Question about Nokia 6230
Water hi my phone fell into the water, I try to dry it with a hairdryer and the battry is still working but my phone does not come on do I need to replace my phone or can I have it fixed.
Water damaged,not charging--nokia1110
my nokia1110 was water damaged.still after that also somehow it was working bit properly..
then LOCAL MODE msg came in and went away after a while.
Later when battery got empty and i tried to recharge it was showing
"NOT CHARGING"
what's wrong,what shall i do?
Thankyou
Posted on Apr 23, 2008
    Sergeant:
  • 452 Answers
Take off of ur handset's body and put ur phone in sun for at least 2 hrs , it will solve ur problem
Posted on Oct 10, 2007
  • gizmo plus Oct 10, 2007
    Take off of ur handset's body and put ur phone in sun for at least 2 hrs , it will solve ur problem And if still the same problem persists then chip might have gone, and confirm from vendor about the internal faulty parts of hndset like if display is faulty or not.? same with other parts.
  • 44 Answers
Hi m8 take the easy way out send your fone to http://www.mobilephoneservicecentre.co.uk/ these guys are good at what they do and dont charge anythin for havin a look an in most cases are very cheap hope this helps
Posted on Jun 26, 2007
Get a lighter fluid and put it on the mother board of your cellphone and slowly brush it with a toothbrush.. after put it directly near a flourecent lamp for 10 minute.. and put your fone is good a new...
Posted on Jan 04, 2007
    Problem Solver:
  • 9 Answers
Yes it can be fixed. it has to be rinsed in some chemicals to take the water out, thereafter need to load softwmare
Posted on Oct 26, 2006
Cordless drill fell into water , now it won't work.
IF something with water happend first disconnect immediately the battery as soon as possible and make as soon as possible dry inside the battery cells dry with an hairdryer to use as soon as it can be for the batterycells.
the body must also be dried but is in priority on the switch after you have dried the switch spray it with wd40 after drying.
Dec 26, 2015 | Milwaukee tools 2653-20 M18 FUEL 1/4"...
Dark screen after being dropped in water
try drying it with a throughout hairdryer ie take the battery out and give it a blast for maybe5 minutes then try again.
Mar 09, 2010 | Nokia 6500 Slide Cellular Phone
Fell in water , wont power up after i charged it
The only thing you can do with this phone is leave it to dry over a couple of days. It will not work because the moisture has shorted out the internal circuitry. Do not force it to dry out with anything like a hairdryer as this can often cause more harm to the circuitry.
There's no special magic you can do at this stage to help make it work - it simply needs to dry out and sometimes if you are lucky the phone will work again once this has happened.
I would advise you to remove the battery and then leave the phone in a dry place in your house where air can easily circulate. If you are able to remove any part of the casing this will speed up the process. Do not attempt to dry the circuit board with anything - let it dry itself.
Then wait for 5 days or so and hope for the best!
Sep 27, 2009 | Sanyo Katana SCP-6600 Cellular Phone
LCD reads download
please describe in detail "How you dried it"
I f you ever drop a cell phone in water 1st thing you do is pop the back off and get the battery out.
then shake the water out as best as you can.
leave the back off and battery out for 48 hours. Dont use an oven or Sunshine or a heater or even a hairdryer. After the 48 hours insert the battery and try it out. Most people make the mistake of trying it on withing an hour or two. that just shorts out parts of the phone and permanently crippling it. Following the above procedure for proper drying is your best chance for minimal damage done to any cell phone. Splash-- uh oh! Pop that battery out ASAP! Hope this helps and tell a freind what to do if it happens to them. (it happens ALOT)
and good luck...(sorry)
Jun 09, 2009 | Samsung SGH-Z240 Cellular Phone
Hi my k850i fell into water. The phone seems to be ok except the keypad or touchscreen doesn't work and so am unable to unlock the phone. Will it eventually dry out? I've used the hairdryer and dried out...
turn the phone off, remove the battery, replace the battery cover. Place the phone in the center of a bag of dry (uncooked) rice. Close the bag and place in a warm area overnight. check the phone in the morning for proper working. The rice will help "pull" the moisture out of the unit. If after the first attempt does not correct the problem, attempt it once more. If this does not correct the problem, the unit will require servicing.
Hope this gets ya fixed with out the cost of servicing.
Please take the time to give this solution a fix ya rating.
clarkco
Apr 12, 2009 | Sony Ericsson K850i Mobile Phone
L6 phone
Hi!
My phone also fell into a bucket full of water. I just gave the phone to the service center for repair and it's now absolutely fine.
I would suggest you to do the same. Also, don't try to switch on the phone as it may lead to short circuit in your phone.
Thank You
Oct 04, 2008 | Motorola Mobility L6 Cellular Phone
Samsung SGh a437
normally the phone is no longer any good after water damage like that, but you could take the battery out and let it sit next to some thing worm for a day or two to make sure it completely dries, then put the battery back in. se if that does the trick.
Sep 07, 2008 | Samsung SGH-a437 Cellular Phone
Phone had fell down in water
take it apart an dry it with hairdryer im nt garinteyin anthing but it worked for me
Jul 29, 2008 | Samsung SGH-X830 Cellular Phone
Water
yes you can have it to fix but the problem is you can use it up to 2 to 3 months or maybe 5, i suggest to buy a new one.
peace!
Nov 25, 2007 | Samsung SGH-x426
Nokia 6230 Logo
125 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
270rexton
270rexton
