Question about Bernina Bernette 75
Need to oil and install free motion foot correctly
I took my machine in to the shop and they told me to oil it often, but I can't remember where to put the oil. I have two feet I purchased at a workshop some years ago, and I can't remember what they are for or how to get them to work. One is the clear circle foot, which I think is the freemotion foot, but I can't get it to install correctly, and the other is a big white plastic box with an arm to go on the screw post on the right side of the post, which I can install but can't figure out what it is for.
  • lengal Dec 10, 2008
    Where does the forked arm on the walking foot go on the needle arm?
  • 19 Answers
Have your machine in for service about every five years, your certified Bernina Tech should be able to help you with preventative maintenance.
-You'll need to remove your needle plate by removing the two screws, pull out your hook (this is the part your bobbin sists in) but make sure you note which way it sits inside your machine. Clean out the pocket that the hook was sitting in with a vacuum and then oil either the metal rim that the hook rested on or the underside of the hook. I would suggest the upper and lower part of the needle bar as well but caution you as any grit will damage your machine.
-Yes you are right, the plastic circle is your freehand embroidery foot. Drop your feed dogs and have some fun!
-The box is your walking foot used for quilting. Top fabric, batting and bottom fabric. The walking foot helps move all three layers evenly with your feed dogs while you sew, so it won't slide around like a sloppy hamburger.
Posted on Dec 10, 2008
Pfaff 113 want to free motion quilt the foot will not allow me to se. I even took the screw for adjusting preasure all the way out and it still has too much preassure
Sounds like perhaps you have the incorrect foot. Did you perhaps purchase a quilting foot (used for piecing)? A free motion foot is actually shorter in height so it will not contact the feed dogs or needle plate. It is this added space that allows the fabric to be moved freely under the foot. Also, be sure to drop the feed dogs.
Open Toe Free Motion Spring Foot
Open Toe Free Motion Foot
Pfaff 113 free motion foot Google Search
If the presser foot is still too long, perhaps the shank is not correct for your machine. Sorry, am unable to locate information re your particular model.
Sewing Machine Feet
Apr 05, 2017 | PfaFF Sewing Machines
I want to free hand machine quilt - but it won't work when I drop the foot
You need an embroidery foot, that doesn't lay on the fabric like a normal foot and allows free motion of the fabric. If you are using one, be sure it is the appropriate foot for your machine and that you have pushed the appropriate button or place on your machine so that the machine will place the foot in the correct position.
Feb 16, 2017 | Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
Machine well not work with the quilting foot what can I do
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? h
May 17, 2015 | Juki Sewing Machines
Do I need to use tension with free motion foot
Yes, the tension setting for 'free motion' and for 'sewing' is the same AND there must be tension; otherwise the top thread will form huge loops on the underside and eventually totally jam. Also make sure that the presser foot is down ... it is often easily left up as the 'free motion foot' disguises it.
The stitch length is irrelevant in free motion as the stitch length is determined by how fast the fabric is moved by the operator while maintaining constant speed (or close to constant).
A couple more items to check: make sure that the 'feed dogs' are either lowered or covered (depending on your machine model) AND that the 'free motion foot' is installed correctly.
Enjoy free motioning.
Aug 25, 2014 | Sewing Machines
How to set 2140 for free motion sewing
Which model are you using? Creative 4.5?, On the newer machines it drops automatically once the embroidery attachment is hooked up. On older Creatives v2.x there is a slide lever in front of the presser foot on the front.
Sep 26, 2012 | Sewing Machines
How do I set my pfaff mahine up for free motion quilting
try dropping the feed dogs, & reduce the top thread tension one number at a time till the stitches are normal
Feb 27, 2012 | Sewing Machines
Can I do free motion sewing on a Kenmore Ultra Stitch 12? Model 158 1595281 serial #31011208
If you can lower or disengage the feed dogs you can stitch free motion.
If the the feed dogs cannot be adjusted as described, you can set the stitch length to zero.
You can also tape an index card over the feed dogs and punch a hole where the needle needs to enter the needle/face plate.
A darning or free motion foot is needed.
Take a presser foot with you when shopping for the foot as it is important to match the shank length.
Newer sewing machines are low shank and the older ones long shank.
You can also order online at Clotilde (see "which foot to use" for a guide).
Feb 18, 2010 | Sewing Machines
Help setting Viking Designer I machine for free motion quilting
I assume you are doing free motion quilting? Use the V Menu, choose the first stitch. If you are using the Q Sensor foot or the spring free motion foot, go into the Set menu, hit "More" twice then turn On for either the Q Foot or Free motion. Make sure you have Needle Down turned on (top right-hand button on the left side above the needle). You might need to loosen the top tension by one or two clicks - first screen of the Set menu, under the picture that looks like DNA. A Size 90 needle is probably best and if the quilt is difficult to move about you might like to either use the Sewing Advisor to set for Heavy fabric or lessen the upper presser foot pressure - Set menu once again, next picture after the DNA. I have never had to do this with my D1 but I know some other people have. Get back if things are not working well for you.
Pam
Apr 29, 2009 | Bernina Activa 140
Sewing Machines Logo
157 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
