Hi....
My Xerox DC440ST Network/print controller only can boots up to 70% only even i reboot it for several time.......
Anybody can help or advice me what can i do.....
Thanks!!
JP
When it boots to 70 percent and faults out, one of 2 things.
If you look in the fault codes, or if one is displayed. If it is a 07-11 then you have a bad hard drive in the network area, or as Xerox refers to it as the ESS module, That is the most likely cause.
Secondly maybe the ESS software is corrupted and needs to be reloaded.
I more suspect the hard drive. It's not an uncommon failure.
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
Spool Initialization
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
HDD Initialization
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
ESS NVM Initialization
CAUTION
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
If these do not work the system software needs reloaded or the ESS network board needs to be replaced.
THE MACHINE REBOOT WHEN THE CONTROLER\NETWORK 25% BOOT
