Question about Dell Dimension 4700 PC Desktop
Internet In answer to your questions - I have DSL, Connection is OK, can't download anything - can't get into anything.
  • 128 Answers
Try to ping any website and see if there is a response
click start / run then type this: ping goolgle.com -t
then click ok
then post the result
Posted on Nov 12, 2008
No interent connection
Your Linksys wireless router needs to be connected to a DSL or cable modem which needs to configured with the settings that your Internet Service Provider gave you.
To test your Internet connection connect a LAN cable fron your conputer to the DSL/cable modem. If you cannot connect to the Internet using this methos, you need to contact your ISP and the can check the connection to your DSL/cable modem.
Apr 12, 2012 | Linksys Computers & Internet
Telephone interupts the internet connection
I'm going to assume from your problem description that you have DSL service. With DSL, every phone or other device (answering machine, fax machine, etc.) must connect through a DSL filter. The only unfiltered connection should be the phone cord from the DSL modem line jack. If you have a phone connected to the line without a filter, it will cause your DSL connection to be interrupted. Make sure that everything is filtered and it should take care of the trouble.
Jul 09, 2011 | Computers & Internet
Need detailed help setting up my 2wire 1701hg gateway. I have high speed att dsl internet. I tryed already but att redirects me to there website, I tried calling them but they keep trying to charge mt 49$...
I can help you to configure the modem... Before that i need answers for certain questions....
How many lights are litup in your modem...? Do u have the light called "Internet and DSL" lit up in your modem ? Do you know the connection type ??? PPPoE If so do u know what is the Username and password ??
May 23, 2011 | 2wire (1000-100052-000) 802.11g/b Wireless...
Internet is so slow, can't open my yahoo and gmail
On occasion, when your router loses connection with your network, it OK to turn the router off for 20 seconds and turn it back on. It will go through a boot up sequence and return to lights on. Check your DSL light, if it's of your DSL connection is down.
If it's on, try your internet again.
If this doesn't work, download a good virus and spyware removal tool and run it full scan on your computer. It may be overrun with spyware or even a virus will cause this kind of problem.
Oct 03, 2010 | Computers & Internet
I have a Compaq s6500nx. I have dsl connection through the ethernet port. After lighting struck nearby, I can no longer connect to internet. The modem is still operating correctly and I have changed...
I would suggest before you do anything you have the DSL provider come and check the line and equipment to verify it is working ok. Then if it is all ok, then you would probably need to replace your network card.
Sep 22, 2010 | Compaq Presario S6500NX (DQ181A#ABA) PC...
I moved and switched from cable internet connection to dsl. My router is not getting the internet connection, do I need to do anything special with the change from cable to dsl or a new location???
I'm afraid so. I'm not familiar with your particular device, but usually DSL/cable routers are completely different beasts and are rarely compatible with both connection types.
It might be worth checking with your ISP - they should be well aware of what kit is compatible with your current connection.
Hope this helps,
Good luck,
Raf
Nov 09, 2009 | Packeteer PACKETSHAPER 1550-UP TO 512K...
Is there any way to increase download speed on my dialup connection? Phil
making sure you have the latest drivers for the dialup modem is about the most you can do. not sure if you've considered dsl or cable internet, but its cheaper than paying for dialup service and a phone line. (unless you don't have a cell phone and need the home phone line.)
Jun 27, 2008 | Acer Computers & Internet
Lan
Okay so if I understand your question....your desktop has DSL and you want to connect your laptop to the same DSL connection? If that is the case then what you need is a router. A router will share the DSL connection between the desktop and the laptop. A wireless router will allow your laptop to surf wirelessly if it has a wireless adapter or you can plug it into the ethernet port on the laptop. You can purchase one here. The instructions are pretty simple and straightforward and should be included with the router.
Jun 25, 2008 | Dell Latitude D600 Notebook
I NEED HELP!!!!!!!!!!!!!!!!!!!!
first how are you connecting .... dsl cable?? ... next how are you going to network ... ethernet ... wireless or USB ... next run the new connection wizard and answer the questions ... connect to the internt .... setup connection manually ... either choose broadband w/ user pass thats a DSL connection or broadband thats always on (cable) ... enter the info and connect ...
Mar 30, 2008 | Computers & Internet
My problem is, that my laptop cannot work anymore its internet connection.
Some questions before we get started: -What operating system are you running? -Are you using DSL, cable or dial-up for Internet access? -If you?re using DSL or cable are you plugging your laptop directly into the Internet provider?s box? What is the manufacturer and model of it? -Have you tested your Internet connection to make sure its working? If it?s a phone line can you dial out, if its DSL or cable try connecting another computer to it. -When you plug your Internet cable into your PC does anything appear or change on your screen? Once you give us some more information to work with we can start figuring out what is going on.
Jan 20, 2007 | Dell Inspiron 1000 Notebook
Dell Dimension 4700 PC Desktop Logo
Alun Cox
