Question about Dryers
Noise Dryer makes a loud squeaking rubbing noise. Sounds like maybe a belt. Kenmore 80 Series
How to replace a fan impellar on a zanussi
Posted on Nov 22, 2008
Kenmore 80 series, drying well, but really loud noise, kind of high pitched like airplane sound. Ideas>
Check your belt for ware and watch toe idler wheels, they could wear out and make that kind of noise.
Sep 23, 2011 | Kenmore 63942 Dryer
My Kenmore 80 Series gas dryer is making a loud thumping noise when running. It appears to still be drying, just making a very loud noise. What could this be? If it's the roller, approximately what is the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 04, 2011 | Dryers
Kenmore 80 series dryer makes loud humming noise when it is drying clothes think it may be a belt that needs to be replaced
More likely is that your motor is going bad...that will make a very loud hum when it starts to go...
DryerRepair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 07, 2010 | Kenmore 65924 Electric Dryer
My dryer is making a very loud noise when it runs. drum is still turning but it sounds like the belt is rubbing
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 03, 2010 | Maytag Dryers
I have a Kenmore 80 series dryer. When we start the dryer the unit gets a loud noise it will run through a few loads but then the noise will get louder then the dryer will cutoff.
heatman101
Oct 20, 2010 | Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
My series 80 dryer squeaks
do not lubricate anything in a dryer you will damage .locate the the squeek if it is coming from the rear of the unit most likly need to replace the drum support or wheels if its intermittant and has a squeek squeeek noise that either gets worse or goes away when the dryer heats up the tensioner pully or the moter berrings are bad
Aug 10, 2009 | Dryers
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Loud Squeaking Noise kenmore gas dryer 80 series
You need to change your drum rollers. To get to them you take the dryer apart from the front not the back. There are 2 screws where the filter goes in on top. Then pull the top toward you and up. Then remove the 2 - 5/16 inch screws on each side of the front panel about 2 to 3 inches down. Then pull the front up and out. Then you will see everything. Replace the belt, drum rollers, and idler making sure to oil each as you re-install them. Then put back together and your on your way.
Dec 07, 2007 | Kenmore 63942 Dryer
Dryers Logo
304 people viewed this question
Top Dryers Experts
