Likom HD15A  15" LCD Monitor
Problem for Likom HD15A (Black) 15" LCD Monitor
Likom HD17A blacks out
By cookie001 on Oct 24, 2006
My monitor just started blacking out. The green light stays on but it is not in standby mode. I have to turn the monitor off, then on, then move the mouse to get it working again.
Comments:
Oct 24, 2006
- The power scheme is set to never, never, never for all options. The screen saver is set to wait 500 minutes and requires password.
Oct 28, 2006
- checked drivers and they are up to date.
also:
when it does go off,the light stays green on the monitor,
the sound and games still play,
turning off the monitor and back on works (till next blank out)
video card fan stays on
hasn't blanked out for the last 5 hours or so
Best Solution
posted on Feb 09, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Actually the bulbs are not normally the problem, usually it is is inverter board
Solution #2
posted on Oct 24, 2006
Somewhat Helpful)
sandrew
Rank: Wiz
Rating: 83%, 5938 votes
Just check that your monitor is not set to power down(Control Panel> Power Options) and check that the 'Turn Monitor Off' Power Scheme is set to never and turn off any screensaver to see if it still goes off.
Comments:
Oct 24, 2006
- Check the drivers are correct for your graphics card/on board graphics, sometimes Windows loads new generic drivers when you install updates, if it has roll back the driver.
If you are able also try doing a system restore(Start>Programmes>System Tools>System Restore) to before the problem started to see if it was a driver issue.
If all is correct, try another driver from your cards web site to see if it cures itself, if not suspect monitor is faulty, but moving the mouse, to bring it back on line sounds like a screensaver type problem.
Was this helpful?
Yes
No
Solution #3
posted on Jan 29, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
if you have an LCD monitor.. try holding a flashlight right upto it on the next black out! it worked for me.. if you can see the screen then its the bulbs in the back that need to be replaced.
Popular Solutions for Likom HD15A 15" LCD Monitor
Questions and Unsolved Problems for Likom HD15A 15" LCD Monitor
Do you recommend Likom HD15A (Black) 15" LCD Monitor?
Answer
Answer
i have bought a brand new likom 16" LCD wide Screen monitor 2 weeks ago. The screen has... (More)
Answer
i HAVE LIKOM LCD MONITOR WITH PROBLEM THE COLOR YELLOW,BLACK AND BRIGHT. I SUSPECT THE BOARD... (More)
Answer
pls sir sent me a a 2 part of diagram pls sir,
Answer
My LCD monitor is blinking orange and the AC adapter is blinking as well. please help!!!
Answer
there was something wrong with the screen. I got it fixed but when I turend on the screen it was... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Likom HD15A 15" LCD Monitor:
Top Monitor Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
