT LEAST 4 OF THE 6 CAPACITORS BULDGING AT THE TOPS MAYBE EVEN LEAKING BROWNISH STUFF. DO YOURSELF A FAVOR THOUGH AND REPLACE ALL OF THEM WHILE YOUR IN THERE "THE SIX BIGGER ONES ONLY" IF ANY OF YOU NEED FURTHER HELP OR ANY OTHER QUESTIONS ABOUT THIS PROJECT PLEASE FEEL FREE TO EMAIL ME AT BTLEE26@HOTMAIL I DAMN NEAR WENT CRAZY TRYING TO FIND A SOLUTION ON HOW TO FIX THIS THING SINCE I SPENT OVER 300 BUCKS FOR IT NEW. AND IM BY NO MEANS A EXPERT WHEN IT COMES TO THIS STUFF BUT I DO KNOW A FEW THINGS. AS IM SURE MOST OF YOU DO. TAKE CARE YOU ALL AND THANKS TO THE GY WHO MENTIONED SOMETHING ABOUT CAPACITORS BEING BAD IN HIS!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 24, 2006
Thanks for Trying (70)
sandrew
Rank:Wiz Wiz
Rating: 83%, 4708 votes
Did you uninstall your old graphics card driver first,if not try starting up in safe mode(pressing F8 on boot up)and hopefully you can uninstall your old driver through ADD/Remove programmes.
Try booting again and install drivers from instalation CD.
If you did not have an old graphics card and you were using your onboard graphics display, you will have to connect back to the VGA port you previously used and enter the bios(pressing F2 or DEL on boot up) and enabling your AGP card as the primary display device in the 'Advanced Chipset Features'.
Press ESC and it will ask if you want to save settings on exit ;press 'Y'.
Connect monitor back up to your new card,boot up and install drivers from your installation CD.
Solution #3
posted on Feb 27, 2008
Not Rated (0)
elilbitz
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
State a fix without using PCU! Can't read it if monitor doesn't come on
Comment by elilbitz, posted on Feb 27, 2008
FIXED IT!!!!
There are two ports for the video on thack of my pcu!
Solution #4
posted on Feb 20, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
My monitor canot power on . I need service centre in abudhabi.
Solution #5
posted on Jan 02, 2007
Not Rated (0)
mookman
Rating: 0%, 0 votes
If your monitor has svideo out or in plug it to a television or monitor with svideo capability.Then go to the desktop and right click on the screen click properties so that the display menu comes up click settings tab and look to see if there are two displays featured click on 1 and see if there is a check mark as the primary display and make sure the other box is not checked.Depending on if you are using two monitors you should leave it checked.Sometimes the drivers default to the svideo output.Hope this helps.
This Problem Also Relates To: HP vs19 (Silver) 19" LCD Monitor HP Pavilion F1503 15 in. Flat Panel LCD Monitor HP 91 (White) 19" CRT Monitor HP Compaq WF1907 Monitor Philips 170S4FG (Light Grey) 17" LCD Monitor Philips 190B6CB/27 19IN LCD BLK Philips 202P40 22" CRT Monitor
Can you Help with these Monitors problems?
Monitors
3g_technology
i want to know that what is... Answer This...
Monitors
my monitor reads not optimum...
it stays on for 20 seconds then... Answer This...
Monitors
monitor flashing from power...
monitor flashing from power... Answer This...
Monitors
MAG Innovation Moniter Model...
I have a four year old moniter... Answer This...
Fujitsu Siemens Siemens Business Line 19P4...
no display
i have a gigabyte... Answer This...
6 Other Users Have The Same Problem - Continued
Comment by walter30265, posted on Feb 06, 2008
the monitor just stop working .It wont come on .
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
