Question about Sony VAIO VGN-AR230G Notebook
Resetting Fn key
HI,
I have a sony vaio. Some keys on right hand side have little numbers. If I type for example the letter "o" it will type the number 6. i would have to press the Fn key along with the key so i can type the letter.
Help Please !
how do i reset it?
thanks!
  • fatma_nasser May 11, 2010
    what shall i do? while i dont know how to install the printer?
  • 53 Answers
I think this is either the Scroll button or Num lock button is on, try toggling them off and on.
Hope this helped.
Posted on Dec 03, 2008
Laptop keyboard not typing letters
Which is it? Not typing letters or not typing numbers?
For your information there is an Fn+Fx key combination that activate the overlaid numeric keypad (your calculator). Figure out which function key to use with the Fn key.
Dec 23, 2013 | Dell Computers & Internet
I have fujitsu laptop runing win 7, when i type some letter be wrong for examle when i type m come 0 ,
Hello there,
Did you check the keypad for alternate keys.
For example net books, the number keys on the right side has an alter key on the some letters like the image below. when you accidentally press the [Fn] key, Numbers are written instead of letters..
Hopefully this helps. Thank you for posting..
Jul 12, 2011 | Computers & Internet
I have a sony vaio lalptop and some letters are not working at all: 9,o,l,,,. (I am on another laptop). Help
Hi treborswindl
Look on the keyboard to see whether any of the function keys on the top row are on. If so, you have to turn it off.
How do you do it?
Locate the [FN] key at the bottom (this is the function key between the [CTRL] and [WIN] keys.
Hold down the [FN] key and the numbered function key which is on ( for example F11 ) the top row which is lit.
Goto Microsoft word or Notepad and try out your keys.
Hope this will work for you.
Good luck
luciana44
Dec 02, 2009 | Sony VAIO VGP-WKB1 Keyboard
Hi fellas, i'm having trouble with my vaio pcg-k47. the fn key is on all the time, and instead of having letters on the key board, there are some that are wr5ting nnumbers. can u help me fix that? Can u...
Press the Function (Fn) key again to deactivate it.
Please check if the "NUM LOCK" is enabled. If it is enabled then press it to disable to resolve the letter/number key issue.
You may disable the Function key by removing the VAIO Event Services Utility or HKSERV Utility from the Startup.
1. Click on the Start, select RUN, in Run command type: msconfig and press the Enter key.
2. In the MS Configuration Utility, un-check the VAIO Event Services Utility or HKSERV Utility and then click on Apply then OK.
3. Then, restart the Computer. This will disable the Function key in the Computer.
Good Luck!!!!!!!!!
Nov 18, 2009 | Sony VAIO PCG-K47 Notebook
Hi, I've got 2 eeepcs, with identical problems,
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed.
Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Fn key plus and probably the Scroll keys, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Aug 13, 2009 | ASUS Laptop Keyboard for Asus Eee PC
Fn keys
It sounds like your FN key may be stuck. One simple thing that you might want to try would be to pick up a can of compressed air from a local electronics shop and use it to clean around and under all of the keyboard keys, but especially around the FN key. If there is something lodged around or underneath a particular key, this will sometimes clear it up.
Graye
Nov 09, 2008 | Sony VAIO VGN-AR230G Notebook
@nd function on keus
It appears that the function key is stuck on. try an external keyboard. if the external keyboard has the same problem its an issue with windows but if not you could be looking at a replacement keyboard. hope this helps Peter
Mar 28, 2007 | Sony VAIO VGN-FS640W Notebook
Sony VAIO VGN-AR230G Notebook Logo
299 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
