BenQ FP71E  17" LCD Monitor
Problem for BenQ FP71E (Black, Silver) 17" LCD Monitor
Screen goes white
By entropy on Oct 24, 2006
A recurrent problem that is now happening more frequently. In the middle of working the screen goes totally white. Used to be able to fix by turning monitor quickly off and on, but now can take up to a dozen attempts, which can't be doing the monitor any good. Does anyone have any idea what is causing this?
Comments:
Oct 24, 2006
- Have checked the video connections, which seems OK. Also, jiggling the connectors during a "white out" has no visible effect.
Oct 25, 2006
- Thanks, I'll give that a try.
Feb 01, 2007
- Updating driver made no difference. Also, problem still there when connected to different machines. Not keen on the smacking solution, even though it would relieve the frustration. Have taken it to the Benq service centre today - hopefully they will have a fix.
I'll post back when I find out what the problem was. Thanks all.
Feb 09, 2007
- Repair technician said they "did some work to the power supply" to fix this problem. So far so good - hopefully it's a long term fix.
Mar 07, 2007
- Well, wish it was better news, but the "fix" lasted about a week. Old problem has resurfaced, so back to the repair shop it goes :(
Same Problem
May 07, 2009
-   My screen had kept going white and now just a part of it does so i get a big white box that keeps appearing with only arrows at the right hand side of it that do nothing- it's doing my head in! What can i do? -   Guest
May 21, 2008
-   I also have the problem where my screen will go white (possibly grayish white) for no apparent reason. Starting a few week earlier, I noticed that very occasionally the display would briefly (for less than one second)change to a "garbage" display. The change was so brief in duration, I was not able to get a good view of it.
Now, after using the computer for a period of time - I haven't timed it, but certainly less than an hour - the display changes suddenly to this gray-white color. So far it appears that turning the monitor power switch off and leaving it off for a while allows the display to return to its normal view, but only temporarily.
This is a Dell 15 flat panel monitor model E151FPb. Date of Mfg is May 2003.
DenDiMarco@Verizon.net-   DenDiMarco
Apr 01, 2008
-   CPD-G410R 19 in.CRT Conventional Monitor. prblem is brightness is high and it not controlled by adjusting knobs or contrllers.-   Guest
Feb 27, 2008
-   same problem here, the screen turned white i if i turn it off and on again, same problem but it flashes, like 3 second white, 3 seconds black, 3secondwhite,etc....-   Guest
Jan 07, 2008
-   I have a 15" dell monitor purchased in 2002. In the last 6 months the monitor will go completely white while I am using it. Usually turning the monitor off fixes it. Othertimes I have to use the degauss button (reset).
I have not done any other troubleshooting.-   davidyin
Best Solution
posted on Apr 09, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same montior. It has nothing to do with drivers, cables, graphic card, etc..it is monitor itself. You can check yourself by unplugging the monitor from computer and turn it on by itself. The self-diagnoisic should come on, but it doesn't. It is just pure, brillant white light emanating from the monitor. It come and go randomly. It is not back light since it shines quite brightly, and it is not pixel related, or scanning related. I believe it has to do something inside hardware that control information between cable interface and screen.
Solution #2
posted on Mar 08, 2007
Helpful)
ct113
Rank: Apprentice
Rating: 92%, 8 votes
i have it the control panel cable to the main board is improperly soldered can be fix by anybody who is an expert solderer
Was this helpful?
Yes
No
Solution #3
posted on Oct 24, 2006
Somewhat Helpful)
sandrew
Rank: Wiz
Rating: 83%, 5940 votes
Certainly sounds like a driver issue, check your cards/onboard graphics make; and download latest drivers.
Are you able to pinch a monitor off a friend to try and pin it to a monitor or graphics problem?
You may have done this but apologies as i did not read initial thread.
Was this helpful?
Yes
No
Solution #4
posted on Jun 09, 2009
Somewhat Helpful)
zachplatts
Rank: Apprentice
Rating: 75%, 1 votes
Try opening the monitor up, and checking for bad solder joints on the VGA connector. This is actually a relatively common problem, when the monitor gets hot from use, the solder joint begins to fail until it cools down again.
Was this helpful?
Yes
No
Solution #5
posted on Nov 01, 2006
Somewhat Helpful)
TaLoN
Rank: Apprentice
I am having the same problem so if anyone can offer some help that would be great. i have tested a new monitor and it works fine, tried old monitor on another computer and same problem, i have the same model entropy has!! i called sylvania and they say they have not heard of any problems with it!! im going to make a stink because i have had the monitor 14 months!! please help
Was this helpful?
Yes
No
Solution #6
posted on Apr 28, 2009
Not Rated)
tremblay518
Rank: Apprentice
Rating: 0%, 0 votes
I had exactly the same problem with a Samsung 204b LCD monitor. The problem was just a little fuse on the LCD board. Look on the board attached to the LCD (not on the power supply or video controller board) and the little fuse is usually identified on the board as F1 or something like that. The fuse is really really small, around 1mm per 1mm. You can replace it or just by pass it with a little solder point.
Was this helpful?
Yes
No
Solution #7
posted on Sep 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my xerox goes whitescreen too. Works for a bit then just goes off
Solution #8
posted on Aug 27, 2008
Not Rated)
skeeter564
Rank: Apprentice
Rating: 0%, 0 votes
Hi. Im having this same problem but w/ a ViewSonic VX-800, connected to my MSI 8500GT graphics card. I uninstalled my graphics card and connected my monitor to the motherboards VGA port and so far so good. With the graphics, I would get the white blank scrn. like 35-40 minutes into use. So i assume my video card is the problem. RMA time
Was this helpful?
Yes
No
Solution #9
posted on Aug 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
try to smash it :-), it works. at least for a while. its not a problem with drivers or something else. there is hardware problem inside monitor. Maybe some of technitians should know.
15" PackardBell monitor, year unknown.
Sry 4 bad english
Solution #10
posted on Mar 05, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I sent this to geeks on wheels. They say that the video card is not the issue. Seems to be a heat related issue. definetly the lcd monitor. I have been turning the monitor off when not in use and watching the time as it stays on. So far, no problems. I haven't looked at the soldering. I don't want to go there.
Solution #11
posted on Feb 27, 2008
Not Rated)
dickde
Rank: Apprentice
Rating: 0%, 0 votes
Had similar problem with the dell monitor
Found that it was a dry solder joint
Looked at the control board and just about resoldered anything that looked pitted or off color
now works a treat 6 months now
Was this helpful?
Yes
No
Solution #12
posted on Oct 18, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
That problem is a bad video processor in the monitor failing.  The fix is to replace the main board.
Solution #13
posted on Jul 25, 2007
Not Rated)
rurick
Rank: Apprentice
Rating: 0%, 0 votes
hello im a kwak pc technician from the philippines , my lcd monitor screen whitens too, and i solved the problem its in some kind of processor board at the back of lcd monitor it keeps overheating maybe because its overused,
so i cut a square opening on the back cover (plastic)and install a 4inches pc fan, now its working good the bigger fan the better try it don't judge. :)
Was this helpful?
Yes
No
Solution #14
posted on Feb 25, 2007
Not Rated)
Andromeda1
Rank: Apprentice
Rating: 0%, 0 votes
My Xerox is doing the same with a HP Media center. The problem is that the xerox does not like being turned off by Windows power management. I have altered it now so that windows never turns the monitor off and the problem has dissapeared.
Was this helpful?
Yes
No
Solution #15
Not Rated)
Andromeda1
Rank: Apprentice
Rating: 0%, 0 votes
Was this helpful?
Yes
No
Solution #16
posted on Feb 17, 2007
Not Rated)
amar
Rank: Apprentice
Rating: 0%, 0 votes
control panel lock
Was this helpful?
Yes
No
Solution #17
posted on Feb 09, 2007
Not Rated)
Joelcress
Rank: Guide
Rating: 92%, 3 votes
http://f1.pg.photos.yahoo.com/ph/jsbaron...@
sbcglobal.net/detail?.dir=/My+Photos&.dnm=ex1
.jpg
Was this helpful?
Yes
No
Solution #18
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It's Sony crap at work....it's not the drivers and it's not the PC card. It's a faulty connection inside:
http://f1.pg.photos.yahoo.com/ph/jsbaron...@sbcglobal.net/detail?.dir=/My+Photos&.dnm=ex1.jpg
Solution #19
posted on Feb 02, 2007
Not Rated)
Cronic2007
Rank: Apprentice
Rating: 0%, 0 votes
Hey Talon I am going to be with you bud, I am going to raise a stink about it too and if enough of us have this problem they will have to do something about it, maybe not with ours exactly but maybe with future models.
Was this helpful?
Yes
No
Solution #20
Not Rated)
Cronic2007
Rank: Apprentice
Rating: 0%, 0 votes
sorry this is not a solution but I couldn't find a way to post otherwise.I am having the same problem with mine. I have been all over looking for a solution but Advueus Tech support leaves ALOT to be desired. Please post what you found out about it, I was thinking about taking mine to a shop also. I have just started getting the white screen within the last 2 weeks and I can still get it back to normal from the off and on solution but I have quit doing it and packed away the screen(going back to a 19" CRT I had locked away). I know it is not the graphics card I have all the most recent drivers from Nvidia. I have hooked the screen up to another computer with the same results. I am hoping it is not the screen going bad, I have not owned it that long. Good thread though and keep me posted on the outcome from the shop and mine might be seeing one soon too. Thanks.
Was this helpful?
Yes
No
Solution #21
posted on Feb 01, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
None of these solutions will work. I have the same problem, the only thing that brings the monitor back is if I smack it on the side. I read somewhere online that this is due to a loose wire/bad soldering.
Solution #22
posted on Jan 21, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If you are using an LCD display, this is ussually indicative of the power electronics in the monitor being bad. Some places can fix that for ~$90-$100 but I'd just go and get a new monitor. They are pretty cheap these days.
Popular Solutions for BenQ FP71E 17" LCD Monitor
Questions and Unsolved Problems for BenQ FP71E 17" LCD Monitor
Do you recommend BenQ FP71E (Black, Silver) 17" LCD Monitor?
Answer
Answer
my laptop screen goes white everytime i close down a problem
Answer
My BenQ FP71E monitor has to stay on all of the time. If it goes into sleep mode, when I move my... (More)
Answer
My monitor suddenly goes white in the middle of working or browsiing. doesnt matter if the machine... (More)
Answer
fixya shows up along with some other sites but with awhite background
6 Other Users Have The Same Problem - Continued
Comment by bs133140, posted on Nov 15, 2007
Have a similar problem, there is no problem when the monitor is turned on, but when it's turned off by the button, or goes to sleep, the screen turns totally white,
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For BenQ FP71E 17" LCD Monitor:
Top Monitor Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
