Question about HP Pavilion 505n (DC470A#ABA) PC Desktop
No Post after Cmos Reset
So i inherited a HP 505n from a guy at work that bought new, the main board is as follows: mso 9]> Normal 0 MicrosoftInternetExplorer4 mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";}@page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;}div.Section1 {page:Section1;}--> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}imperial-gl-ve 20021218 (Proc slot read foxcon).
So fix things fix i want to install windows so i formatted a drive in my main pc the drop it in, the 505n bios does not see it (though it sees the cdrw fine) but the setup disk seems to and asks where i want windows, so i choose the only partion available that was just formatted (WD 120 gb ntfs). It runs its "copying files for setup" cycle reboots and reasks where i want windows...strange, so then i let it format the space for the second go and get the same formats, copies setup files, reboots and ask what partion i want to use.
At this point I am not understanding whats happening...Google tells me a cmos reset may cure my ills, so i pull the battery (as i do not see a jumper) and disconect the power supply wait about 5 min replace the battery and cable and no post. The PC now turns on for a few seconds does not post then turns off, seems to me like it may be a short so i pull all the hardware and run the board on my static mat (no pc case), same result.
Further Google searches tell me that had i erased the partions and let windows decide how large they should be it could have saved me before the cmos reset. All i can think is that HP put in some funky **** in this PC so it will only recognize the parts they tell it to, but that gives me no clue how to repair it.
  • 1 more comment
  • zeroknown Nov 09, 2008
    I should have mentioned i tried both a 20 maxtor and the 120 WD neither were seen on either IDE thought both a CDrw and DVD rom were seen on both in series or alone. Regardless of of if i had one or two drive on the ribbon master and slave set or cable select no hard drive would be seen by the bios.
    Oh, i also tried multiple cables.
  • zeroknown Nov 12, 2008
    I checked the drives, the 20GB was 5400. I have thought about flashing the bios but if the board will not stay powered how can i hope to flash it?
  • 221 Answers
Referring back to your comment about the bios not seeing the new drive. If the drive is not seen and setup continues to start at the beginning then there is either a compatibility issue or a connection issue. check your cables on the drive and on the motherboard. reinsert them to ensure proper orientation and stable connection and try again. If drive is still not seen then it is probably a drive compatibility issue. However, just to make sure, try switching hard drives to see if a different drive works on the same port. If it does then it is definitely compatibility, but if not then it could be a bad port on the motherboard.
Let me know whether any of this works.
Posted on Nov 09, 2008
  • Mark Kessler Nov 09, 2008
    Was one of these drives the original for that computer, if not do you have the original?
    The original specs for the hard drive are that it is a 60 GB Ultra DMA, 5400 rpm. If you are trying to use 7200 rpm hard drives, this might be causing the problem. You may need to flash the bios (Upgrade to latest version) in order to detect the 7200 rpm drives.
    Below is a link where you can find additional links for product information and driver downloads. In the driver download section there is an update for the bios. If you click on that selection there is also step by step instructions on how to install. There is another download for a firmware upgrade, (last on list under firmware), for the hard drive dealing with»
  • Mark Kessler Nov 20, 2008
    I guess I overlooked your comment about how the computer fires up for a few seconds then shuts back down. Have you thought about replacing the power supply? If you have another computer, even if the power supply from the other computer does not fit in the space, at least hook it up and try turning the computer on. If the board stays powered up, see if the hard drive is recognized. If the hard drive is recognized with the alternate power supply, then the problem is most likely caused by the old power supply not powering up the system adequately.
Can an HP Pavilion a305w imperial GL_VE 20021218 137001 motherboard with a celeron 2.7 ghz 400 mhz intel processor be upgraded to a pentium 4 2.66 ghz 533 mhz processor?
Yes as long as it is the same case stile and 400 mhz.
Base processor Intel Celeron 2.7 GHz
  • 400 MHz Front side bus
  • Socket mPGA478
    Note.... Make sure you use PC2700 memory PC2100 will give you error messages
May 22, 2014 | Intel Computers & Internet
Imperial gl ve 20020930 SPECS
TriGem (Company) Imperial GLVE (Model)
Hmmm, I'm at a stalemate.
Looking at the specs for the motherboard chipset;
The Northbridge and Southbridge chip,
Intel 845GV
Supports CPU's with a 400MegaHertz Front Side Bus, or a
533MHz FSB.
Naturally I can't get a clear picture of those jumpers, but they look to be 3-pin.
If we are to assume that the jumper pins set the CPU FSB support, from 400MHz to 533MHz, then the jumper cap is moved from either
Pins 1 and 2, to Pins 2 and 3; on J2 jumper;
Or Pins 2 and 3, to Pins 1 and 2.
I know !O_O!
Sort of a guessing game, as to where the jumper cap goes to what pins, for 400MHz FSB support, or 533MHz FSB support.
Do you have any idea of what the FSB is for the old CPU (Processor), that was in the motherboard? (Or is)
Let's say 400MHz.
You now know if the CPU you are wanting to use, needs 533MHz Front Side Bus support, you need to move the jumper cap to the opposite pins.
What happens if it's wrong? Nothing. processor just won't work.
Change the jumper cap back.
(NOT plugged into power when you do. Also FOLLOW Anti-Static Precautions)
Yes. I'm 'out there on a limb'
I am assuming after looking at the TriGem support page, for the Imperial GLVE motherboard, that the J2 jumper is used to change the FSB support for the Processor.
It MAY be that J2 has Nothing to do with CPU Support.
It may be that there is no jumper for changing CPU FSB support.
(Cleared that right up, huh? Geez!)
For additional questions please post in a Comment.
[J1 = FDD. Floppy Disk Drive
J2 = CPU FSB jumper
J3 = CMOS Setup
J4 = CMOS,
Feb 19, 2013 | Computers & Internet
I want an Imperial GL VE 20021111 motherboard manual
Get all information about the motherboard from here...
best of luck!
Mar 07, 2012 | Computers & Internet
Save all your important files , then reformat your operating system
May 28, 2010 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Imperial GL VE 134841 20020930; need drivers &
If its in an HP machine go to HP site and download from there.
Apr 21, 2010 | Computers & Internet
How to connect front panel connectors to front panel headers on a imperial GL VE 20021218 motherboard
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
May 30, 2009 | Intel Computers & Internet
Damaged motherboard
HP uses proprietary boards so a regular ATX board wouldn't work. Here is a link to a store that carries the replacement you need but if you have time you may be able to find it cheaper elsewhere.
Hope this helps & please remember to rate my answer. Thanks.
Jan 27, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
EMachines Imperial GL VE-20021218 Motherboard Pin Out
Normally on the board there is silk printing to state what connection goes where. Also on the black connector i.e. power LED there is a small arrow that goes to pin 1 of the POWER LED pins.
Hope that was any help thanks J
Jan 20, 2008 | Computers & Internet
HP Pavilion 505n (DC470A#ABA) PC Desktop Logo
231 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
