Question about Radio Communications
Motorola T5500 Scanning problem
Hi , I got a problem with my Motorola T5500, when I press the scan for all the channel the radio seen to be picking up only static noise and will stop at some channel.
Could this be a hardware problem?
  • Radio Commun... Master
  • 1,654 Answers
Most likely it is stopping at a channel which has RF (radio frequency) activity. The activity doesn't have to be another radio with someone talking. It could simply be something transmitting on the same MHz. The only way to know for sure is to try the radios in a different location (as in moving away from the problem). If you want to avoid this "noise" you can turn on your interference eliminator, and it should block out anyone transmitting on the frequency (unless they set their interference eliminator to the same code as yours.)
If the noise continues when you try the radios in a different location (more than 5-10 miles away), then you will have to investigate a problem with the radios themselves.
Posted on Nov 10, 2008
RADIO WILL SCAN BUT WONT STOP ON EACH CHANNELL
Contact Motorola Solutions.
Get Support
Mark Motorola Mobility Support
May 20, 2014 | Motorola GP360 Two Way Radio.
4 radio communication
Pls swotch off qt & keep the same channel also keep all privacy codes to 0 , try ur set it will get connected to rest 3 , do not forget to keep privacy code 0
Jun 05, 2013 | Motorola Talkabout T5500 (7 Channels)...
Voice recognition on motorola t5500
That means that it will Transmit, like pressing the "Talk" button, BUT ONLY when it hears the "Voice" it was "Trained" on. So this is so No-one else could use this unit. With this method. You "Identify" yourself, and after that every-time you speak, the Transmitter is keyed, and the channel is opened and the voice sent, when you stop talking,it goes back to receive, again. Some are less sophisticated, in that they are really a "Sound Switch" and when the unit "Hears" a "Voice" it, switches OFF receive, and ON the transmitter, and Transmits the audio out.
Apr 15, 2010 | Motorola Talkabout T5500 (7 Channels)...
Need manual for motorola t5500 talkabout
the manual for the requested product can be found by clicking this link (you may have to temporarily allow pop ups)
T5500 Manual
The manual is in PDF format.
Please don't forget to rate my service, thank you.
Aug 27, 2009 | Motorola Talkabout T5500 (7 Channels)...
Motorola T5500 - Continuous transmitt with headset
1) Be certain the radio is shut off when plugging in the audio device.
2) On most units, press the PTT button to turn off the VOX feature.
3) If you are not planning to use VOX. Turn the VOX feature off. Follow the programming instructions which came with the radio.
Hope this helps.
Jan 15, 2009 | Motorola Talkabout T5500A (14 Channels)...
Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Oct 23, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Motorola T5500 - can't start scan !
Hello AHAPXUCT,
To start scanning on a Motorola TalkAbout T5500 all you have to do it press the MON button for a full second and then release it. The radio should automatically being scanning the channels for activity and stopping on any received signals.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 10, 2008 | Motorola Talkabout T5500 (7 Channels)...
I have a problem
Normally in a Motorola T5700, to set a specific channel to monitor (and reply to) called your working channel, you press the Menu (center) button and the current channel shown in the display will flash. Press either the + or - buttons to change to your desired channel number which should be identical to both radios. Press the PTT button to save.
Likewise, both radios must have identical Interference Eliminator Code. To set code, press Menu till the code display blinks. Press + or - to select code. Press the PTT to save. To disable the code, select 0.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 22, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Scan
If it does- yes, it will pick up other 2 way radios.
Jun 01, 2007 | Motorola Talkabout T5500 (7 Channels)...
Motorola Talkabout T5500 Menu button doesn't work
I think you radio has a problem and will need to be checked, rapaired or replaced.
Dec 15, 2006 | Motorola Talkabout T5500 (7 Channels)...
Radio Communications Logo
132 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
