My air conditioner has started leaking and has very poor air flow. It worked fine in winter but when I switched it to cool water is coming out of it. Sometimes the fan will work (no cold air) for about 20 minutes before it starts to leak, other times it leaks straight away. Any help appreciated.
    Champion:
  • 254 Answers
This sounds like an air restriction inside the evaporator probably caused by a dirty filter or dirty evaporator coil.
Posted on Nov 15, 2008
Air Cools well but after about an hour, water starts coming into the coach through the discharge air side. Unit does not freeze up but if I shut the unit off, the tray that holds the water drains quickly,...
Your evaporator is probably dirty and is blocking some of the air flow so the air has to move around the coil and starts coming in through the condensate drain holes. That stops the condensation (water) from draining out the holes because the air is pushing it back in.Try having the unit cleaned and that should stop that leaking.
Jun 27, 2011 | Dometic Rooftop RV Air Conditioner
Poor cooling
cold air is made by refrigeration in the air conditioner. If the unit is low on the freon charge then you have a poor exchange and poor cooling. I have gotten the units to work better by putting a little water on the outside exchange coil. by bringing the temp down on the outside coil you get a better exchange and better cooling. I used a small copper tube with about 10 real small holes in it to drizzel just a little bit of water on the outside part of the machine. the fan cools off the outside coils off and gets a better exchange bringing down the temp of the air coming out of air conditioner
May 01, 2011 | Heating & Cooling
Hello, I have a Ruud 10 seer unit in the condo i rent...it frequently stops cooling. The fan inside never shuts off, but the unit outside won't come on often enough to cool to the temp on thermostat. When...
It sounds like the air cond is freezing up, and as he melts the ice off he evaporator coil you will have air flow again. When the evaporator, (which is the coil that absorbs the heat from your condo) is frozen over, no air flow can pass through it. The evaporator is located either above the furnace or below the furnace. Therefore, the indoor fan will continue to run, but no cool air will be coming out of the vents. What causes it to freeze up? Usually it is low on refrigerant (some people call it freon). If there is a leak in the system, he may charge it with refrigerant, and then in a few days or weeks later have to thaw it out, and charge it again. If this is the case, you might want to request the leak be located and fixed. Another reason it will freeze up is a dirty filter. Or, if the unit did not have a filter in it for quite some time, the evaporator could possibly be stopped up with dirt resulting in poor air flow all the time and and eventual freeze up of the evaporator. Hope this helps you, stay cool.
Apr 20, 2011 | Ruud Matching Split Air Conditioner
Plentiun air conditioning coils are icing up after running in cooling mode
frost or ice on an a\c coil has 2 causes poor air flow or a low referigant charge. poor air flow could be a ditry air filter, blower wheel or a coil. a low charge is a leak in the system
Jun 17, 2010 | Carrier 38CKC036 Air Conditioner
Our Bryant air conditioner that we bought a year ago started leaking water yesterday but was still working. It isn't working at all today even though the thermostat says "on". Is there a way to reset it?
These symptoms usually indicate a problem with the drain. If the drain for the evaporator is restricted it may leak, if it leaks enough it will activate a float switch that turns off the air cooling unit.
The first thing you need to do is locate the evaporator, depending on where you live and what type of home you have it will be in the basement or the attic most likely. There will be a pan under the cooling coils, if in that pan there is water then your drain for the cooling coils is plugged. Look above that pan for another drain line that is the one you need to clean out.
In the pan that has the water you will find some type of float or water switch that is keeping the A/C from coming on.
Send me a message here if you have questions.
May 29, 2010 | Bryant Heating & Cooling
Why does my 2004 avalanche not heat up when i am
Check the coolant level. in the winter time It will not over heat very easily but vapor locks can occur and low coolant level will do what your describing ...When you drive the water pump is spinning faster causing coolant to intermittently flow through the heater core so it gets warm then cold at an idle.. also a thermostat that is stuck open will also cause this its also in the cooling system, if the cooling system is full I would replace the thermostat..good luck hope this helps
Jan 28, 2010 | 2004 Chevrolet Avalanche
Level one working but not level two
Check to see if unit is running outside. Could be iced up. Float switch tripped means stopped up drain. Float switch located under unit or in front. Does your fan work on on positio. As a service tech he first thing we check is power to the trnasformer but unless you know what your doing you will do more damage. Check float switch and then call a service tech. Rusty
Jun 10, 2009 | Heating & Cooling
Water is not going into swamp cooler
CK THE FLOAT THAT OPENS AND CLOSES THE water valve.. press down on float to see if water is available,if water flows float needs adjusting. If no water then check to seeit hasn't been turned off for the winter -good luck
May 11, 2009 | Mastercool 67471 Evaporative Cooler Air...
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Apr 21, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
