Question about Mitsubishi WS-55807 TV
Mitsubishi 55" WS-55807 problem--saw you try with someone else
Hey, you look like a guy with a lot of answers. I have the same problem this guy posted where the screen goes blank after a few minutes--you wrote you needed more info, and i didn't see him reply...if you can help me i'll give all the info you need.
so: the tv will have a picture for a minute or so, longer, then it won't. hitting the side brought the picture back, but now it's not doing it so much. unplugging it and moving it to unplug it, and plugging it back in, the image comes back, but then it disappears again. sometimes it will stay for a while and all's fine; sometimes it needs to be tapped every five minutes. now, it looks like there's an image struggling to get back on the screen, and when i press the "format" button on the remote, it will go from dark black to a more active black, sometimes bowing down at the top with some white lines. usually, if the screen looks like it's actively blank, the taps work to get the picture back.
so that's that, please let me know if you can help.
and THANKS!!!
--brandon
  • sdsimons Nov 22, 2008
    power light comes on then goes off in about 2 seconds.
techman
  • 3130 Answers
SOURCE: Mitsubishi WS-55807 "Bow-Tie" Problem
If your not a tech, its highly advisable to not even open the set because of the high voltage and x-ray radiation issues. Now if your a technician ,you gonna need to get a service manual, Look up the convergence circuit, Find the two or three convergence driver ics, find the b+ feed resistors to those ic, and order the exact replacement parts. if you dont replace all at once, and with exact replacements, you will be in the same boat a few months down the road. This is not a repair a handi-person should consider doing as even if you get the ics replaced, your gonna need to do some minor or could be major convergence alighnment and your gonna need a cross hatch generator to do this. This repair should cost ya about 300 to 400 bucks? Sorry man Good Luck
Posted on Jun 14, 2006
  • 192 Answers
SOURCE: Mitsu 55'' screen
The convergence ICs probably have a cracked solder joint on the foil side of the circuit board. Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. To fix this yourself, you will need to be able to identify the two convergence ICs (STK392-570), have a basic knowledge of electronics and be able to use a soldering iron.
Posted on Feb 18, 2007
techworm
  • 56 Answers
SOURCE: Mitsubishi WS-55807 Picture goes out ... clicking
flyback
Posted on Nov 12, 2007
SOURCE: Mitsubishi model No. WS-55807 - In need of schematic please
I have a WS-55807 that will not power up. When the power button is pressed I hear a click from the back of the set, the timer light comes on and 3 seconds later I hear a click from the back of the set, and the timer light goes off. I started checking power to the unit with a voltmeter. For those intersted I have attached scematics: I verified that the PCB main fuse is good and there is 120V at point PT. 9f453c1.jpg
From what I can tell is happening, the power button is pressed and the P-ON transistor is given a signal to conduct which causes K9A50 to close. K9A50 opens after about 3 seconds.
I am looking for other troubleshootinng steps. I have checked fuses F9A01 and F9A06, both are good. What are some other things to check for? Where does the P-ON signal come from?
In the switched supplies regulator circuitry I found fuses F9A04 and F9A05 blown (denoted by red lines thru components). I jumpered around F9A04 and F9A05 with good 5A fuses and the TV powered on. However when the set was plugged into an outlet there was a huge power draw (sparks from the outlet).
After jumpering around the blown fuses, the TV stayed powered on for about 30 sec and then powered down. I pressed the power button a few more times and the same result. The TV stayed on for only 30 sec.
I pulled the middle PCB whichs holds these circuits and I found the
D9A60 diode open and IC8C02, one of the convergence IC's fried. I don't know if these were like this before or after jumpering.
I replaced all bad components and I am back to square one. The K9A50 relay stays closed for 3 sec and the set does not power on any further.
Comment by TV_ITGuy, posted on Dec 19, 2007 Thanks for the advice ctf1800. I have read several posts that speak of the DM unit. I have looked in the back of my set and the DM unit is not in the location shown in the pictures. dcb8806.jpg
As I hope you can see in this picture, there is no DM unit to the far left, just open space. Also the service manual for the V17 chasiss does not speak of a DM module.
I checked the reisitors on the output of IC8C02 which are a couple of 3.9 ohm resistors in parallel. When I test them I get approximately 1.9 ohms, which is what it should be with them being in parallel.
Please let me know if I am off base on any of this. Thanks Comment by TV_ITGuy, posted on Dec 19, 2007 Also, I have replaced both of the Convergence IC's when I replaced the fuses and diode. postsolution.gif Post Solution
addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Best Solution posted on Dec 19, 2007 2%20stars.png
ctf1800
Rank:wizard_s.gif Wiz
Rating: 84%, 2716 votes
first off you should replace both convergance IC and check the resisters coming off the output if any of the resisters are bad it will trash the ic on trying to power up.
i would also replace the caps in the DM section
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://chrisandnat.com/projects/blinkingtv/blink.htm
Comment by ctf1800, posted on Dec 20, 2007 there are six fusible return resistors ranging from 1.5, 1.8, 2.2, 2.7, 3.3, 3.9 Ohms. I would lift one side of the resister out.
check for any caps that look puffy and check the horz. out put transistor.
Rating Locked! (?) TV_ITGuy has rated this solution as Thanks for Trying
Hope this helps fortuna55@aol.com
Posted on May 29, 2008
  • 927 Answers
SOURCE: Mitsubishi 55 inch Digital TV WS-55807
Good Day; This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Posted on Sep 25, 2008
Close captioning stays on all the time.
if have remote or tv bo to menu scann threw it find captions and set off this may help
Mar 24, 2009 | Mitsubishi WS-55807 TV
Mitsubishi
i just sent the response to your email address
Sep 16, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55807 turns on but then powers back down after a few seconds
Good Day;
The fuses tell you that circuit has failed and was drawing too much current. No other test is needed.
Good Luck, big Irish.
Sep 04, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS 55807
Good Day, Girl 1;
Hey, Girl 1, I have four girls not counting my wife . So, helping you may be difficult. Just kidding!
I would highly suspect that you have fluid on your TV's PCB's (printed circuit boards).
So, at this point that you should call an Authorized Service Center and have them give you an estimate before any repairs are performed.
If you want to try repair on your own e me at mmrkcar@yahoo.com.
Thanks you and Good Luck, big IRISH.
Aug 09, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
WS-55807 doesn't power on
1) Check all fuse devices in power supply
2)Pc board with transformer possibly defective.............T.
Nov 07, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubish WS-55807 HDTV 55" 1080
RGB picture guns ( CRT's ) are ok. Your set needs a common
convergence circuit overhaul requiring replacement of two IC's,
part # STK392-570. Usual cost about 400.00.........T.
Oct 31, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Sep 29, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi ws 55807 have the blinking lights problem and not powering on
Yes on some sets are a bit differant depending on the model number there is still a DM board. The disassembly is a bit different and the service manual will describe how to take apart the TV set to get to the DM board. The repair is the same for the DM board. I am sorry but I do not have the the service manual but one can be downloaded here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=WS55807 Good Luck
Jun 20, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55807 TV Logo
3,368 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
