Dvd driver not recognized
Vista generaly doesn't recognize my dvd drivers.I had an optiarc driver it stoped functioning on the manager it had a yellow sign ! .I bougth LG GH20NS15 Vista can't load cd-drivers
  • Anonymous Apr 07, 2009
    same
This is probably a registry problem, or at least mine was. My LG worked fine then disappeared and device manager had a yellow sign and said it was a corrupt driver. The problem is addressed in the MS Knowledge base Article ID: 314060. Essentially you need to go into the registry, find the key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} that refers to DVD drives (there will be a number of keys by that name), and erase the entry for Upper Filter, and for Lower Filter. Then save and reboot the machine.
Posted on Apr 22, 2009
Optiarc dvd+rw ad 7700h ata device not recognizing any devices
CHECK IN BIOS IF THE DVD IS GETTING DETECTED,, IF DETECTED , GO TO DEVICE MANAGER AND UNINSTALL THE DVD FROM DISK DRIVER AND RESTART AND IT WILL FIX IT
Aug 15, 2014 | Dell Vostro 1015 Laptop
My optiarc dvd rw drive isn't recognizing blank new dvd's to burn videos on
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 09, 2011 | AGPtek Sony Optiarc AD-7560A CD DVD RW...
Bought a Sony optiarc AD-7261S, but have an IDE connection, so got a ADP-06 bridge board to connect the drive using my IDE cable. The Sony is the 2nd cd/dvd drive on this computer, and after plugging it...
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 30, 2011 | Sony NEC Optiarc Sony Optiarc...
HP Presario DVD Drive Stopped working after installing Windows 7. Windows recognizes the drive and installs driver, but when I insert a DVD/CD, it is not read. I have found similar problems on the net...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 20, 2011 | Sony NEC Optiarc AD7560A DVD±RW Dual Layer...
Vista does not recognize HP dvd 1260i. I have a yellow exclamation in device manager.
Double-click that YELLOW mark. What do you see?
Click "Reinstall driver", and see if that resolves the problem.
Feb 19, 2011 | HP DVD1260i DVDRAM Burner
My laptop does not "read" m Optiarc DVD RW AD-5540A ATA . Code 19 Drivers may be missing or corrupted. Please help.
Try going to the device manager and uninstalling the dvd drive, reboot the laptop and windows will recognize the device and reload the frivers for it. It may even ask to go to windows update and search for a fresh driver, allow that and let windows finsh the installation. Reboot and try the device for function.
Sep 29, 2009 | ASUS (CD-S520QUIETRACK) Internal 52x...
Optical drive not working
Hi there.
To resolve this, all you should need to do, is download and install the chipset and/or cd/dvd drivers for your laptop.
You can get them from here:
http://support.gateway.com/support/drivers/ddaStep.asp?platform=10022&st=browse
Just select your model and operating system, download and install.
Hope that helps.
Tim
Apr 19, 2009 | Computers & Internet
Optiarc DVD-RW AD 7560A - well recording CD-ROMs, but not DVDs
i had the same problems so i updated the firmware for the cd/dvd drive and now its working perfectly
Jan 01, 2009 | Sony Optiarc AD-7170S Burner
Vista Home does not recognize LG DVD drivers
Try updating your drivers for the dvd players.
Apr 06, 2008 | Computers & Internet
Computers & Internet Logo
1,272 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
