This happens after setting for a week.
SOURCE: Carb will not shoot gas in engine w/primer.
Hi, check the primer rubber too see if there is small leak in it. and replace the gas tubes inner and outer
If this doesn’t work for you please write back. Thanks,
SOURCE: craftsman lawnmower carb pours gas
One of two problems. your needle and seat is leaking or the float has a hole in it
SOURCE: no gas to carb on toro gts
Carb needs to be cleaned/repaired. Without knowing model number of the engine, that's all the info I can give you.
SOURCE: Lawn Boy Silver Edition, When Primed, it starts, Then Stops? help
High speed jet is plugged. You'll have to disassemble the carb
SOURCE: 4.5 hp Briggs& Stratton push mower will not run
You need to rebuild your carb. The diaphram in the carb has gotten hard and is no longer acting as a fuel pump to pump the fuel to the carb. Get a rebuild kit and a compressor (for compressed air) to blow out the jet passages. It is an medium to easy job, just watch the small parts. ----------------------------------------------------------------------------- Hint: Before you remove your fuel/air jets, bottom them out first and count the number of turns it takes to bottom them out and mark it down for each fuel/air jet. When you go to reinstall the fuel/air jets bottom them out and then back them back out to the number of turns before removal. That way the fuel/air jets are set to the right number of turns when it was running right. Good Luck, I hope this helped Please rate me...Thanks
I bought needle/o-ring($21)and installed in carb.(1-2hours)---did not help problem at all.
when replacing the needle and did you clean out the jets and pasages
I found the Throttle/Choke cable out of adjustment.(not letting the choke completely
close off at startup)--this adjustment seemed to correct the problem.
