Ok are neighbor gave to us and said that the power light flashes on and off and that the picture and sound did not work. and we believed them. so we lugged it up the street and into are house and turned it on and like what they said it did not work .so i was wondering what might have happened and how could we fix it. cause it is a 48 in tv
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
SOURCE: tv power button flashing no picture or sound
Short in powersupply check secondary fuse and all other fuses too. Were there a color problem before this/ Because most of these set have convergence problems. The amps May need to be changed and resistors around them.
SOURCE: "52" RCA Scenium DLP; No Picture and the buttons flash on and off
On the back of the TV, you'll find the Access door to your lamp. Unplug the TV from power, and remove the screw on the access panel. Inside you'll find 2 additional screws holding in the lamp housing assembly. Remove the screws, then the lamp assembly and visibly inpect it. You'll know if the lamp is defective, it will have obvious damage. If so replace with part # 260962, you can acquire this lamp for arround 100 dollars off ebay, or 262.00 direct from RCA.
The red light flashes 5 times then pauses and flashes 5 times again????? Any ideas?
SOURCE: standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
